#include <uhd/rfnoc/node.hpp>
Public Types | |
enum class | forwarding_policy_t { ONE_TO_ONE , ONE_TO_FAN , ONE_TO_ALL_IN , ONE_TO_ALL_OUT , ONE_TO_ALL , DROP , USE_MAP } |
Types of property/action forwarding for those not defined by the block itself. More... | |
using | resolver_fn_t = std::function< void(void)> |
using | resolve_callback_t = std::function< void(void)> |
using | graph_mutex_callback_t = std::function< std::recursive_mutex &(void)> |
using | action_handler_t = std::function< void(const res_source_info &, action_info::sptr)> |
using | forwarding_map_t = std::unordered_map< res_source_info, std::vector< res_source_info > > |
node_t () | |
virtual | ~node_t () |
virtual std::string | get_unique_id () const |
Return a unique identifier string for this node. In every RFNoC graph,. More... | |
virtual size_t | get_num_input_ports () const =0 |
virtual size_t | get_num_output_ports () const =0 |
std::vector< std::string > | get_property_ids () const |
template<typename prop_data_t > | |
void | set_property (const std::string &id, const prop_data_t &val, const size_t instance=0) |
void | set_properties (const uhd::device_addr_t &props, const size_t instance=0) |
const prop_data_t & | get_property (const std::string &id, const size_t instance=0) |
virtual void | set_command_time (uhd::time_spec_t time, const size_t instance) |
virtual uhd::time_spec_t | get_command_time (const size_t instance) const |
virtual void | clear_command_time (const size_t instance) |
static const size_t | ANY_PORT = size_t(~0) |
Protected Types | |
using | prop_ptrs_t = std::vector< property_base_t * > |
Protected Member Functions | |
void | register_property (property_base_t *prop, resolve_callback_t &&clean_callback=nullptr) |
void | add_property_resolver (prop_ptrs_t &&inputs, prop_ptrs_t &&outputs, resolver_fn_t &&resolver_fn) |
void | set_prop_forwarding_policy (forwarding_policy_t policy, const std::string &prop_id="") |
void | set_prop_forwarding_map (const forwarding_map_t &map) |
void | set_property (const std::string &id, const prop_data_t &val, const res_source_info &src_info) |
const prop_data_t & | get_property (const std::string &id, const res_source_info &src_info) |
void | register_action_handler (const std::string &id, action_handler_t &&handler) |
void | set_action_forwarding_policy (forwarding_policy_t policy, const std::string &action_key="") |
void | set_action_forwarding_map (const forwarding_map_t &map) |
void | post_action (const res_source_info &edge_info, action_info::sptr action) |
virtual bool | check_topology (const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs) |
virtual void | shutdown () |
Static Protected Attributes | |
static dirtifier_t | ALWAYS_DIRTY |
A dirtifyer object, useful for properties that always need updating. More... | |
Friends | |
class | node_accessor_t |
The base class for all nodes within an RFNoC graph
The block supports the following types of data access:
using uhd::rfnoc::node_t::action_handler_t = std::function<void(const res_source_info&, action_info::sptr)> |
using uhd::rfnoc::node_t::forwarding_map_t = std::unordered_map<res_source_info, std::vector<res_source_info> > |
using uhd::rfnoc::node_t::graph_mutex_callback_t = std::function<std::recursive_mutex&(void)> |
protected |
using uhd::rfnoc::node_t::resolve_callback_t = std::function<void(void)> |
using uhd::rfnoc::node_t::resolver_fn_t = std::function<void(void)> |
strong |
uhd::rfnoc::node_t::node_t | ( | ) |
inlinevirtual |
protected |
Add a resolver function to this block.
A resolver function is used to reconcile state changes in the block, and is triggered by a user or other upstream/downstream blocks. A block may have multiple resolvers.
Notes on resolvers:
outputs
list can be written to.For more information, see Property Resolvers and Property Resolution.
inputs | The properties that will cause this resolver to run |
outputs | The properties that this resolver will write to |
resolver_fn | The resolver function |
uhd::runtime_error | if any of the properties listed is not registered |
protectedvirtual |
Check if the current connections "work" for this block
The default implementation simply checks if all connections are within the valid range, i.e., no connected_inputs
element is larger than get_num_input_ports(), etc. This can be overridden, but keep in mind that blocks need some kind of tolerance here, because blocks may simply not be part of the current application, and left unconnected. This check is more meant for blocks that simply don't work of only one of two ports is connected, or situations like that.
Note that this method is always called when a graph is committed, i.e., no connections will be added or removed without calling this method again, unless the user bypasses calling uhd::rfnoc_graph::commit(). This method can therefore be used to make decisions about the behaviour of the block.
connected_inputs | A list of input ports that are connected |
connected_outputs | A list of output ports that are connected |
virtual |
Standard API for resetting the command time
This will clear the time previously set by set_command_time(). It defaults to calling set_command_time(time_spec_t(0.0), instance)
virtual |
Return a previously set command time
When no time was set, this will return uhd::time_spec_t::ASAP
Return the number of input ports for this block.
This function needs to be overridden.
Implemented in uhd::rfnoc::noc_block_base.
Return the number of output ports for this block.
protected |
Get the value of a property.
This is like get_property(), but it also allows reading edge properties. All comments from get_property() still apply.
prop_data_t | The data type of the property |
id | The identifier of the property to write. |
src_info | Source info of this property |
uhd::lookup_error | if the property can't be found. |
const prop_data_t & uhd::rfnoc::node_t::get_property | ( | const std::string & | id, |
const size_t | instance = 0 |
Get the value of a specific block argument. The
type of an argument must be known at compile time.
If the property does not exist, or if the property can be determined to be of a different type than prop_data_t
due to the usage of runtime type information (RTTI), a lookup_error is thrown.
Note: Despite this being a "getter", this function is not declared const. This is because internally, it can resolve properties, which may cause changes within the object.
instance | The instance number of this property |
std::vector<std::string> uhd::rfnoc::node_t::get_property_ids | ( | ) | const |
Return the names of all possible user properties that can be accessed for this block.
Note that the type of the property is not auto-detectable.
virtual |
Reimplemented in uhd::rfnoc::noc_block_base.
protected |
Post an action to an up- or downstream node in the graph.
If the action is posted to an edge which is not connected, the action is lost.
edge_info | The edge to which this action is posted. If edge_info.type == INPUT_EDGE, the that means the action will be posted to an upstream node, on port edge_info.instance. |
action | A reference to the action info object. |
uhd::runtime_error | if edge_info is not either INPUT_EDGE or OUTPUT_EDGE |
protected |
Handle a request to perform an action. The default action handler ignores user action and forwards port actions.
id | The action ID for which this action handler is valid. The first argument to the handler will be a uhd::rfnoc::action_info::sptr, and its id value will match this parameter (unless the same action handler is registered multiple times). If this function was previously called with the same id value, the previous action handler is overwritten. |
handler | The function that is called to handle the action. It needs to accept a uhd::rfnoc::res_source_info object, and a uhd::rfnoc::action_info::sptr. |
protected |
Register a property for this block
This is typically called from the constructor. It is possible to register properties later, but then the node must take care of serialization.
This has the intentional side-effect of setting the access mode to RW for the property. The idea is that after registering a property, the node might need some time to settle on the default value. The access mode will either be reset after the constructor is finished, or the next time properties are resolved.
For more information, see Defining Properties.
prop | A reference to the property |
clean_callback | A callback that gets executed whenever this property is dirty and gets marked clean |
uhd::key_error | if another property with the same ID and source type is already registered |
protected |
Specify a table that maps how an action should be forwarded
Whenever this node is asked to handle an action that is not registered, and the forwarding policy for the particular action is set to USE_MAP, the node will consult a user-provided map to determine what to do with the action. The map's keys are the source edges for the incoming action and the value associated with each key is a vector of destination edges to which the action should be forwarded.
incoming action and the value is a vector of destination edges to which the action should be forwarded.
If there is no key in the map matching an incoming action's source edge, or if the value of the key is the empty vector, the action is dropped and not forwarded further.
The following conditions will generate exceptions at action forwarding time:
map | The map describing how actions should be forwarded |
protected |
Set an action forwarding policy
Whenever this node is asked to handle an action that is not registered, this is how the node knows what to do with the action. For example, the FIFO block controller will almost always want to pass on actions to the next block.
This method can be called more than once, and it will overwrite previous policies. Typically, this function should only ever be called from within the constructor.
policy | The policy that is applied (see also forwarding_policy_t). |
action_key | The action key that this forwarding policy is applied to. If action_key is not given, it will apply to all properties, unless a different policy was given with a matching key. |
virtual |
Standard API for setting the command time
There are instances where commands need a time associated with them. For example, a block could have a 'freq' user property, which should be changed at a certain time. In that case, the block would have to be written to handle command times.
The reason there is no 'time' parameter in set_property() or other API calls is because there is no uniform definition of what the time means; it can change from block to block. The transformation of time
to a tick count, for example, is non-standard.
The default implementation will simply stash away the time; it can be retrieved by calling get_command_time();
protected |
Specify a table that maps how a property should be forwarded
Whenever this node is asked to handle a property that is not registered, and the forwarding policy for the particular property is set to USE_MAP, the node will consult a user-provided map to determine what to do with the property. The map's keys are the source edges for the incoming property and the value associated with each key is a vector of destination edges to which the property should be propagated.
If there is no key in the map matching an incoming property's source edge, or if the value of the key is the empty vector, the property is dropped and not propagated further.
The following conditions will generate exceptions at property propagation time:
See also Handling unknown properties.
map | The map describing how properties should be propagated |
protected |
Set a property forwarding policy for dynamic properties
Whenever this node is asked to handle a property that is not registered, this is how the node knows what to do with the property. For example, the FIFO block controller will almost always want to pass on properties to the next block.
This method can be called more than once, and it will overwrite previous policies. However, once a property has been registered with this block, the policy is set. Typically, this function should only ever be called from within the constructor.
prop_id | The property ID that this forwarding policy is applied to. If prop_id is not given, it will apply to all properties, unless a different policy was given with a matching ID. |
void uhd::rfnoc::node_t::set_properties | ( | const uhd::device_addr_t & | props, |
Set multiple properties coming from a dictionary
This is equivalent to calling set_property() individually for every key/value pair of props. However, the type of the property will be automatically derived using RTTI. Only certain types are supported.
Property resolution happens after all properties have been updated.
This function allows the client to override the instance
parameter for each property key/value pair passed in via the props
parameter. If the key consists of the property name, followed by a colon (':') and then a number, the number following the colon is used to determine which instance of the property this set pertains to, and the instance
parameter is ignored for that property. (Note that if the key does not have the colon and instance number override syntax, then instance
is still used to determine which instance of the property to set. For example, in the following call:
node->set_properties("dog=10,cat:2=5,bird:0=0.5", 1)
instance 1 of node's 'dog' property is set to 10, the 1 coming from the instance parameter, instance 2 of the node's 'cat' property is set to 5 due to the override syntax provided in the string, and instance 0 of the node's 'bird' property is set to 0.5 due to its override.
If the instance override is malformed, that is, there is no number following the colon, or the number cannot be parsed as an integer, a value_error is thrown.
If a key in props
is not a valid property of this block, a warning is logged, but no error is raised.
protected |
Set a specific property that belongs to this block.
This is like set_property(), but it also allows setting edge properties. All comments from set_property() still apply.
id | The identifier of the property to write. To find out which values of id are valid, call get_property_ids() |
val | The new value of the property. |
src_info | Source info of the property |
void uhd::rfnoc::node_t::set_property | ( | const std::string & | id, |
const prop_data_t & | val, | ||
Set a specific user property that belongs to this block.
Setting a user property will trigger a property resolution. This means that changing this block can have effects on other nodes.
protectedvirtual |
Perform a shutdown sequence
This is mostly relevant for noc_block_base implementations. See also noc_block_base::shutdown().
friend |
staticprotected |
