18 namespace uhd {
namespace experts {
56 template <
typename data_t>
58 const std::string& name,
59 const data_t& init_val,
91 template <
typename data_t>
95 const std::string& name,
96 const data_t& init_val,
107 container->add_data_node(node_ptr, mode);
123 template <
typename data_t>
127 const data_t& init_val,
130 return add_prop_node(container, subtree, path, path, init_val, mode);
151 template <
typename data_t>
155 const std::string& desired_name,
156 const std::string& coerced_name,
157 const data_t& init_val,
160 bool auto_resolve_desired =
162 bool auto_resolve_coerced =
177 container->add_data_node(desired_node_ptr,
179 container->add_data_node(coerced_node_ptr,
197 template <
typename data_t>
201 const data_t& init_val,
204 return add_dual_prop_node(container,
222 template <
typename worker_t>
225 container->add_worker(
new worker_t());
242 template <
typename worker_t,
typename... Args>
246 container->add_worker(
new worker_t(args...));
Definition: expert_nodes.hpp:129
std::shared_ptr< expert_container > sptr
Definition: expert_container.hpp:28
Definition: expert_factory.hpp:32
static void add_worker_node(expert_container::sptr container, Args const &... args)
Definition: expert_factory.hpp:243
static void add_data_node(expert_container::sptr container, const std::string &name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:57
static property< data_t > & add_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const std::string &name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:92
static expert_container::sptr create_container(const std::string &name)
static void add_worker_node(expert_container::sptr container)
Definition: expert_factory.hpp:223
static property< data_t > & add_dual_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const std::string &desired_name, const std::string &coerced_name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:152
static property< data_t > & add_dual_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:198
static property< data_t > & add_prop_node(expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
Definition: expert_factory.hpp:124
Definition: property_tree.hpp:223
@ AUTO_COERCE
Definition: property_tree.hpp:225
@ MANUAL_COERCE
Definition: property_tree.hpp:79
virtual property< T > & set_publisher(const publisher_type &publisher)=0
virtual property< T > & add_desired_subscriber(const subscriber_type &subscriber)=0
virtual property< T > & add_coerced_subscriber(const subscriber_type &subscriber)=0
virtual property< T > & set_coerced(const T &value)=0
virtual property< T > & set(const T &value)=0
Definition: config.h:87
auto_resolve_mode_t
Definition: expert_container.hpp:18
@ AUTO_RESOLVE_ON_WRITE
Definition: expert_container.hpp:21
@ AUTO_RESOLVE_ON_READ
Definition: expert_container.hpp:20
@ AUTO_RESOLVE_OFF
Definition: expert_container.hpp:19
@ AUTO_RESOLVE_ON_READ_WRITE
Definition: expert_container.hpp:22
Definition: build_info.hpp:12
Definition: property_tree.hpp:206
