16 namespace uhd {
namespace rfnoc {
namespace rf_control {
28 using sptr = std::shared_ptr<core_iface>;
140 const std::string& name,
const size_t chan)
const = 0;
152 virtual double get_tx_gain(
const size_t chan) = 0;
164 virtual double set_tx_gain(
const double gain,
174 const double gain,
187 const std::string& name,
const size_t chan)
const = 0;
199 virtual double get_rx_gain(
208 virtual double set_rx_gain(
const double gain,
218 const double gain,
224 virtual void set_rx_agc(
const bool enable,
281 const std::string& name,
const size_t chan)
const = 0;
292 const std::string& name,
const size_t chan)
const = 0;
304 const std::string& src,
325 bool enabled,
342 double freq,
370 const std::string& name,
const size_t chan)
const = 0;
381 const std::string& name,
393 const std::string& src,
414 const bool enabled,
433 const double freq,
Definition: core_iface.hpp:26
virtual double set_rx_lo_freq(double freq, const std::string &name, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range(size_t chan) const =0
virtual double get_rx_bandwidth(const size_t chan)=0
virtual std::string get_rx_antenna(const size_t chan) const =0
virtual void set_rx_lo_source(const std::string &src, const std::string &name, const size_t chan)=0
virtual double set_tx_lo_freq(const double freq, const std::string &name, const size_t chan)=0
virtual uhd::freq_range_t get_rx_frequency_range(const size_t chan) const =0
virtual double get_rx_gain(const size_t chan)=0
virtual std::vector< std::string > get_rx_gain_names(const size_t chan) const =0
virtual std::vector< std::string > get_tx_lo_names(const size_t chan) const =0
virtual bool get_tx_lo_export_enabled(const std::string &name, const size_t chan)=0
virtual double get_tx_gain(const size_t chan)=0
virtual bool get_rx_lo_export_enabled(const std::string &name, const size_t chan)=0
virtual double get_tx_bandwidth(const size_t chan)=0
virtual double set_tx_gain(const double gain, const size_t chan)=0
virtual double set_rx_bandwidth(const double bandwidth, const size_t chan)=0
virtual double get_tx_gain(const std::string &name, const size_t chan)=0
virtual double set_rx_gain(const double gain, const size_t chan)=0
virtual void set_rx_tune_args(const uhd::device_addr_t &args, const size_t chan)=0
virtual double set_rx_gain(const double gain, const std::string &name, const size_t chan)=0
virtual void set_rx_lo_export_enabled(bool enabled, const std::string &name, const size_t chan)=0
virtual void set_rx_agc(const bool enable, const size_t chan)=0
virtual std::vector< std::string > get_rx_lo_sources(const std::string &name, const size_t chan) const =0
virtual void set_tx_lo_source(const std::string &src, const std::string &name, const size_t chan)=0
virtual void set_rx_antenna(const std::string &ant, const size_t chan)=0
virtual meta_range_t get_tx_bandwidth_range(size_t chan) const =0
virtual double get_tx_frequency(const size_t chan)=0
virtual std::string get_tx_antenna(const size_t chan) const =0
virtual std::vector< std::string > get_tx_lo_sources(const std::string &name, const size_t chan) const =0
virtual double get_rx_gain(const std::string &name, const size_t chan)=0
virtual uhd::gain_range_t get_rx_gain_range(const std::string &name, const size_t chan) const =0
virtual double set_tx_bandwidth(const double bandwidth, const size_t chan)=0
virtual std::string get_rx_lo_source(const std::string &name, const size_t chan)=0
virtual uhd::gain_range_t get_tx_gain_range(const std::string &name, const size_t chan) const =0
virtual double set_tx_gain(const double gain, const std::string &name, const size_t chan)=0
virtual uhd::gain_range_t get_rx_gain_range(const size_t chan) const =0
virtual double set_tx_frequency(const double freq, size_t chan)=0
virtual std::vector< std::string > get_tx_gain_names(const size_t chan) const =0
virtual double get_rx_frequency(const size_t chan)=0
std::shared_ptr< core_iface > sptr
Definition: core_iface.hpp:28
virtual std::vector< std::string > get_rx_lo_names(const size_t chan) const =0
virtual double get_tx_lo_freq(const std::string &name, const size_t chan)=0
virtual uhd::freq_range_t get_tx_frequency_range(const size_t chan) const =0
virtual freq_range_t get_rx_lo_freq_range(const std::string &name, const size_t chan) const =0
virtual ~core_iface()=default
virtual void set_tx_tune_args(const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::gain_range_t get_tx_gain_range(const size_t chan) const =0
virtual void set_tx_lo_export_enabled(const bool enabled, const std::string &name, const size_t chan)=0
virtual double set_rx_frequency(const double freq, const size_t chan)=0
virtual void set_tx_antenna(const std::string &ant, const size_t chan)=0
virtual std::vector< std::string > get_rx_antennas(const size_t chan) const =0
virtual std::string get_tx_lo_source(const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_tx_antennas(const size_t chan) const =0
virtual freq_range_t get_tx_lo_freq_range(const std::string &name, const size_t chan)=0
virtual double get_rx_lo_freq(const std::string &name, const size_t chan)=0
Definition: build_info.hpp:12
