Here is a list of a changes with the latest E310 filesystem (UHD v3.15.0.0 and later) that can affect customer usage and applications:
ni-e31x-$serial
. This makes it easier to identify devices. You can change the hostname by creating the file /data/network/hostname
, saving the desired hostname in it, then rebooting.FPGA bit/bin/rpt file name and image target:
FPGA type | Old filename | New filename |
IDLE Image (power saving mode) SG1 | usrp_e3xx_fpga_idle.bit | usrp_e310_sg1_idle_fpga.bit |
IDLE Image (power saving mode) SG3 | usrp_e3xx_fpga_idle_sg3.bit | usrp_e310_sg3_idle_fpga.bit |
NORMAL Image SG1 | usrp_e310_fpga.bit | usrp_e310_sg1_fpga.bit |
NORMAL Image SG3 | usrp_e310_fpga_sg3.bit | usrp_e310_sg3_fpga.bit |
The names of the FPGA build targets have been modified but the old FPGA targets would continue to work as before. The generated bit files names in the build directory will be new as mentioned above.
FPGA Image Flavor | SFP+ Port 0 Interface |
1G (Default) | 1 Gigabit Ethernet |
XG | 10 Gigabit Ethernet |
AA | Aurora |
[sudo] uhd_images_downloader
uhd_image_loader --args type=e3xx,addr=<IP Address>,fpga=XG
Checklist:
The image will be downloaded to <UHD_INSTALL_DIR>/share/uhd/images/usrp_<e310/e320>_fs.sdimg
, where <UHD_INSTALL_DIR>
is the UHD installation directory.
The <YOUR_IMAGE>
is the path to the micro SD card image (i.e.<UHD_INSTALL_DIR>/share/uhd/images/usrp_<e310/e320>_fs.sdimg
The <YOUR_SD_CARD>
device node depends on your operating system and which other devices are plugged in. Typical values are sdb
or mmcblk0
CAUTION: The Linux utility dd
or bmap
can cause unrecoverable data loss if the incorrect disk is selected, or if the parameters are input incorrectly. Ensure you have selected the correct input and output parameters for your system configuration.
In this command, we prepend 'sudo' to elevate user privileges (by default, accessing serial ports is not available to regular users), we specify the device node (in this case, /dev/ttyUSB2
), and the baud rate (115200).
The exact device node depends on your operating system's driver and other USB devices that might be already connected. Modern Linux systems offer alternatives to simply trying device nodes; instead, the OS might have a directory of symlinks under /dev/serial/by-id
For E310:
$ ls /dev/serial/by-id /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DQ0041HO-if00-port0
For E320:
$ ls /dev/serial/by-id /dev/serial/by-id/usb-FTDI_Dual_RS232-HS-if00-port0 /dev/serial/by-id/usb-FTDI_Dual_RS232-HS-if01-port0 /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A6C-if00-port0 /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A6C-if01-port0
Every E320 device connected to USB will by default show up as four different devices. The devices labeled "USB_to_UART_Bridge_Controller" are the devices that offer a serial prompt. The one with the if01
suffix connects to Linux, whereas the one with if00
suffix connects to the STM32 microcontroller. If you have multiple E320 devices connected, you may have to try out multiple devices. In this case, to use this symlink instead of the raw device node address, modify the command above to:
For E310:
For E320:
Depending on your network setup, using a .local
domain may work:
Note: The device's hostname is derived from its serial number by default (ni-<e31x/e320>-<SERIAL>
). You can change the hostname by creating the file /data/network/hostname
eth0 (DHCP): [Match] Name=eth0 [Network] DHCP=v4 [DHCPv4] UseHostname=false
E320 has an extra SFP+ (sfp0) port which is configured with static address 192.168.10.2/24. The configuration for the sfp0
port is stored in /data/network/sfp0.network
sfp0 (static): [Match] Name=sfp0 [Network] Address=192.168.10.2/24 [Link] MTUBytes=9000
Note: Care needs to be taken when editing these files on the device, since vi / vim sometimes generates undo files (e.g. /data/network/sfp0.network~
), that systemd-networkd might accidentally pick up.
With UHD 4.0 the RJ-45 port can also be used for streaming samples from the USRP device to the host or other remote operations such as uhd_image_loader
. Please note: As the SDR application runs on an embedded CPU with limited processing capability, users should leverage the FPGA using tools such as RFNoC to offload compute intensive algorithms that process high bandwidth samples. The maximum sample rates that can be achieved are 4.4 MS/s on the E31x and 6.4 MS/s on the E320 when streaming through the RJ-45 port. As the E320 has an additional highspeed SFP Port, the RJ-45 port should only be used for streaming data from the E320 if necessary.
master_clock_rate=13.2e6
, rx_rate=4.4e6
master_clock_rate=19.6e6
, rx_rate=6.4e6
The E320 ships without a root password set. It is possible to ssh into the device by simply connecting as root, and thus gaining access to all subsystems. To set a password, run the command
$ passwd
on the device.
Updating the FPGA follows the same procedure as other USRPs. Use the uhd_image_loader
command line utility to upload a new FPGA image onto the device. The command can be run on the host to load the image via RJ-45 network connection or it can be run on the device.
$ uhd_images_downloader
to update the FPGA using the default settings. Replace the addr above with the correct device address. If a custom FPGA image is targeted for uploading, use the --fpga-path
command line argument. Run
$ uhd_image_loader --help
to see a full list of command line options. Note that updating the FPGA image will force a reload of the FPGA, and in case of E320 it will temporarily take down the SFP network interfaces (and temporary settings, such as applied via ifconfig
on the command line, will be lost).
Key | Description | Example Value |
addr | IPv4 address of primary SFP+/RJ-45 port to connect to | addr=192.168.30.2 |
find_all | When using broadcast, find all devices, even if unreachable via CHDR. | find_all=1 |
master_clock_rate | Master Clock Rate in Hz. Default is 16 MHz. | master_clock_rate=30.72e6 |
skip_init | Skip the initialization process for the device. | skip_init=1 |
discovery_port | Override default value for MPM discovery port. | discovery_port=49700 |
rpc_port | Override default value for MPM RPC port. | rpc_port=49701 |
enable_gps | Enable/disable power to the integrated GPSDO (E320 only). | enable_gps=0 |
Like other USRPs, the E3x0 series has RF and motherboard sensors. When using uhd::usrp::multi_usrp, the following API calls are relevant to interact with the sensor API:
temp_fpga
: temperature (in Celsius) of the FPGA dietemp_mb
: temperature (in Celsius) of the motherboardref_locked
: This will check that all the daughter boards have locked to the reference clock.The following daughterboard sensors are always available:
lo_locked
: Boolean sensor value to check if the AD9361 LO has locked to its referencelo_lock
: Alias to lo_locked
(for backward compatibility reasons)ad9361_temperature
: Temperature sensor of the RFIC dierssi
: RSSI value as returned from the AD9361 (RX only)The following motherboard sensors are always available:
temp_internal
: temperature (in Celsius) of Temperature Sensor on boardtemp_fpga
: temperature (in Celsius) of the FPGA dietemp_rf_channelA
: temperature (in Celsius) near power amplifier RF Atemp_rf_channelB
: temperature (in Celsius) near power amplifier RF Btemp_main_power
: temperature (in Celsius) near power supplygps_locked
: GPS lockgps_time
: GPS time in seconds sin ce the epchgps_tpv
: A TPV report from GPSd serialized as JSONgps_sky
: A SKY report from GPSd serialized as JSONref_locked
: This will check that all the daughter boards have locked to the external/internal reference clock.fan
: get fan speed (in rpm)The following daughterboard sensors are always available:
lo_locked
: RSSI value as returned from the AD9361 (RX only)The E3xx series support the UHD power calibration API (see: Power Level Controls). The TX path and the two RX paths per channel each have their own calibration data, resulting in 6 sets of calibration data per E3xx device.
Devices have to be manually calibrated using a calibrated power meter or signal generator.
To initiate an update from the device itself, download a Mender artifact containing the update itself. These are files with a .mender
suffix.
$ reboot
$ mender commit
$ systemctl start salt-minion
apt install salt-master
if the server is an Ubuntu system), and make sure the Salt master is running./etc/salt/minion
file on the device by editing the master:
line.systemctl start salt-minion
.salt-key -a $hostname
where $hostname
is the name of the minion.Note: Do not source high currents (more than 5 mA) per pin. The GPIOs are not designed to drive high loads!
Note: Unlike the X300 series, the E3XX series does not have user-programmable daughterboard GPIOs. The front-panel (or internal) GPIOs can still be used to track the ATR state of the radios, though (see below).
The E320 series devices have a built-in self-test that can be used to verify the hardware. It is not automatically run, but it can be invoked anytime by running the e320_bist
executable. Calling
e320_bist -h
e320_bist gpsdo
will test the functionality of the GPSDO. Calling e320_bist standard
will run a standard set of tests, verifying some base peripherals such as the RTC, the fan and temperature sensors, etc.
Some tests require special hardware connected. For example, for the sfp_loopback
tests, a loopback module must be plugged into the SFP+.
$ mkdir uhd # Create a new, empty directory called uhd $ sshfs user@yourcomputer:src/uhd uhd # This will mount ~/src/uhd from the remote machine to ~/uhd on the device
$ mkdir build_mpm $ cd build_mpm # You are now in /home/root/build_mpm $ cmake -DMPM_DEVICE=e320 ../uhd/mpm $ make -j2 install # This will take several minutes
Note that this overwrites your system MPM. You can install MPM to another location by specifying -DCMAKE_INSTALL_PREFIX
, but make sure to update all of your paths appropriately.
If this doesn't work, the executable permissions of the file might have been lost (this can occur with some versions of Python). In that case, add those permissions back before executing the .sh
file:
Executing the .sh
file will prompt you for an installation path. Please ensure you have sufficient disk space, as each of the SDKs may require several gigabytes of disk space (depending on the image flavor selected).
$ $CC -dumpmachine
$ cmake -DCMAKE_TOOLCHAIN_FILE=../host/cmake/Toolchains/oe-sdk_cross.cmake -DCMAKE_INSTALL_PREFIX=/usr .. # Add any CMake options you desire $ make # You can run make -j12 to compile on 12 processes at onceNote: The UHD you are cross-compiling will not run on your host computer (the one where you're doing the development). Compiling UHD regularly on your host computer (with MPMD enabled) will allow you to talk to your device.
<args>
are device address arguments (optional if only one USRP device is on your machine)
The device provides a 3.3V supply voltage to an external antenna connected to the GPS port of your device. Note that this supply voltage is turned off in order to save power upon destruction of the software object.
Pin 1 is connected to the shared +3.3V power rail and can be used to draw power. The maximum current depends on the power used by the rest of the device, but 300-500 mA is generally safe. It is recommended to monitor the rail voltage when drawing power from this pin.
The pins are as follows:
and for the charger:
Type:
Receive
RX Port | RX Filter (MHz) | VCTXRX2_V1,V2 | VCRX2_V1,V2 | RX2_BANDSEL[2:0] | RX2B_BANDSEL[1:0] | RX2C_BANDSEL[1:0] |
TRX-A | < 450 | 01 | 10 | 101 | XX | 01 |
TRX-A | 450 – 700 | 01 | 10 | 011 | XX | 11 |
TRX-A | 700 – 1200 | 01 | 10 | 001 | XX | 10 |
TRX-A | 1200 – 1800 | 01 | 10 | 000 | 01 | XX |
TRX-A | 1800 – 2350 | 01 | 10 | 010 | 11 | XX |
TRX-A | 2350 – 2600 | 01 | 10 | 100 | 10 | XX |
TRX-A | 2600 – 6000 | 01 | 01 | XXX | XX | XX |
RX2-A | 70 – 450 | TT | 01 | 101 | XX | 01 |
RX2-A | 450 – 700 | TT | 01 | 011 | XX | 11 |
RX2-A | 700 – 1200 | TT | 01 | 001 | XX | 10 |
RX2-A | 1200 – 1800 | TT | 01 | 000 | 01 | XX |
RX2-A | 1800 – 2350 | TT | 01 | 010 | 11 | XX |
RX2-A | 2350 – 2600 | TT | 01 | 100 | 10 | XX |
RX2-A | >= 2600 | TT | 10 | XXX | XX | XX |
Transmit
TX Port | TX Filter (MHz) | VCTXRX2_V1,V2 | TX_ENABLE2A,2B | TX_BANDSEL[2:0] |
TRX-A | < 117.7 | 10 | 01 | 111 |
TRX-A | 117.7 – 178.2 | 10 | 01 | 110 |
TRX-A | 178.2 – 284.3 | 10 | 01 | 101 |
TRX-A | 284.3 – 453.7 | 10 | 01 | 100 |
TRX-A | 453.7 – 723.8 | 10 | 01 | 011 |
TRX-A | 723.8 – 1154.9 | 10 | 01 | 010 |
TRX-A | 1154.9 – 1842.6 | 10 | 01 | 001 |
TRX-A | 1842.6 – 2940.0 | 10 | 01 | 000 |
TRX-A | >= 2940.0 | 11 | 10 | XXX |
Receive
RX Port | RX Filter (MHz) | VCTXRX1_V1,V2 | VCRX1_V1,V2 | RX1_BANDSEL[2:0] | RX1B_BANDSEL[1:0] | RX1C_BANDSEL[1:0] |
TRX-B | < 450 | 10 | 01 | 100 | XX | 10 |
TRX-B | 450 – 700 | 10 | 01 | 010 | XX | 11 |
TRX-B | 700 – 1200 | 10 | 01 | 000 | XX | 01 |
TRX-B | 1200 – 1800 | 10 | 01 | 001 | 10 | XX |
TRX-B | 1800 – 2350 | 10 | 01 | 011 | 11 | XX |
TRX-B | 2350 – 2600 | 10 | 01 | 101 | 01 | XX |
TRX-B | 2600 – 6000 | 10 | 10 | XXX | XX | XX |
RX2-B | 70 – 450 | TT | 01 | 100 | XX | 10 |
RX2-B | 450 – 700 | TT | 01 | 010 | XX | 11 |
RX2-B | 700 – 1200 | TT | 01 | 000 | XX | 01 |
RX2-B | 1200 – 1800 | TT | 01 | 001 | 10 | XX |
RX2-B | 1800 – 2350 | TT | 01 | 011 | 11 | XX |
RX2-B | 2350 – 2600 | TT | 01 | 101 | 01 | XX |
RX2-B | >= 2600 | TT | 10 | XXX | XX | XX |
Transmit
TX Port | TX Filter (MHz) | VCTXRX1_V1,V2 | TX_ENABLE1A,1B | TX1_BANDSEL[2:0] |
TRX-B | < 117.7 | 00 | 01 | 111 |
TRX-B | 117.7 – 178.2 | 00 | 01 | 110 |
TRX-B | 178.2 – 284.3 | 00 | 01 | 101 |
TRX-B | 284.3 – 453.7 | 00 | 01 | 100 |
TRX-B | 453.7 – 723.8 | 00 | 01 | 011 |
TRX-B | 723.8 – 1154.9 | 00 | 01 | 010 |
TRX-B | 1154.9 – 1842.6 | 00 | 01 | 001 |
TRX-B | 1842.6 – 2940.0 | 00 | 01 | 000 |
TRX-B | >= 2940.0 | 11 | 10 | XXX |
Unlike the E31x, but like most other USRPs, the USRP E320 has separate inputs for clock and time reference. There is no separate internal 10 MHz oscillator, when selecting an 'internal' reference, the GPSDO is used to create reference signals.
To reduce phase noise, it may be necessary to power down the GPSDO when using an external reference. To do this, just add enable_gps=False
to args when connecting to the radio. Note that adding enable_gps
to args will override any enable_gps
value in the E320's MPM configuration (see Configuration Files).
The values 'internal' and 'gpsdo' are thus interchangeable and mean the same thing.
GPIO | Mini HDMI (Type C) | HDMI (Type A) |
Data[0] | Data 0+ - Pin 8 | Pin 7 |
Data[1] | Data 0- - Pin 9 | Pin 9 |
Data[2] | Clock 0+ - Pin 11 | Pin 10 |
Data[3] | Clock 0- - Pin 12 | Pin 12 |
Data[4] | CEC - Pin 14 | Pin 13 |
Data[5] | SCL - Pin 15 | Pin 15 |
Data[6] | SDA - Pin 16 | Pin 16 |
Data[7] | Utility - Pin 17 | Pin 14 |
EEPROM flags can be set with
$ eeprom-set-flags 0xFLAGS
Bit | Description |
0 | Auto-boot (1=on) |
1 | Fan (1=present) |
2 | TPM (0=present) |
3 | Enclosure (1=present) |
$ eeprom-set-flags 0x3
The enclosure flag is typically set during the manufacturing process, and can be used to identify if the board has an enclosure is used. The firmware and thermal subsystems of this device also use this flag to load different default thermal settings (see the SCU firmware code).
AXI Slave | Address Range | UIO Label | Description |
Slave 0 | 4000_0000 - 4000_3fff | - | Ethernet DMA SFP (only for E320) |
Slave 1 | 4000_4000 - 4000_4fff | misc-enet-regs | Ethernet registers SFP (only for E320) |
Slave 2 | 4001_0000 - 4001_3fff | mboard-regs | Motherboard control |
Slave 3 | 4001_4000 - 4001_41ff | dboard-regs | Daughterboard control |
AXI Slave | Module | Address | Name | Read/Write | Description |
Slave 0 | axi_eth_dma | 4000_0000 - 4000_4fff | Ethernet DMA | RW | See Linux Driver (only on E320) |
Slave 1 | e320_mgt_io_core | 4000_4000 | PORT_INFO | RO | SFP port information |
[31:24] | COMPAT_NUM | RO | - | ||
[23:18] | 6'h0 | RO | - | ||
[17] | activity | RO | - | ||
[16] | link_up | RO | - | ||
[15:8] | mgt_protocol | RO | 0 - None, 1 - 1G, 2 - XG, 3 - Aurora | ||
[7:0] | PORTNUM | RO | - | ||
e320_mgt_io_core | 4000_4004 | MAC_CTRL_STATUS | RW | Control 10gE and Aurora mac | |
[0] | ctrl_tx_enable (PROTOCOL = "10GbE") | RW | - | ||
[0] | bist_checker_en (PROTOCOL = "Aurora") | RW | - | ||
[1] | bist_gen_en | RW | - | ||
[2] | bist_loopback_en | RW | - | ||
[8:3] | bist_gen_rate | RW | - | ||
[9] | phy_areset | RW | - | ||
[10] | mac_clear | RW | - | ||
e320_mgt_io_core | 4000_4008 | PHY_CTRL_STATUS | RW | Phy reset control | |
e320_mgt_io_core | 4000_400C | MAC_LED_CTL | RW | Used by ethtool to indicate port | |
[1] | identify_enable | RW | - | ||
[0] | identify_value | RW | - | ||
mdio_master | 4000_4010 | MDIO_DATA | RW | - | |
4000_4014 | MDIO_ADDR | RW | - | ||
4000_4018 | MDIO_OP | RW | - | ||
4000_401C | MDIO_CTRL_STATUS | RW | - | ||
e320_mgt_io_core | 4000_4020 | AURORA_OVERUNS | RO | - | |
4000_4024 | AURORA_CHECKSUM_ERRORS | RO | - | ||
4000_4028 | AURORA_BIST_CHECKER_SAMPS | RO | - | ||
4000_402C | AURORA_BIST_CHECKER_ERRORS | RO | - | ||
eth_switch | 4000_5000 | MAC_LSB | RW | Device MAC LSB | |
4000_5004 | MAC_MSB | RW | Device MAC MSB | ||
4000_6000 | IP | RW | Device IP | ||
4000_6004 | PORT1, PORT0 | RW | Device UDP port | ||
eth_dispatch | 4000_6008 | [1] ndest, [0] bcast | RW | Enable Crossover | |
4000_600c | [1] my_icmp_type, [0] my_icmp_code | - | |||
eth_switch | 4000_6010 | BRIDGE_MAC_LSB | Bridge SFP ports in ARM | ||
4000_6014 | BRIDGE_MAC_MSB | - | |||
4000_6018 | BRIDGE_IP | - | |||
4000_601c | BRIDGE_PORT1, BRIDGE_PORT0 | - | |||
4000_6020 | BRIDGE_EN | - | |||
chdr_eth_framer | 4000_6108 onwards | LOCAL_DST_IP | W | Destination IP, MAC, UDP for Outgoing Packet for 256 SIDs | |
4000_6208 onwards | LOCAL_DST_UDP_MAC_MSB | W | Destination MAC for outgoing packets (MSB) | ||
4000_6308 onwards | LOCAL_DST_MAC_LSB | W | Destination MAC for outgoing packets (LSB) | ||
4000_7000 onwards | REMOTE_DST_IP | W | Destination IP, MAC, UDP for Outgoing Packet for 16 local addrs | ||
4000_7400 onwards | REMOTE_DST_UDP_MAC_HI | W | Destination MAC (MSB) | ||
4000_7800 onwards | REMOTE_DST_MAC_LO | W | Destination MAC (LSB) | ||
Slave 2 | e3xx_core | 4001_0000 | COMPAT_NUM | R | FPGA Compat Number |
[31:16] | Major | RO | - | ||
[15:0] | Minor | RO | - | ||
4001_0004 | DATESTAMP | RO | - | ||
4001_0008 | GIT_HASH | RO | - | ||
4001_000C | SCRATCH | RO | - | ||
4001_0010 | REG_DEVICE_ID | RW | RFNoC Device ID | ||
4001_0014 | REG_RFNOC_INFO | RO | RFNoC Information | ||
[31:16] | CHDR_W | RO | RFNoC CHDR Width in Bits | ||
[15:0] | RFNOC_PROTOVER | RO | RFNoC Protocol Version | ||
4001_0018 | CLOCK_CTRL | - | |||
[0] | pps select (internal 10 MHz) | RW | One-hot encoded pps_select to use the internal PPS from GPSDO | ||
[1] | pps select (external 10 MHz) | RW | One-hot encoded pps_select to use the external PPS. | ||
[2] | refclk_select (internal/external 10 MHz) | RW | refclk_select=0 for internal (GPSDO) 10 MHz, refclk_sel=1 for external 10 MHz. | ||
4001_001C | XADC_READBACK | RO | - | ||
[11:0] | FPGA temperature | RO | - | ||
4001_0020 | BUS_CLK_RATE | RO | - | ||
4001_0024 | BUS_CLK_COUNT | RO | - | ||
4001_0028 | SFP_PORT_INFO | RO | Same as port_info register 0x4000_4000 | ||
4001_002C | FP_GPIO_CTRL | RW | - | ||
4001_0030 | FP_GPIO_MASTER | RW | GPIO master select bits. One bit per GPIO. LSB is for GPIO 0. Set bit to 0 for Radio, 1 for PS. | ||
4001_0034 | FP_GPIO_RADIO_SRC | RW | Radio channel source select bits. Two bits per GPIO. Bits [1:0] are for GPIO 0. Set to 00 for channel 0, 01 for channel 1, etc. | ||
4001_0038 | GPS_CTRL | RW | E320 Only | ||
[0] | GPS_PWR_EN | RW | Power on GPSDO | ||
[1] | GPS_RST_N | RW | - | ||
[2] | GPS_INITSURV_N | RW | - | ||
4001_003C | GPS_STATUS | RO | GPSDO Status, E320 Only | ||
[0] | GPS_LOCK | RO | Returns 1 if GPSDO is locked | ||
[1] | GPS_ALARM | RO | - | ||
[2] | GPS_PHASELOCK | RO | - | ||
[3] | GPS_SURVEY | RO | - | ||
[4] | GPS_WARMUP | RO | - | ||
4001_0040 | DBOARD_CTRL | RO | - | ||
4001_0044 | DBOARD_STATUS | RO | - | ||
4001_0048 | NUM_TIMEKEEPERS | RO | Number of radio timekeepers | ||
Slave 4 | 4001_4000 | 4001_41FF | Daughterboard Registers | - | Don't exist now. TBD |
