#include <uhd/stream.hpp>
Public Types | |
| typedef std::shared_ptr< rx_streamer > | sptr |
| typedef ref_vector< void * > | buffs_type |
| Typedef for a pointer to a single, or a collection of recv buffers. More... | |
| virtual | ~rx_streamer (void) |
| virtual size_t | get_num_channels (void) const =0 |
| Get the number of channels associated with this streamer. More... | |
| virtual size_t | get_max_num_samps (void) const =0 |
| Get the max number of samples per buffer per packet. More... | |
| virtual size_t | recv (const buffs_type &buffs, const size_t nsamps_per_buff, rx_metadata_t &metadata, const double timeout=0.1, const bool one_packet=false)=0 |
| virtual void | issue_stream_cmd (const stream_cmd_t &stream_cmd)=0 |
| virtual void | post_input_action (const std::shared_ptr< uhd::rfnoc::action_info > &action, const size_t port)=0 |
| typedef ref_vector<void*> uhd::rx_streamer::buffs_type |
| typedef std::shared_ptr<rx_streamer> uhd::rx_streamer::sptr |
virtual |
| stream_cmd | the stream command to issue |
Post an action to the input edge of the Streamer.
| action | shared pointer to the corresponding action_info request |
| port | the port to which to post the action |
Receive handles fragmentation as follows: If the buffer has insufficient space to hold all samples that were received in a single packet over-the-wire, then the buffer will be completely filled and the implementation will hold a pointer into the remaining portion of the packet. Subsequent calls will load from the remainder of the packet, and will flag the metadata to show that this is a fragment. The next call to receive, after the remainder becomes exhausted, will perform an over-the-wire receive as usual. See the rx metadata fragment flags and offset fields for details.
Note on threading: recv() is not thread-safe, to avoid locking overhead. The application calling recv() is responsible for making sure that not more than one thread can call recv() on the same streamer at the same time. If there are multiple streamers, receiving from different sources, then those may be called from different threads simultaneously.
metadata is a value that is set inside this function (effectively, a return value), and should be checked for potential error codes (see rx_metadata_t::error_code_t).
The most common error code when something goes wrong is an overrun (also referred to as overflow: error_code_t::ERROR_CODE_OVERFLOW). This error code means that the device produced data faster than the application could read, and various buffers filled up leaving no more space for the device to write data to. Note that an overrun on the device will not immediately show up when calling recv(). Depending on the device implementation, there may be many more valid samples available before the device had to stop writing samples to the FIFO. Only when all valid samples are returned to the call site will the error code be set to "overrun". When this happens, all valid samples have been returned to application where recv() was called. If the device is streaming continuously, it will reset itself when the FIFO is cleared, and recv() can be called again to retrieve new, valid data.
The recv() call has a timeout parameter. This parameter is used to limit the time the call will block. If no data is available within the timeout period, the call will return with an error code of error_code_t::ERROR_CODE_TIMEOUT. This is not necessarily an error condition, but can occur naturally, for example if the upstream source produces data in a bursty fashion.
An important fact about the timeout parameter is that it is not a total timeout value, but is applied to every single call within recv() that uses a timeout. This means that the total time recv() can block can be significantly larger than the timeout parameter passed to recv().
When the timeout is set to zero, recv() will attempt to return as fast as possible, to minimize latency. This is useful when the application polls for data in a busy loop. However, note that in this case, it is possible that the call will return with an error code of timeout, even though a different error condition occurred, but has not been fully processed. It is therefore not sufficient to call recv() with a timeout of zero to check for any outstanding error conditions.
It is not forbidden to call recv() with nsamps_per_buff = 0, and this can be useful to retrieve metadata only. In this case, the call will still apply the timeout value internally (which means the recv() call will wait at least for the timeout value for any incoming data, even though it won't be processed). However, the call will never return an error code of ERROR_CODE_TIMEOUT, as no data is expected to be processed.
The following code snippet demonstrates how to call recv() with a zero number of samples to retrieve metadata only:
| buffs | a vector of writable memory to fill with samples | |
| nsamps_per_buff | the size of each buffer in number of samples | |
| [out] | metadata | data to fill describing the buffer |
| timeout | the timeout in seconds to wait for a packet | |
| one_packet | return after the first packet is received |
