registry.hpp
2 // Copyright 2019 Ettus Research, a National Instruments Brand
5 //
6
7 #pragma once
8
9 #include <uhd/config.hpp>
10 #include <uhd/rfnoc/defaults.hpp>
12 #include <uhd/utils/static.hpp>
13 #include <functional>
14 #include <string>
15
17 // after the class definition
18 #define UHD_RFNOC_BLOCK_REGISTER_FOR_DEVICE_DIRECT( \
19  CLASS_NAME, NOC_ID, DEVICE_ID, BLOCK_NAME, MB_ACCESS, TB_CLOCK, CTRL_CLOCK) \
20  uhd::rfnoc::noc_block_base::sptr CLASS_NAME##_make( \
21  uhd::rfnoc::noc_block_base::make_args_ptr make_args) \
22  { \
23  return std::make_shared<CLASS_NAME##_impl>(std::move(make_args)); \
24  } \
25  UHD_STATIC_BLOCK(register_rfnoc_##CLASS_NAME) \
26  { \
27  uhd::rfnoc::registry::register_block_direct(NOC_ID, \
28  DEVICE_ID, \
29  BLOCK_NAME, \
30  MB_ACCESS, \
31  TB_CLOCK, \
32  CTRL_CLOCK, \
33  &CLASS_NAME##_make); \
34  }
35
36 #define UHD_RFNOC_BLOCK_REGISTER_DIRECT( \
37  CLASS_NAME, NOC_ID, BLOCK_NAME, TB_CLOCK, CTRL_CLOCK) \
38  UHD_RFNOC_BLOCK_REGISTER_FOR_DEVICE_DIRECT( \
39  CLASS_NAME, NOC_ID, ANY_DEVICE, BLOCK_NAME, false, TB_CLOCK, CTRL_CLOCK)
40
41 #define UHD_RFNOC_BLOCK_REGISTER_DIRECT_MB_ACCESS( \
42  CLASS_NAME, NOC_ID, BLOCK_NAME, TB_CLOCK, CTRL_CLOCK) \
43  UHD_RFNOC_BLOCK_REGISTER_FOR_DEVICE_DIRECT( \
44  CLASS_NAME, NOC_ID, ANY_DEVICE, BLOCK_NAME, true, TB_CLOCK, CTRL_CLOCK)
45
46 namespace uhd { namespace rfnoc {
47
53 {
54 public:
56
87  static void register_block_direct(noc_id_t noc_id,
88  device_type_t device_id,
89  const std::string& block_name,
90  bool mb_access,
91  const std::string& timebase_clock,
92  const std::string& ctrlport_clock,
93  factory_t factory_fn);
94
97  static void register_block_direct(std::vector<noc_id_t> noc_ids,
98  device_type_t device_id,
99  const std::string& block_name,
100  bool mb_access,
101  const std::string& timebase_clock,
102  const std::string& ctrlport_clock,
103  factory_t factory_fn);
104
116  static void register_block_descriptor(
117  const std::string& block_key, factory_t factory_fn);
118 };
119
120 }} /* namespace uhd::rfnoc */
config.hpp
UHD_API
Definition: config.h:87
uhd
Definition: build_info.hpp:12
uhd::rfnoc::device_type_t
uint16_t device_type_t
Device Type.
Definition: defaults.hpp:56
noc_block_base.hpp
static.hpp
uhd::rfnoc::registry::factory_t
std::function< noc_block_base::sptr(noc_block_base::make_args_ptr)> factory_t
Definition: registry.hpp:55
Definition: noc_block_base.hpp:48
defaults.hpp
uhd::rfnoc::noc_id_t
uint32_t noc_id_t
Definition: defaults.hpp:52
std::unique_ptr< make_args_t > make_args_ptr
Opaque pointer to the constructor arguments.
Definition: noc_block_base.hpp:54
Definition: registry.hpp:52
