12 #include <boost/detail/atomic_count.hpp>
13 #include <boost/intrusive_ptr.hpp>
14 #include <boost/utility.hpp>
17 namespace uhd {
namespace transport {
50 return static_cast<T
>(_buffer);
68 return boost::intrusive_ptr<T>(p);
72 typedef boost::intrusive_ptr<managed_buffer>
sptr;
76 return (
int)_ref_count;
105 typedef boost::intrusive_ptr<managed_recv_buffer>
sptr;
116 typedef boost::intrusive_ptr<managed_send_buffer>
sptr;
149 typedef std::shared_ptr<zero_copy_if>
sptr;
Definition: zero_copy.hpp:21
int ref_count()
Definition: zero_copy.hpp:74
UHD_INLINE void commit(size_t num_bytes)
Definition: zero_copy.hpp:38
boost::detail::atomic_count _ref_count
Definition: zero_copy.hpp:71
managed_buffer(void)
Definition: zero_copy.hpp:23
size_t _length
Definition: zero_copy.hpp:81
virtual ~managed_buffer(void)
Definition: zero_copy.hpp:25
UHD_INLINE size_t size(void) const
Definition: zero_copy.hpp:57
boost::intrusive_ptr< managed_buffer > sptr
Definition: zero_copy.hpp:72
void * _buffer
Definition: zero_copy.hpp:80
UHD_INLINE T cast(void) const
Definition: zero_copy.hpp:48
UHD_INLINE boost::intrusive_ptr< T > make(T *p, void *buffer, size_t length)
Definition: zero_copy.hpp:64
virtual void release(void)=0
Definition: zero_copy.hpp:103
boost::intrusive_ptr< managed_recv_buffer > sptr
Definition: zero_copy.hpp:105
Definition: zero_copy.hpp:114
boost::intrusive_ptr< managed_send_buffer > sptr
Definition: zero_copy.hpp:116
Definition: zero_copy.hpp:147
virtual managed_send_buffer::sptr get_send_buff(double timeout=0.1)=0
virtual size_t get_num_send_frames(void) const =0
virtual managed_recv_buffer::sptr get_recv_buff(double timeout=0.1)=0
std::shared_ptr< zero_copy_if > sptr
Definition: zero_copy.hpp:149
virtual size_t get_recv_frame_size(void) const =0
virtual size_t get_send_frame_size(void) const =0
virtual ~zero_copy_if()
Definition: zero_copy.hpp:154
virtual size_t get_num_recv_frames(void) const =0
#define UHD_INLINE
Definition: config.h:65
Definition: config.h:87
UHD_INLINE void intrusive_ptr_add_ref(managed_buffer *p)
Definition: zero_copy.hpp:86
UHD_INLINE void intrusive_ptr_release(managed_buffer *p)
Definition: zero_copy.hpp:91
Definition: build_info.hpp:12
Definition: zero_copy.hpp:123
size_t num_recv_frames
Definition: zero_copy.hpp:135
size_t recv_frame_size
Definition: zero_copy.hpp:133
size_t send_buff_size
Definition: zero_copy.hpp:138
size_t send_frame_size
Definition: zero_copy.hpp:134
size_t recv_buff_size
Definition: zero_copy.hpp:137
zero_copy_xport_params()
Definition: zero_copy.hpp:124
size_t num_send_frames
Definition: zero_copy.hpp:136
