16 namespace uhd {
namespace rfnoc {
24 std::function<void(uint32_t, uint32_t)>
poke_fn;
25 std::function<uint32_t(uint32_t)>
peek_fn;
40 using sptr = std::shared_ptr<register_iface>;
53 std::function<bool(uint32_t addr,
const std::vector<uint32_t>& data)>;
66 uint32_t addr,
const std::vector<uint32_t>& data, boost::optional<uint64_t>)>;
83 bool ack =
false) = 0;
108 {uint32_t(data & 0xFFFFFFFF), uint32_t((data >> 32) & 0xFFFFFFFF)},
132 const std::vector<uint32_t> data,
134 bool ack =
false) = 0;
157 const std::vector<uint32_t> data,
159 bool ack =
false) = 0;
190 return uint64_t(vals[0]) | (uint64_t(vals[1]) << 32);
258 bool ack =
false) = 0;
339 const uint32_t length,
340 std::function<
void(uint32_t, uint32_t)> poke_fn,
341 std::function<uint32_t(uint32_t)> peek_fn) = 0;
Definition: register_iface.hpp:38
virtual void register_async_msg_handler(async_msg_callback_t callback_f)=0
virtual void block_poke32(uint32_t first_addr, const std::vector< uint32_t > data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
uint64_t peek64(uint32_t addr, time_spec_t time=uhd::time_spec_t::ASAP)
Definition: register_iface.hpp:187
std::shared_ptr< register_iface > sptr
Definition: register_iface.hpp:40
std::function< void(uint32_t addr, const std::vector< uint32_t > &data, boost::optional< uint64_t >)> async_msg_callback_t
Definition: register_iface.hpp:66
virtual void poll32(uint32_t addr, uint32_t data, uint32_t mask, time_spec_t timeout, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
virtual void multi_poke32(const std::vector< uint32_t > addrs, const std::vector< uint32_t > data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
virtual void register_async_msg_validator(async_msg_validator_t callback_f)=0
std::function< bool(uint32_t addr, const std::vector< uint32_t > &data)> async_msg_validator_t
Definition: register_iface.hpp:53
virtual uint16_t get_port_num() const =0
virtual std::vector< uint32_t > block_peek32(uint32_t first_addr, size_t length, time_spec_t time=uhd::time_spec_t::ASAP)=0
virtual ~register_iface()=default
virtual void set_policy(const std::string &name, const uhd::device_addr_t &args)=0
virtual uint32_t peek32(uint32_t addr, time_spec_t time=uhd::time_spec_t::ASAP)=0
virtual uint16_t get_src_epid() const =0
virtual void define_custom_register_space(const uint32_t start_addr, const uint32_t length, std::function< void(uint32_t, uint32_t)> poke_fn, std::function< uint32_t(uint32_t)> peek_fn)=0
void poke64(uint32_t addr, uint64_t data, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)
Definition: register_iface.hpp:102
virtual void sleep(time_spec_t duration, bool ack=false)=0
virtual void poke32(uint32_t addr, uint32_t data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
Definition: time_spec.hpp:31
static constexpr double ASAP
Definition: time_spec.hpp:34
Definition: soft_register.hpp:86
Definition: build_info.hpp:12
Definition: register_iface.hpp:22
Definition: register_iface.hpp:24
uint32_t end_addr
Definition: register_iface.hpp:23
Definition: register_iface.hpp:25
