Namespaces | |
| uhd | |
| uhd::build_info | |
Functions | |
| const UHD_API std::string | uhd::build_info::boost_version () |
| Return the version of Boost this build was built with.  More... | |
| const UHD_API std::string | uhd::build_info::build_date () |
| Return the date and time (GMT) this UHD build was built.  More... | |
| const UHD_API std::string | uhd::build_info::c_compiler () |
| Return the C compiler used for this build.  More... | |
| const UHD_API std::string | uhd::build_info::cxx_compiler () |
| Return the C++ compiler used for this build.  More... | |
| const UHD_API std::string | uhd::build_info::c_flags () |
| Return the C flags passed into this build.  More... | |
| const UHD_API std::string | uhd::build_info::cxx_flags () |
| Return the C++ flags passed into this build.  More... | |
| const UHD_API std::string | uhd::build_info::enabled_components () |
| Return the UHD components enabled for this build, comma-delimited.  More... | |
| const UHD_API std::string | uhd::build_info::install_prefix () |
| Return the default CMake install prefix for this build.  More... | |
| const UHD_API std::string | uhd::build_info::libusb_version () |
| Return the version of libusb this build was built with.  More... | |
| const UHD_API std::string | uhd::build_info::dpdk_version () |
| Return the version of DPDK this build was built with.  More... | |
| const UHD_API std::string | uhd::build_info::pkg_data_dir () |
| Return the value of PKG_DATA_DIR at build time (e.g., "share/uhd").  More... | |
