41 const std::string& utrue,
42 const std::string& ufalse);
53 const std::string& unit,
54 const std::string& formatter =
"%d");
65 const std::string& unit,
66 const std::string& formatter =
"%f");
75 const std::string& name,
const std::string& value,
const std::string& unit);
123 enum data_type_t { BOOLEAN =
'b', INTEGER =
'i', REALNUM =
'r', STRING =
's' };
Definition: config.h:87
source
Identify the source of calibration data, i.e., where was it stored.
Definition: database.hpp:23
Definition: build_info.hpp:12
Definition: sensors.hpp:29
bool to_bool(void) const
convert the sensor value to a boolean
data_type_t
Enumeration of possible data types in a sensor.
Definition: sensors.hpp:123
signed to_int(void) const
convert the sensor value to an integer
double to_real(void) const
convert the sensor value to real number
sensor_value_t(const std::string &name, signed value, const std::string &unit, const std::string &formatter="%d")
std::map< std::string, std::string > sensor_map_t
Definition: sensors.hpp:30
sensor_value_t & operator=(const sensor_value_t &value)
Assignment operator for sensor value.
sensor_value_t(const std::string &name, const std::string &value, const std::string &unit)
sensor_value_t(const std::string &name, bool value, const std::string &utrue, const std::string &ufalse)
std::string value
Definition: sensors.hpp:113
sensor_value_t(const sensor_value_t &source)
sensor_map_t to_map(void) const
convert the sensor value to sensor_map_t
sensor_value_t(const std::string &name, double value, const std::string &unit, const std::string &formatter="%f")
std::string name
The name of the sensor value.
Definition: sensors.hpp:106
sensor_value_t(const std::map< std::string, std::string > &sensor_dict)
data_type_t type
The data type of the value.
Definition: sensors.hpp:126
std::string to_pp_string(void) const
Convert this sensor value into a printable string.
std::string unit
Definition: sensors.hpp:120
