uhd::rfnoc::window_block_control Member List
This is the complete list of members for uhd::rfnoc::window_block_control, including all inherited members.
get_coefficients(const size_t chan) const =0uhd::rfnoc::window_block_controlpure virtual
get_max_num_coefficients(const size_t chan) const =0uhd::rfnoc::window_block_controlpure virtual
node_t()uhd::rfnoc::node_t
REG_WINDOW_BLOCK_SIZEuhd::rfnoc::window_block_controlstatic
REG_WINDOW_LEN_OFFSETuhd::rfnoc::window_block_controlstatic
REG_WINDOW_LOAD_COEFF_LAST_OFFSETuhd::rfnoc::window_block_controlstatic
REG_WINDOW_LOAD_COEFF_OFFSETuhd::rfnoc::window_block_controlstatic
REG_WINDOW_MAX_LEN_OFFSETuhd::rfnoc::window_block_controlstatic
set_coefficients(const std::vector< int16_t > &coeffs, const size_t chan)=0uhd::rfnoc::window_block_controlpure virtual
