176 virtual const T
get(
void)
const = 0;
195 template <
typename T>
223 typedef std::shared_ptr<property_tree>
sptr;
242 virtual std::vector<std::string>
list(
const fs_path& path)
const = 0;
245 template <
typename T>
249 template <
typename T>
253 template <
typename T>
254 std::shared_ptr<property<T>> pop(
const fs_path& path);
258 virtual std::shared_ptr<property_iface> _pop(
const fs_path& path) = 0;
261 virtual void _create(
262 const fs_path& path,
const std::shared_ptr<property_iface>& prop) = 0;
265 virtual std::shared_ptr<property_iface>& _access(
const = 0;
Definition: property_tree.hpp:25
virtual ~property_iface()=default
Definition: property_tree.hpp:221
Definition: property_tree.hpp:223
virtual std::vector< std::string > list(const fs_path &path) const =0
Get an iterable to all things in the given path.
virtual ~property_tree(void)=0
virtual void remove(const fs_path &path)=0
Remove a property or directory (recursive)
virtual sptr subtree(const fs_path &path) const =0
Get a subtree with a new root starting at path.
static sptr make(void)
Create a new + empty property tree.
virtual bool exists(const fs_path &path) const =0
True if the path exists in the tree.
coerce_mode_t
Definition: property_tree.hpp:225
@ AUTO_COERCE
Definition: property_tree.hpp:79
virtual property< T > & set_publisher(const publisher_type &publisher)=0
std::function< T(void)> publisher_type
Definition: property_tree.hpp:82
virtual property< T > & add_desired_subscriber(const subscriber_type &subscriber)=0
virtual const T get_desired(void) const =0
virtual bool empty(void) const =0
virtual property< T > & add_coerced_subscriber(const subscriber_type &subscriber)=0
virtual property< T > & set_coercer(const coercer_type &coercer)=0
virtual ~property(void)=0
Definition: property_tree.hpp:196
std::function< T(const T &)> coercer_type
Definition: property_tree.hpp:83
virtual property< T > & set_coerced(const T &value)=0
std::function< void(const T &)> subscriber_type
Definition: property_tree.hpp:81
virtual property< T > & update(void)=0
virtual const T get(void) const =0
virtual property< T > & set(const T &value)=0
#define UHD_API_HEADER
Definition: config.h:88
Definition: config.h:87
Definition: build_info.hpp:12
UHD_API fs_path operator/(const fs_path &, const fs_path &)
Definition: property_tree.hpp:206
UHD_API fs_path(const char *)
UHD_API std::string leaf(void) const
UHD_API fs_path branch_path(void) const
UHD_API fs_path(const std::string &)
