uhd::utils::chdr::chdr_packet Class Reference
#include <uhd/utils/chdr/chdr_packet.hpp>
template<typename payload_t >
 chdr_packet (uhd::rfnoc::chdr_w_t chdr_w, uhd::rfnoc::chdr::chdr_header header, payload_t payload, boost::optional< uint64_t > timestamp=boost::none, std::vector< uint64_t > metadata={})
 chdr_packet (uhd::rfnoc::chdr_w_t chdr_w, uhd::rfnoc::chdr::chdr_header header, std::vector< uint8_t > payload_data, boost::optional< uint64_t > timestamp=boost::none, std::vector< uint64_t > mdata={})
uhd::rfnoc::chdr::chdr_header get_header () const
void set_header (uhd::rfnoc::chdr::chdr_header header)
boost::optional< uint64_t > get_timestamp () const
void set_timestamp (boost::optional< uint64_t > timestamp)
const std::vector< uint64_t > & get_metadata () const
void set_metadata (std::vector< uint64_t > metadata)
std::vector< uint8_t > serialize_to_byte_vector (endianness_t endianness=uhd::ENDIANNESS_LITTLE) const
template<typename OutputIterator >
void serialize (OutputIterator first, OutputIterator last, endianness_t endianness=uhd::ENDIANNESS_LITTLE) const
size_t get_packet_len () const
const std::vector< uint8_t > & get_payload_bytes () const
void set_payload_bytes (std::vector< uint8_t > bytes)
payload_t get_payload (uhd::endianness_t endianness=uhd::ENDIANNESS_LITTLE) const
void set_payload (payload_t payload, uhd::endianness_t endianness=uhd::ENDIANNESS_LITTLE)
std::string to_string () const
 Return a string representation of this object. More...
std::string to_string_with_payload (uhd::endianness_t endianness=uhd::ENDIANNESS_LITTLE) const
 Return a string representation of this object and deserialize its payload. More...
template<typename InputIterator >
static chdr_packet deserialize (uhd::rfnoc::chdr_w_t chdr_w, InputIterator first, InputIterator last, endianness_t endianness=uhd::ENDIANNESS_LITTLE)
A Generic class that represents a CHDR Packet
Whether the packet has a specific type of payload is not specified
◆ chdr_packet() [1/2]
uhd::utils::chdr::chdr_packet::chdr_packet ( uhd::rfnoc::chdr_w_t  chdr_w,
payload_t  payload,
boost::optional< uint64_t >  timestamp = boost::none,
std::vector< uint64_t >  metadata = {}
Constructs a CHDR Packet from a header and a payload
timestamp and metadata are optional and will be empty if omitted
◆ chdr_packet() [2/2]
std::vector< uint64_t >  mdata = {}
Construct a CHDR Packet from a header and raw payload words
◆ deserialize()
chdr_packet uhd::utils::chdr::chdr_packet::deserialize ( uhd::rfnoc::chdr_w_t  chdr_w,
InputIterator  last,
uhd::endianness_t  endianness = uhd::ENDIANNESS_LITTLE
Deserialize a CHDR Packet from a buffer of bytes
chdr_wthe CHDR_W of the incoming packet
endiannessthe endianness of the input buffer (link endianness)
firstthe start of the input buffer
lastthe end of the input buffer
a CHDR Packet with an unspecified payload type
◆ get_header()
uhd::rfnoc::chdr::chdr_header uhd::utils::chdr::chdr_packet::get_header ( ) const
Returns the contents of the CHDR header
The CHDR header
◆ get_metadata()
const std::vector<uint64_t>& uhd::utils::chdr::chdr_packet::get_metadata ( ) const
Returns a const reference to the metadata
The metadata reference
◆ get_packet_len()
size_t uhd::utils::chdr::chdr_packet::get_packet_len ( ) const
Get the total serialized length of the packet
The length of the packet in bytes
◆ get_payload()
payload_t uhd::utils::chdr::chdr_packet::get_payload ( uhd::endianness_t  endianness = uhd::ENDIANNESS_LITTLE) const
Parses the data out of this objects payload field into a payload_t object
endiannessThe link endianness of the CHDR Link
The parsed payload_t object
◆ get_payload_bytes()
const std::vector<uint8_t>& uhd::utils::chdr::chdr_packet::get_payload_bytes ( ) const
Returns a const reference to the payload bytes
The payload reference
◆ get_timestamp()
boost::optional<uint64_t> uhd::utils::chdr::chdr_packet::get_timestamp ( ) const
Returns the timestamp in the packet as an optional value
A boost::optional which if initialized has the timestamp
◆ serialize()
void uhd::utils::chdr::chdr_packet::serialize ( OutputIterator  first,
) const
Serialize a CHDR Packet into a buffer
endiannessthe endianness of the output buffer (link endianness)
firstthe start of the output buffer
lastthe end of the output buffer
◆ serialize_to_byte_vector()
std::vector<uint8_t> uhd::utils::chdr::chdr_packet::serialize_to_byte_vector ( endianness_t  endianness = uhd::ENDIANNESS_LITTLE) const
Serialize a CHDR Packet into a vector of bytes
endiannessthe endianness of the returned vector (link endianness)
a vector of bytes which represents the CHDR Packet in serialize form
◆ set_header()
void uhd::utils::chdr::chdr_packet::set_header ( uhd::rfnoc::chdr::chdr_header  header)
Change this object's header
headerThe new CHDR header
◆ set_metadata()
void uhd::utils::chdr::chdr_packet::set_metadata ( std::vector< uint64_t >  metadata)
Sets the metadata for a CHDR packet and updates the headers
metadataA vector containing the new metadata
◆ set_payload()
void uhd::utils::chdr::chdr_packet::set_payload ( payload_t  payload,
Serializes the payload object into bytes and stores it in this object's payload field
payloadthe payload object to store
◆ set_payload_bytes()
void uhd::utils::chdr::chdr_packet::set_payload_bytes ( std::vector< uint8_t >  bytes)
Sets the current payload
bytesthe payload to store inside this object (It is moved from)
◆ set_timestamp()
void uhd::utils::chdr::chdr_packet::set_timestamp ( boost::optional< uint64_t >  timestamp)
Sets the timestamp in the packet
timestampthe timestamp to set, or boost::none for no timestamp
◆ to_string()
std::string uhd::utils::chdr::chdr_packet::to_string ( ) const
◆ to_string_with_payload()
std::string uhd::utils::chdr::chdr_packet::to_string_with_payload ( uhd::endianness_t  endianness = uhd::ENDIANNESS_LITTLE) const
