#include <uhd/config.hpp>#include <uhd/types/ref_vector.hpp>#include <boost/operators.hpp>#include <cstddef>#include <functional>#include <memory>#include <string>Go to the source code of this file.
Classes | |
| class | uhd::convert::converter |
| A conversion class that implements a conversion from inputs -> outputs.  More... | |
| struct | uhd::convert::id_type |
| Identify a conversion routine in the registry.  More... | |
Namespaces | |
| uhd | |
| uhd::convert | |
Typedefs | |
| typedef std::function< converter::sptr(void)> | uhd::convert::function_type |
| Conversion factory function typedef.  More... | |
| typedef int | uhd::convert::priority_type |
| Priority of conversion routines.  More... | |
Functions | |
| UHD_API bool | uhd::convert::operator== (const id_type &, const id_type &) |
| Implement equality_comparable interface.  More... | |
| UHD_API void | uhd::convert::register_converter (const id_type &id, const function_type &fcn, const priority_type prio) |
| UHD_API function_type | uhd::convert::get_converter (const id_type &id, const priority_type prio=-1) |
| UHD_API void | uhd::convert::register_bytes_per_item (const std::string &format, const size_t size) |
| UHD_API size_t | uhd::convert::get_bytes_per_item (const std::string &format) |
| Convert an item format to a size in bytes.  More... | |
