◆ UHD_SINGLETON_FCN
          | #define UHD_SINGLETON_FCN |
          _t,  |
          _x  |
Value:    static _t& _x()               \
        static _t _x;             \
        return _x;                \
Defines a function that implements the "construct on first use" idiom
- Parameters
    | _t | the type definition for the instance  |
    | _x | the name of the defined function  |
- Returns
 - a reference to the lazy instance
◆ UHD_STATIC_BLOCK
          | #define UHD_STATIC_BLOCK |
          _x | ) |
Value:    void _x(void);                                     \
    void _x(void)
Defines a static code block that will be called before main() The static block will catch and print exceptions to std error.
- Parameters
    | _x | the unique name of the fixture (unique per source)  |
