| using  | sptr = std::shared_ptr< noc_block_base > |
| using  | make_args_ptr = std::unique_ptr< make_args_t > |
|   | Opaque pointer to the constructor arguments.  More...
| enum   | forwarding_policy_t {
  forwarding_policy_t::ONE_TO_ONE,
forwarding_policy_t::ONE_TO_FAN,
forwarding_policy_t::ONE_TO_ALL_IN,
forwarding_policy_t::ONE_TO_ALL_OUT,
  forwarding_policy_t::ONE_TO_ALL,
forwarding_policy_t::DROP,
forwarding_policy_t::USE_MAP
|   | Types of property/action forwarding for those not defined by the block itself.  More...
| using  | resolver_fn_t = std::function< void(void)> |
| using  | resolve_callback_t = std::function< void(void)> |
| using  | graph_mutex_callback_t = std::function< std::recursive_mutex &(void)> |
| using  | action_handler_t = std::function< void(const res_source_info &, action_info::sptr)> |
| using  | forwarding_map_t = std::unordered_map< res_source_info, std::vector< res_source_info > > |
| using  | prop_ptrs_t = std::vector< property_base_t * > |
|   | noc_block_base (make_args_ptr make_args) |
| void  | set_num_input_ports (const size_t num_ports) |
| void  | set_num_output_ports (const size_t num_ports) |
| void  | set_tick_rate (const double tick_rate) |
| void  | set_mtu_forwarding_policy (const forwarding_policy_t policy) |
| void  | set_mtu (const res_source_info &edge, const size_t new_mtu) |
| property_base_t *  | get_mtu_prop_ref (const res_source_info &edge) |
| virtual void  | deinit () |
| void  | register_property (property_base_t *prop, resolve_callback_t &&clean_callback=nullptr) |
| void  | add_property_resolver (prop_ptrs_t &&inputs, prop_ptrs_t &&outputs, resolver_fn_t &&resolver_fn) |
| void  | set_prop_forwarding_policy (forwarding_policy_t policy, const std::string &prop_id="") |
| void  | set_prop_forwarding_map (const forwarding_map_t &map) |
| template<typename prop_data_t >  |
| void  | set_property (const std::string &id, const prop_data_t &val, const res_source_info &src_info) |
| const prop_data_t &  | get_property (const std::string &id, const res_source_info &src_info) |
| void  | register_action_handler (const std::string &id, action_handler_t &&handler) |
| void  | set_action_forwarding_policy (forwarding_policy_t policy, const std::string &action_key="") |
| void  | set_action_forwarding_map (const forwarding_map_t &map) |
| void  | post_action (const res_source_info &edge_info, action_info::sptr action) |
| virtual bool  | check_topology (const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs) |
| void  | update_reg_iface (register_iface::sptr new_iface=nullptr) |
| static dirtifier_t  | ALWAYS_DIRTY |
|   | A dirtifyer object, useful for properties that always need updating.  More...
Switchboard Block Control Class
The Switchboard Block is an RFNoC block that routes any single input to any single output. Routing is 1 to 1, that is, an input port can only be connected to one output port, and vice versa.
INIT: This block is initialized with only input port 0 connected to output port 0.
NOTE: This block is not intended to switch during the transmission of packets. Data on disconnected inputs will stall.
