uhd::rfnoc::chdr::mgmt_hop_t Class Reference
A class that represents a single management hop. More...
A hop is a collection for management transactions for a single node.
 mgmt_hop_t ()=default
 mgmt_hop_t (const mgmt_hop_t &rhs)=default
void add_op (const mgmt_op_t &op)
 Add a management operation to this hop. More...
size_t get_num_ops () const
 Get the number of management operations in this hop. More...
const mgmt_op_t & get_op (size_t i) const
 Get the n'th operation in the hop. More...
size_t serialize (std::vector< uint64_t > &target, const std::function< uint64_t(uint64_t)> &conv_byte_order, const size_t padding_size) const
 Serialize the payload to a uint64_t buffer. More...
void deserialize (std::list< uint64_t > &src, const std::function< uint64_t(uint64_t)> &conv_byte_order, const size_t padding_size)
 Deserialize the payload from a uint64_t buffer. More...
bool operator== (const mgmt_hop_t &rhs) const
 Comparison operator (==) More...
std::string to_string () const
 Return a string representation of this object. More...
◆ mgmt_hop_t() [1/2]
uhd::rfnoc::chdr::mgmt_hop_t::mgmt_hop_t ( )
default
◆ mgmt_hop_t() [2/2]
uhd::rfnoc::chdr::mgmt_hop_t::mgmt_hop_t ( const mgmt_hop_t &  rhs)
default
◆ add_op()
void uhd::rfnoc::chdr::mgmt_hop_t::add_op ( const mgmt_op_t &  op)
Operations are added to the hop in FIFO order and executed in FIFO order.
◆ deserialize()
void uhd::rfnoc::chdr::mgmt_hop_t::deserialize ( std::list< uint64_t > &  src,
const std::function< uint64_t(uint64_t)> &  conv_byte_order,
The RFNoC Specification section 2.2.6 specifies that for chdr widths greater than 64, all MSBs are 0, so we remove padding based on the width
◆ get_num_ops()
size_t uhd::rfnoc::chdr::mgmt_hop_t::get_num_ops ( ) const
◆ get_op()
const mgmt_op_t& uhd::rfnoc::chdr::mgmt_hop_t::get_op ( size_t  i) const
◆ operator==()
bool uhd::rfnoc::chdr::mgmt_hop_t::operator== ( const mgmt_hop_t &  rhs) const
◆ serialize()
size_t uhd::rfnoc::chdr::mgmt_hop_t::serialize ( std::vector< uint64_t > &  target,
) const
The RFNoC Specification section 2.2.6 specifies that for chdr widths greater than 64, all MSBs are 0, so we pad out the hop based on the width
◆ to_string()
std::string uhd::rfnoc::chdr::mgmt_hop_t::to_string ( ) const
