USRP Hardware Driver and USRP Manual  Version: 3.14.0.0.rc1-19-ga56185c6f
USRP N3xx Series
Comparative features list
  • Hardware Capabilities:
    • Dual SFP+ Transceivers (can be used with 1 GigE, 10 GigE, and Aurora)
    • External PPS input & output
    • External 10 MHz input & output (20 MHz and 25 MHz inputs also supported)
    • External White Rabbit time/frequency reference input support
    • Internal 25 MHz reference clock
    • Internal GPSDO for timing, location, and 20 MHz reference clock + PPS
    • External USB Connection for built-in JTAG debugger and serial console
    • Xilinx Zynq SoC with dual-core ARM Cortex A9 (Speedgrade 2) and Kintex-7 FPGA (XC7Z100 or XC7Z035 depending on variant)
  • Software Capabilities:
  • FPGA Capabilities:
    • Timed commands in FPGA
    • Timed sampling in FPGA
    • RFNoC capability
N310/N300 4-channel/2-channel Transceiver
N310 Exploded View
  • Supported master clock rates: 122.88 MHz, 125 MHz, 153.6 MHz
  • Tuning range: 10 MHz to 6 GHz (below 300 MHz, additional LOs and mixer stages are used to shift the signal into the frequency range of the AD9371)
  • Support for external LOs
  • 4 RX DDC chains in FPGA (2 for N300)
  • 4 TX DUC chain in FPGA (2 for N300)
  • 2 SFP+ connectors
N320/N321 2-channel Transceiver
  • Supported master clock rates: 200 MHz, 245.76 MHz, 250 MHz
  • Tuning range: 1 MHz to 6 GHz (below 450 MHz, an additional LO and mixer stage is used to shift the signal into the range of the main LO stage)
  • 2 RX DDC chains in FPGA
  • 2 TX DUC chain in FPGA
  • LO sharing between multiple devices (N321 only)
  • 2 SFP+ connectors + 1 QSFP+ connector
The Zynq CPU/FPGA and host operating system
The STM32 microcontroller
The SD card
  1. Boot partition (contains the bootloader). This partition usually does not require touching.
  2. A data partition, mounted in /data. This is the only partition that is not erased during file system updates.
  1. Two identical system partitions (root file systems). These contain the operating system and the home directory (anything mounted under / that is not the data or boot partition). The reason there are two of these is to enable remote updates: An update running on one partition can update the other one without any effect to the currently running system. Note that the system partitions are erased during updates and are thus unsuitable for permanently storing information.
$ mkdir temp
$ mount /dev/mmcblk0p3 temp
Getting started
Assembling the N3XX
Checklist:
  • Connect power and network
  • Read security settings
  • Connect clocking (if required)
  • Connect external LOs (if required)
Updating the file system
The image will be downloaded to <UHD_INSTALL_DIR>/share/uhd/images/usrp_n3xx_fs.sdimg, where <UHD_INSTALL_DIR> is the UHD installation directory.
The <YOUR_IMAGE> is the path to the micro SD card image (i.e.<UHD_INSTALL_DIR>/share/uhd/images/usrp_n3xx_fs.sdimg).
Serial connection
$ ls /dev/serial/by-id
usb-Digilent_Digilent_USB_Device_25163511FE00-if00-port0
usb-Digilent_Digilent_USB_Device_25163511FE00-if01-port0
usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if00-port0
usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if01-port0
Every N3XX series device connected to USB will by default show up as four different devices. The devices labeled "USB_to_UART_Bridge_Controller" are the devices that offer a serial prompt. The first (with the if00 suffix) connects to Linux, whereas the second connects to the STM32 microcontroller. If you have multiple N3XX devices connect, you may have to try out multiple devices. In this case, to use this symlink instead of the raw device node address, modify the command above to:
root@ni-n3xx-311FE00:~#
SSH connection
$ ssh root@ni-n3xx-311FE00.local
Note: The device's hostname is derived from its serial number by default (ni-n3xx-$SERIAL). You can change the hostname by modifying the /etc/hostname file and rebooting.
Network Connectivity
The SFP+ (sfp0, sfp1) ports are configured with static addresses 192.168.10.2/24 and 192.168.20.2/24, respectively. Their default MTU value is 8000. These settings are independent of the image type (HG vs. XG), i.e., the defaults are the same for 1 GigE and 10 GigE (unlike the X310!).
The configuration for the sfpX port is stored in /etc/systemd/network/sfpX.network.
eth0 (DHCP):
    [Match]
    Name=eth0
    [Network]
    DHCP=v4
    [DHCPv4]
    UseHostname=false
sfp0 (static):
    [Match]
    Name=sfp0
    [Network]
    Address=192.168.10.2/24
    [Link]
    MTUBytes=8000
sfp1 (static):
    [Match]
    Name=sfp1
    [Network]
    Address=192.168.20.2/24
    [Link]
    MTUBytes=8000
Security-related settings
The N3XX ships without a root password set. It is possible to ssh into the device by simply connecting as root, and thus gaining access to all subsystems. To set a password, run the command
$ passwd
on the device.
Updating the FPGA
Updating the FPGA follows the same procedure as other USRPs. Use the uhd_image_loader command line utility to upload a new FPGA image onto the device.
$ uhd_images_downloader
to update the FPGA using the default settings. If a custom FPGA image is targeted for uploading, use the --fpga-path command line argument. Run
$ uhd_image_loader --help
to see a full list of command line options. Note that updating the FPGA image will force a reload of the FPGA, which will temporarily take down the SFP network interfaces (and temporary settings, such as applied via ifconfig on the command line, will be lost).
Using an N3XX USRP from UHD
auto usrp = uhd::usrp::multi_usrp::make("type=n3xx");
Device arguments
Key Description Supported Devices Example Value
addr IPv4 address of primary SFP+ port to connect to. All N3xx addr=192.168.30.2
second_addr IPv4 address of secondary SFP+ port to connect to. All N3xx second_addr=192.168.40.2
mgmt_addr IPv4 address or hostname which to connect the RPC client. Defaults to `addr'.All N3xx mgmt_addr=ni-sulfur-311FE00 (can also go to RJ45)
find_all When using broadcast, find all devices, even if unreachable via CHDR. All N3xx find_all=1
force_reinit Force full reinitialization of all subsystems. Will increase init time. N310 force_reinit=1
master_clock_rate Master Clock Rate in Hz N310 master_clock_rate=125e6
identify Causes front-panel LEDs to blink. The duration is variable. N310 identify=5 (will blink for about 5 seconds)
serialize_init Force serial initialization of daughterboards. All N3xx serialize_init=1
skip_dram Ignore DRAM FIFO block. Connect TX streamers straight into DUC or radio. All N3xx skip_dram=1
skip_ddc Ignore DDC block. Connect Rx streamers straight into radio. All N3xx skip_ddc=1
skip_duc Ignore DUC block. Connect Rx streamers or DRAM straight into radio. All N3xx skip_duc=1
skip_init Skip the initialization process for the device. All N3xx skip_init=1
time_source Specify the time (PPS) source. All N3xx time_source=internal
clock_source Specify the reference clock source. All N3xx clock_source=internal
ref_clk_freq Specify the external reference clock frequency, default is 10 MHz. N310 ref_clk_freq=20e6
init_cals Specify the bitmask for initial calibrations of the RFIC. N310 init_cals=BASIC
init_cals_timeout Timeout for initial calibrations in milliseconds. N310 init_cals_timeout=45000
discovery_port Override default value for MPM discovery port. All N3xx discovery_port=49700
rpc_port Override default value for MPM RPC port. All N3xx rpc_port=49701
tracking_cals Specify the bitmask for tracking calibrations of the RFIC. N310 tracking_cals=ALL
rx_lo_source Initialize the source for the RX LO. N310 rx_lo_source=external
tx_lo_source Initialize the source for the TX LO. N310 tx_lo_source=external
rfic_digital_loopback Digital data loopback inside the RFIC. N310 rfic_digital_loopback=1
Device Initialization
To maximally speed up UHD, an initialization sequence is run when the device (or more accurately, the MPM service) starts. This means even on the first run of UHD, the device will already be initialized into a usable state. Note that it will always come up in a default state, which can be changed by modifying the configuration file in /etc/uhd/mpm.conf (see also Configuration Files), such as this:
; Note: To boot into a fully initialized state, a clock reference must be
; connected before turning the device on if it set to external here:
[n3xx]
clock_source=external
If you prefer not to have the device initialize on boot, but rather have a fast boot time, add the line skip_boot_init=1 to your /etc/uhd/mpm.conf file.
Subdev Specifications
Label Subdev Spec
RF0 A:0
RF1 A:1
RF2 B:0 (N310 only)
RF3 B:1 (N310 only)
Label Subdev Spec
RF0 A:0
RF1 B:0
auto usrp = uhd::usrp::multi_usrp("type=n3xx");
usrp->set_rx_subdev_spec("A:0 B:1");
// This line will now set the gain for RF3 to 20.0:
usrp->set_rx_gain(20.0, 1);
// And this will affect RF0:
usrp->set_rx_gain(20.0, 0);
The sensor API
  • ref_locked: This will check that all the daughterboards have locked to the external reference.
  • temperature: The temperature of the die itself
  • gps_lock: GPS lock
  • gps_time: GPS time in seconds sin ce the epch
  • gps_tpv: A TPV report from GPSd serialized as JSON
  • gps_sky: A SKY report from GPSd serialized as JSON
Remote Management
Mender: Remote update capability
$ mender -rootfs /path/to/latest.mender
$ mender -rootfs http://server.name/path/to/latest.mender
$ reboot
$ mender -commit
If you are running a hosted server, the updates can be initiated from a web dashboard. From there, you can start the updates without having to log into the device, and can update groups of USRPs with a few clicks in a web GUI. The dashboard can also be used to inspect the state of USRPs. This is simple way to update groups of rack-mounted USRPs with custom file systems.
Salt: Remote configuration management and execution
$ systemctl start salt-minion
  1. Install the salt-master package on the server (e.g. by running apt install salt-master if the server is an Ubuntu system), and make sure the Salt master is running.
  2. Add the network address / hostname of that server to the /etc/salt/minion file on the device by editing the master: line.
  3. Launch the Salt minion on the USRP by running the command systemctl start salt-minion.
  4. The minion will try to connect to the master. You need to authorize the minion by running salt-key -a $hostname where $hostname is the name of the minion.
  5. Once the device is authorized, you can try various commands to see if the communication was established:
$ [sudo] salt '*' test.ping
ni-n3xx-311FE00:
    True
ni-n3xx-311FE00:
    eth0:
        hwaddr:
            02:00:03:11:fe:00
        inet:
            |_
              address:
                  10.16.32.113
              broadcast:
                  10.16.33.255
              label:
                  eth0
              netmask:
                  255.255.254.0
        up:
            True
Clock/Time Synchronization
Internal references
The N3xx series has an onboard GPSDO as well as a 25 MHz reference oscillator, which can both be used as time- and clock references. The GPSDO will function as a reference even when there is no GPS reception.
External references
"type=n3xx,clock_source=external,time_source=external");
White Rabbit
Then, you can install the WX (or WA) image using uhd_image_loader:
$ uhd_image_loader \
    --args type=n3xx,addr=ni-n3xx-<DEVICE_SERIAL>,WX
Once the image is loaded, select internal as the clock source and sfp0 as the time source (note: this will fail if the WX or WA image is not currently loaded):
"type=n3xx,clock_source=internal,time_source=sfp0");
// Or if you want to change it to White Rabbit after initialization:
usrp->set_sync_source(device_addr_t("clock_source=internal,time_source=sfp0"));
// Using the older time/clock source APIs is also possible:
usrp->set_time_source("sfp0");
usrp->set_clock_source("internal");
// The 2nd call can technically be skipped because the device implementations
// will coerce, but for consistency with other code and for being explicit this
// is the preferred way. The 2nd call will immediately return in this case.
Troubleshooting
Errors while streaming
The default MTU for the N3x0 series is 8000. The simplest solution is often to set the host computer MTU to 8000 as well:
$ [sudo] ifconfig eth0 mtu 8000 # Replace eth0 with the device you're using
Theory of Operation
Building custom filesystems and SD card images
Using Docker to build filesystems
Ettus Research provides a Docker containers to facilitate building filesystems. Using Docker hub, the container can be downloaded by running
$ docker pull ettusresearch/oe-build
Then, navigate to a location with enough disk space:
$ cd $BUILDDIR
Create a world-writable directory called 'build':
$ mkdir build && chmod 777 build
Then run the Docker container:
$ docker run -i -t -v $(pwd)/build:/home/oe-builder/build:rw,z ettusresearch/oe-build /bin/bash
Note the order of the naming above might vary by docker version, sometimes it might need to be:
$ docker run -i -t ettusresearch/oe-build -v $(pwd)/build:/home/oe-builder/build:rw,z /bin/bash
After running the previous command, you will be inside the container. First, configure your build environment:
$ TEMPLATECONF=$(pwd)/meta-ettus/conf/sulfur source ./oe-core/oe-init-build-env ./build ./bitbake
Then, you can invoke bitbake to build the image:
$ bitbake $image_name
where $image_name could be developer_image or deployment_image. If you want to build the SDK, append -cpopulate_sdk to the above line.
If you keep the build directory, bitbake will reuse it on consecutive runs, which will speed up builds significantly between runs.
This step will build the SDK, the SD card image, and the Mender artefact.
Modifying and compiling UHD and MPM for the N3XX
Compiling MPM natively
$ mkdir uhd # Create a new, empty directory called uhd
$ sshfs user@yourcomputer:src/uhd uhd # This will mount ~/src/uhd from the remote machine to ~/uhd on the N3xx
$ mkdir build_mpm
$ cd build_mpm # You are now in /home/root/build_mpm
$ cmake ../uhd/mpm
$ make -j2 install # This will take several minutes
Obtaining an SDK
$ cd /usr/local/share/uhd/images # Change this to where your images are stored
$ ./oecore-x86_64-cortexa9hf-neon-toolchain-nodistro.0.sh
This will prompt you for an installation path. Please ensure you have sufficient disk space, as each of the SDKs may require several gigabytes of disk space (depending on the image flavor selected).
SDK Usage
$ $CC -dumpmachine
Building UHD
  2. Set up your environment as described in SDK Usage
     $ cmake -DCMAKE_TOOLCHAIN_FILE=../host/cmake/Toolchains/oe-sdk_cross.cmake -DCMAKE_INSTALL_PREFIX=/usr .. # Add any CMake options you desire
     $ make # You can run make -j12 to compile on 12 processes at once
Note: The UHD you are cross-compiling will not run on your host computer (the one where you're doing the development). Compiling UHD regularly on your host computer (with MPMD enabled) will allow you to talk to your N3xx.
Building GNU Radio
  1. Obtain the GNU Radio source code via git or tarball
$ mkdir build-arm
$ cd build-arm
-DENABLE_GR_DTV=OFF -DENABLE_DOXYGEN=OFF ../ # Append any CMake options you desire
N310-specific Features
Front and Rear Panel
  • LINK: This LED will be lit when this USRP has been claimed by a UHD session.
  • REF: Indicates a lock to the reference clock. In particular, when using an external reference clock, this LED is useful to see if the LMK04828 PLLs are locking to this reference clock. Note that some software interaction is necessary to enable the LMK04828, and thus this LED may be off even if a valid reference clock signal is connected.
  • GPS: Indicates a GPS lock (i.e., GPS satellites are in view of the GPS antenna and signal levels are sufficient)
  • PPS: This LED will blink once every second to indicate a valid PPS signal.
N310 Rear Panel
N310 Front Panel
Device Initialization (Fast and Slow)
  • All clocking is initialized
  • The JESD links are trained and brought up (between the FPGA and the AD9371)
  • The AD9371 is reset, its firmware is uploaded, and calibrations are initialized (See also RF Calibrations)
  • N310 only: The multi-chip synchronization is performed to align all the RFICs to the common time and clock reference
This sequence can take a while, depending on the master clock rate and the calibration sequence. To speed things up, the device will retain a state between sessions, but only if no relevant settings were touched. In particular, changing the master clock rate, the clock source, or the calibration masks will force a full re-initialization which is very slow compared to the fast re-initialization. By setting the log level to DEBUG you will be able to observe the exact settings that cause fast vs. slow re-initialization. If you require a full re-initialization every time a UHD session is spawned, specify the force_reinit flag as a device arg. Specifying it will always do the full, slow initialization, but will guarantee a full reset of the RFIC.
[n3xx]
master_clock_rate=122.88e6
RF Calibrations
Not all calibrations available on the AD9371 are applicable to the USRP N310. However, those calibrations that are applicable can be enabled/disabled at initialization time using the tracking_cals and init_cals device args (see also Device arguments). These device can be set to the precise bit mask the chip uses to set those calibrations (e.g., init_cals=0x4DFF,tracking_cals=0xC3) or they can use the following descriptive keys provided by UHD (e.g.init_cals=DEFAULT,tracking_cals=TX_QEC|RX_QEC). The | symbol can be used to combine keys (equivalent to a bitwise OR).
Key (init_cal) Function
TX_BB_FILTER Tx baseband filter calibration
ADC_TUNER ADC tuner calibration
TIA_3DB_CORNER Rx TIA filter calibration
DC_OFFSET Rx DC offset calibration
TX_ATTENUATION_DELAY Tx attenuation delay
RX_GAIN_DELAY Rx gain delay calibration
FLASH_CAL ADC flash calibration
PATH_DELAY Path delay calibration
TX_LO_LEAKAGE_INTERNAL Tx LO leakage internal initial calibration
TX_LO_LEAKAGE_EXTERNAL Tx LO leakage external initial calibration (requires external LO)
TX_QEC_INIT Tx QEC initial
LOOPBACK_RX_LO_DELAY Loopback ORx LO delay (ORx not connected by default!)
LOOPBACK_RX_RX_QEC_INIT Loopback Rx QEC initial calibration
RX_LO_DELAY Rx LO delay
RX_QEC_INIT Rx QEC initial calibration
BASIC Preset for minimal calibrations (TX_BB_FILTER, ADC_TUNER, TIA_3DB_CORNER, DC_OFFSET and FLASH_CAL)
OFF Preset for disabling all initial calibrations
DEFAULT Preset for enabling most calibrations (BASIC plus TX_ATTENUATION_DELAY, RX_GAIN_DELAY, PATH_DELAY, RX_QEC_INIT, TX_LO_LEAKAGE_INTERNAL, TX_QEC_INIT, LOOPBACK_RX_LO_DELAY)
ALL Enable all applicable calibrations
Key (tracking_cal) Function
TRACK_RX1_QEC Rx1 QEC tracking
TRACK_RX2_QEC Rx2 QEC tracking
TRACK_ORX1_QEC ORx1 QEC tracking
TRACK_ORX2_QEC ORx1 QEC tracking
TRACK_TX1_LOL Tx1 LO leakage tracking
TRACK_TX2_LOL Tx2 LO leakage tracking
TRACK_TX1_QEC Tx1 QEC tracking
TRACK_TX2_QEC Tx2 QEC tracking
OFF Disable all tracking
RX_QEC Enable all RX QEC tracking
TX_QEC Enable all TX QEC tracking
TX_LOL Enable all TX LO leakage tracking
DEFAULT Enable all QEC tracking
ALL Enable all tracking (except ORx)
External LOs
  • Improving phase alignment: The N310 itself has no way of aligning phase between channels, and phase will be random between runs. By applying an external LO, the phase ambiguity is reduced to 180 degrees, produced by a by-2 divider in the AD9371 transceiver IC.
  • Improving phase noise: The quality of the onboard LO depends on the external reference clock, among other things. By providing a custom LO signal, it is possible to more accurately tune, assuming the externally generated LO signal is coming from a high-quality oscillator.
Storing user data in the EEPROM
FPGA Register Map
AXI Slave Address Range UIO Label Description
Slave 0 4000_0000 - 4000_3fff - Ethernet DMA SFP0
Slave 1 4000_4000 - 4000_4fff misc-enet-regs0 Ethernet registers SFP0
Slave 2 4000_8000 - 4000_bfff - Ethernet DMA SFP1
Slave 3 4000_c000 - 4000_cfff misc-enet-regs1 Ethernet registers SFP1
Slave 4 4001_0000 - 4001_3fff mboard-regs Motherboard control
Slave 5 4001_4000 - 4001_41ff dboard-regs0 Daughterboard control, slot A
Slave 6 4001_8000 - 4001_bfff dboard-regs1 Daughterboard control, slot B
N310 Register Map
AXI Slave Module Address Name Read/Write Description
Slave 0 axi_eth_dma0 4000_0000 - 4000_4fff Ethernet DMA RW See Linux Driver
Slave 1 n3xx_mgt_io_core 4000_4000 PORT_INFO RO SFP port information
[31:24] COMPAT_NUM RO -
[23:18] 6'h0 RO -
[17] activity RO -
[16] link_up RO -
[15:8] mgt_protocol RO 0 - None, 1 - 1G, 2 - XG, 3 - Aurora
[7:0] PORTNUM RO -
n3xx_mgt_io_core 4000_4004 MAC_CTRL_STATUS RW Control 10gE and Aurora mac
[0] ctrl_tx_enable (PROTOCOL = "10GbE")RW-
[0] bist_checker_en (PROTOCOL = "Aurora")RW-
[1] bist_gen_en RW -
[2] bist_loopback_enRW -
[8:3] bist_gen_rate RW -
[9] phy_areset RW -
[10] mac_clear RW -
n3xx_mgt_io_core 4000_4008 PHY_CTRL_STATUS RW Phy reset control
n3xx_mgt_io_core 4000_400C MAC_LED_CTL RW Used by ethtool to indicate port
[1] identify_enable RW -
[0] identify_value RW -
mdio_master 4000_4010 MDIO_DATA RW -
4000_4014 MDIO_ADDR RW -
4000_4018 MDIO_OP RW -
4000_401C MDIO_CTRL_STATUSRW -
n3xx_mgt_io_core 4000_4020 AURORA_OVERUNS RO -
4000_4024 AURORA_CHECKSUM_ERRORSRO -
4000_4028 AURORA_BIST_CHECKER_SAMPSRO -
4000_402C AURORA_BIST_CHECKER_ERRORSRO-
eth_switch 4000_5000 MAC_LSB RW Device MAC LSB
4000_5004 MAC_MSB RW Device MAC MSB
4000_6000 IP RW Device IP
4000_6004 PORT1, PORT0 RW Device UDP port
eth_dispatch 4000_6008 [1] ndest, [0] bcastRW Enable Crossover
4000_600c [1] my_icmp_type, [0] my_icmp_code
eth_switch 4000_6010 BRIDGE_MAC_LSB Bridge SFP ports in ARM
4000_6014 BRIDGE_MAC_MSB -
4000_6018 BRIDGE_IP -
4000_601c BRIDGE_PORT1, BRIDGE_PORT0-
4000_6020 BRIDGE_EN -
chdr_eth_framer 4000_6108 onwards LOCAL_DST_IP W Destination IP, MAC, UDP for Outgoing Packet for 256 SIDs
4000_6208 onwards LOCAL_DST_UDP_MAC_MSBW Destination MAC for outgoing packets (MSB)
4000_6308 onwards LOCAL_DST_MAC_LSBW Destination MAC for outgoing packets (LSB)
4000_7000 onwards REMOTE_DST_IP W Destination IP, MAC, UDP for Outgoing Packet for 16 local addrs
4000_7400 onwards REMOTE_DST_UDP_MAC_HIW Destination MAC (MSB)
4000_7800 onwards REMOTE_DST_MAC_LOW
Destination MAC (LSB)
Slave 2 axi_eth_dma1 4000_8000 -
Same as Slave 0, different base address
Slave 3 n3xx_mgt_io_core 4000_c001 - 4000_cfff - - Same as Slave 1, different base address
eth_dispatch 4000_d000 - 4000_dfff - - Same as Slave 1, different base address
eth_switch 4000_e000 - 4000_efff - -
Slave 4 n310_core 4001_0000 COMPAT_NUM R FPGA Compat Number
[31:16] Major RO -
[15:0] Minor RO -
4001_0004 DATESTAMP RO -
4001_0008 GIT_HASH RO -
4001_000C SCRATCH RO -
4001_0010 NUM_CE RO Number of Computation Engines (RFNoC Blocks)
4001_0014 NUM_IO_CE RO Number of fixed IO CEs - Radios + DMA Fifo
4001_0018 CLOCK_CTRL
[0] pps select (internal 10 MHz)RWOne-hot encoded pps_select to use the external PPS input.
[1] pps select (internal 25 MHz)RWOne-hot encoded pps_select to use the internally generated PPS with a 10 MHz ref_clk.
[2] pps select (external)RW One-hot encoded pps_select to use the internally generated PPS with a 25 MHz ref_clk.
[3] pps select (GPSDO)RW One-hot encoded pps_select to use the PPS from the GPSDO input to the FPGA.
[4] pps output enableRW
[8] ref clk mmcm resetWO -
[9] ref clk mmcm lockedRO -
[12] meas clk mmcm resetWO -
[13] meas clk mmcm lockedRO -
4001_001C XADC_READBACK RO -
[11:0] FPGA temperatureRO
4001_0020 BUS_CLK_RATE RO -
4001_0024 BUS_CLK_COUNT RO -
axi_crossbar 4001_1010 XBAR_VERSION RO See crossbar kernel driver
4001_1014 XBAR_NUM_PORTS RO See crossbar kernel driver
4001_1018 LOCAL_ADDR RW See crossbar kernel driver
4001_1020 remote_offset WO XBAR settings reg
4001_1420 local_offset WO XBAR settings reg
n3xx_mgt_io_core (NPIO0) 4001_0200 PORT_INFO RO
4001_0204 MAC_CTRL_STATUS RW
4001_0208 PHY_CTRL_STATUS RW
4001_0220 AURORA_OVERUNS RO
4001_0224 AURORA_CHECKSUM_ERRORSRO
4001_0228 AURORA_BIST_CHECKER_SAMPSRO
4001_022c AURORA_BIST_CHECKER_ERRORSRO
n3xx_mgt_io_core (NPIO1) 4001_0240 PORT_INFO RO
4001_0244 MAC_CTRL_STATUS RW
4001_0248 PHY_CTRL_STATUS RW
4001_0260 AURORA_OVERUNS RO
4001_0264 AURORA_CHECKSUM_ERRORSRO
4001_0268 AURORA_BIST_CHECKER_SAMPSRO
4001_026c AURORA_BIST_CHECKER_ERRORSRO
n3xx_mgt_io_core (QSFP0) 4001_0280 PORT_INFORO
4001_0284 MAC_CTRL_STATUSRW
4001_0288 PHY_CTRL_STATUSRW
4001_02a0 AURORA_OVERUNSRO
4001_02a4 AURORA_CHECKSUM_ERRORSRO
4001_02a8 AURORA_BIST_CHECKER_SAMPSRO
4001_02ac AURORA_BIST_CHECKER_ERRORSRO
n3xx_mgt_io_core (QSFP1) 4001_02c0 PORT_INFORO
4001_02c4 MAC_CTRL_STATUSRW
4001_02c8 PHY_CTRL_STATUSRW
4001_02e0 AURORA_OVERUNSRO
4001_02e4 AURORA_CHECKSUM_ERRORSRO
4001_02e8 AURORA_BIST_CHECKER_SAMPSRO
4001_02ec AURORA_BIST_CHECKER_ERRORSRO
n3xx_mgt_io_core (QSFP2) 4001_0300 PORT_INFORO
4001_0304 MAC_CTRL_STATUSRW
4001_0308 PHY_CTRL_STATUSRW
4001_0320 AURORA_OVERUNSRO
4001_0324 AURORA_CHECKSUM_ERRORSRO
4001_0328 AURORA_BIST_CHECKER_SAMPSRO
4001_032c AURORA_BIST_CHECKER_ERRORSRO
n3xx_mgt_io_core (QSFP3) 4001_0340 PORT_INFORO
4001_0344 MAC_CTRL_STATUSRW
4001_0348 PHY_CTRL_STATUSRW
4001_0360 AURORA_OVERUNSRO
4001_0364 AURORA_CHECKSUM_ERRORSRO
4001_0368 AURORA_BIST_CHECKER_SAMPSRO
4001_036C AURORA_BIST_CHECKER_ERRORSRO
Slave 5 4001_40004001_41FFClockingsee Clocking regmap
4001_42004001_43FFSyncsee Sync regmap
4001_44004001_45FFopenopenopen
4001_46004001_47FFDaughterboard see Daughterboard regmap (EISCAT)
4001_60004001_6FFFJESD Core 0see JESD regmap (EISCAT)
4001_70004001_7FFFJESD Core 1see JESD regmap (EISCAT)
Slave 6 4001_8000 - 4001_bfff see above -same as Slave 5
N32x-specific Features
N320 Rear Panel
N321 Rear Panel
N320 Front Panel
N321 Front Panel
  • The JESD links are trained and brought up (between the FPGA and the ADC/DAC)
This sequence can take a while, depending on the master clock rate and the calibration sequence. To speed things up, the device will retain a state between sessions, but only if no relevant settings were touched. In particular, changing the master clock rate or the clock source will force a full re-initialization which is slower compared to the fast re-initialization. By setting the log level to DEBUG you will be able to observe the exact settings that cause fast vs. slow re-initialization. If you require a full re-initialization every time a UHD session is spawned, specify the force_reinit flag as a device arg. Specifying it will always do the full, slow initialization, but will guarantee a full reset digital chains.
[n3xx]
master_clock_rate=200e6
RF Calibrations
The N320/N321 can perform some simple calibration for I/Q imbalance and DC offset, the same way as the X300 series. Refer to Device Calibration for more details.
External LOs
N321 LO Distribution Board
N321 LO Distribution Diagram
N320/N321 LO Sharing
N321 16 Channel LO Sharing
SFP+ and QSFP+ protocols
Interface HG XG XQ AQ
SFP+ 0 1 GbE 10 GbE White Rabbit 10 GbE
SFP+ 1 10 GbE 10 GbE Unused 10 GbE
QSFP+ lane 0 Unused Unused 10 GbE Aurora
QSFP+ lane 1 Unused Unused 10 GbE Aurora
QSFP+ lane 2 Unused Unused Unused Aurora
QSFP+ lane 3 Unused Unused Unused Aurora
