23 namespace uhd {
namespace usrp {
56 typedef std::shared_ptr<dboard_iface>
sptr;
75 enum aux_adc_t { AUX_ADC_A = int(
'a'), AUX_ADC_B = int(
'b') };
258 const std::string& fe_name,
284 virtual void sleep(
const std::chrono::nanoseconds& time);
292 std::function<
void(uint32_t, uint32_t)>,
293 std::function<uint32_t(uint32_t)>)
Definition: serial.hpp:36
Definition: time_spec.hpp:31
Definition: dboard_iface.hpp:54
virtual uint32_t get_atr_reg(unit_t unit, atr_reg_t reg)=0
virtual uint32_t get_gpio_ddr(unit_t unit)=0
virtual void set_gpio_ddr(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0
aux_adc_t
Definition: dboard_iface.hpp:75
virtual void set_clock_rate(unit_t unit, double rate)=0
Definition: dboard_iface.hpp:57
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:56
virtual special_props_t get_special_props(void)=0
~dboard_iface(void) override
Definition: dboard_iface.hpp:79
virtual void set_atr_reg(unit_t unit, atr_reg_t reg, uint32_t value, uint32_t mask=0xffff)=0
virtual void set_command_time(const uhd::time_spec_t &t)=0
virtual uhd::time_spec_t get_command_time(void)=0
virtual void write_aux_dac(unit_t unit, aux_dac_t which_dac, double value)=0
virtual uint32_t get_gpio_out(unit_t unit)=0
uhd::usrp::gpio_atr::gpio_atr_reg_t atr_reg_t
Definition: dboard_iface.hpp:77
virtual std::vector< double > get_clock_rates(unit_t unit)=0
virtual void set_pin_ctrl(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0
virtual void set_gpio_out(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0
unit_t
virtual void set_fe_connection(unit_t unit, const std::string &fe_name, const uhd::usrp::fe_connection_t &fe_conn)=0
virtual double get_codec_rate(unit_t unit)=0
virtual bool has_set_fe_connection(const unit_t)
Definition: dboard_iface.hpp:263
virtual uint32_t get_pin_ctrl(unit_t unit)=0
virtual uint32_t read_write_spi(unit_t unit, const spi_config_t &config, uint32_t data, size_t num_bits)=0
virtual void sleep(const std::chrono::nanoseconds &time)
virtual void define_custom_register_space(const uint32_t, const uint32_t, std::function< void(uint32_t, uint32_t)>, std::function< uint32_t(uint32_t)>)
Definition: dboard_iface.hpp:290
virtual void write_spi(unit_t unit, const spi_config_t &config, uint32_t data, size_t num_bits)=0
virtual uint32_t read_gpio(unit_t unit)=0
virtual double get_clock_rate(unit_t unit)=0
aux_dac_t
Definition: dboard_iface.hpp:67
virtual double read_aux_adc(unit_t unit, aux_adc_t which_adc)=0
virtual void set_clock_enabled(unit_t unit, bool enb)=0
Definition: fe_connection.hpp:17
Definition: config.h:87
Definition: soft_register.hpp:86
gpio_atr_reg_t
Definition: gpio_defs.hpp:12
Definition: build_info.hpp:12
Definition: serial.hpp:83
Definition: dboard_iface.hpp:27
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:44
bool soft_clock_divider
Definition: dboard_iface.hpp:34
