Functions | |
| template<typename T > | |
| T | hexstr_cast (const std::string &in) |
| Convert a hexadecimal string into a value. More... | |
| T | fromstr_cast (const std::string &in) |
| template<typename data_t > | |
| data_t | from_str (const std::string &) |
| Generic cast-from-string function. More... | |
| template<> | |
| UHD_API bool | from_str (const std::string &val) |
Specialization of uhd::cast::from_str() for Boolean values. More... | |
| UHD_API std::string | to_ordinal_string (int val) |
| Create an ordinal string from a number. More... | |
| data_t uhd::cast::from_str | ( | const std::string & | ) |
| UHD_API std::string uhd::cast::from_str | ( | const std::string & | ) |
Specialization of uhd::cast::from_str() for strings.
Specialization of uhd::cast::from_str() for integer values.
Specialization of uhd::cast::from_str() for double-precision values.
inline |
Convert hexadecimal, decimal, octal or other strings that support the >> operator into a value depending on the prefix.
inline |
| UHD_API std::string uhd::cast::to_ordinal_string | ( | int | val | ) |
