error.h File Reference
#include <stdlib.h>
Enumerations
enum  uhd_error {
  UHD_ERROR_NONE = 0 , UHD_ERROR_INVALID_DEVICE = 1 , UHD_ERROR_INDEX = 10 , UHD_ERROR_KEY = 11 ,
  UHD_ERROR_NOT_IMPLEMENTED = 20 , UHD_ERROR_USB = 21 , UHD_ERROR_IO = 30 , UHD_ERROR_OS = 31 ,
  UHD_ERROR_ASSERTION = 40 , UHD_ERROR_LOOKUP = 41 , UHD_ERROR_TYPE = 42 , UHD_ERROR_VALUE = 43 ,
  UHD_ERROR_RUNTIME = 44 , UHD_ERROR_ENVIRONMENT = 45 , UHD_ERROR_SYSTEM = 46 , UHD_ERROR_EXCEPT = 47 ,
  UHD_ERROR_BOOSTEXCEPT = 60 , UHD_ERROR_STDEXCEPT = 70 , UHD_ERROR_UNKNOWN = 100
 UHD error codes. More...
Functions
UHD_API uhd_error uhd_get_last_error (char *error_out, size_t strbuffer_len)
 Return the last error string reported by UHD. More...
◆ uhd_error
enum uhd_error
UHD error codes.
Each error code corresponds to a specific uhd::exception, with extra codes corresponding to a boost::exception, std::exception, and a catch-all for everything else. When an internal C++ function throws an exception, UHD converts it to one of these error codes to return on the C level.
Enumerator
UHD_ERROR_NONE
No error thrown.
Invalid device arguments.
UHD_ERROR_INDEX
See uhd::index_error.
UHD_ERROR_KEY
See uhd::key_error.
See uhd::not_implemented_error.
UHD_ERROR_USB
See uhd::usb_error.
UHD_ERROR_IO
See uhd::io_error.
UHD_ERROR_OS
See uhd::os_error.
UHD_ERROR_ASSERTION
See uhd::assertion_error.
UHD_ERROR_LOOKUP
See uhd::lookup_error.
UHD_ERROR_TYPE
See uhd::type_error.
UHD_ERROR_VALUE
See uhd::value_error.
UHD_ERROR_RUNTIME
See uhd::runtime_error.
See uhd::environment_error.
UHD_ERROR_SYSTEM
See uhd::system_error.
UHD_ERROR_EXCEPT
See uhd::exception.
A boost::exception was thrown.
UHD_ERROR_STDEXCEPT
A std::exception was thrown.
UHD_ERROR_UNKNOWN
An unknown error was thrown.
Function Documentation
◆ uhd_get_last_error()
UHD_API uhd_error uhd_get_last_error ( char *  error_out,
Functions that do not take in UHD structs/handles will place any error strings into a buffer that can be queried with this function. Functions that do take in UHD structs/handles will place their error strings in both locations.
