uhd::rfnoc::chdr::strs_payload Class Reference
 strs_payload ()=default
 strs_payload (const strs_payload &rhs)=default
 strs_payload (strs_payload &&rhs)=default
strs_payload & operator= (const strs_payload &rhs)=default
void populate_header (chdr_header &header) const
 Populate the header for this type of packet. More...
size_t serialize (uint64_t *buff, size_t max_size_bytes, const std::function< uint64_t(uint64_t)> &conv_byte_order) const
 Serialize the payload to a uint64_t buffer. More...
size_t serialize (uint64_t *buff, size_t max_size_bytes) const
 Serialize the payload to a uint64_t buffer (no conversion function) More...
void deserialize (const uint64_t *buff, size_t buff_size, const std::function< uint64_t(uint64_t)> &conv_byte_order)
 Deserialize the payload from a uint64_t buffer. More...
void deserialize (const uint64_t *buff, size_t buff_size)
 Deserialize the payload from a uint64_t buffer (no conversion function). More...
size_t get_length () const
 Get the serialized size of this payload in 64 bit words. More...
bool operator== (const strs_payload &rhs) const
 Comparison operator (==) More...
bool operator!= (const strs_payload &rhs) const
 Comparison operator (!=) More...
std::string to_string () const
 Return a string representation of this object. More...
Public Attributes
uint16_t src_epid = 0
 The source EPID for the stream (16 bits) More...
strs_status_t status = STRS_OKAY
 The status of the stream (4 bits) More...
uint64_t capacity_bytes = 0
 Buffer capacity in bytes (40 bits) More...
uint32_t capacity_pkts = 0
 Buffer capacity in packets (24 bits) More...
uint64_t xfer_count_bytes = 0
 Transfer count in bytes (64 bits) More...
uint64_t xfer_count_pkts = 0
 Transfer count in packets (40 bits) More...
uint16_t buff_info = 0
 Buffer info (16 bits) More...
union {
   uint64_t   info = 0
   struct {
      uint16_t   last_control_seq_num: 16
      uint16_t   expected_seq_num: 16
      uint16_t   reserved_1: 12
      bool   stop_on_seq_error_enabled: 1
      bool   seq_error_occoured: 1
      bool   reserved_2: 1
      bool   flow_control_due: 1
   }   status
   struct {
      uint16_t   current_seq_num: 16
      uint8_t   chdr_packet_type: 3
      uint16_t   reserved_1: 9
      bool   reserved_2: 1
      bool   reserved_3: 1
   }   sequence_error
   struct {
      uint16_t   dest_epid: 16
      uint16_t   this_epid: 16
      uint32_t   reserved_1: 32
   }   routing_error
} status_info
 Extended status info (48 bits) More...
◆ strs_payload() [1/3]
uhd::rfnoc::chdr::strs_payload::strs_payload ( )
default
◆ strs_payload() [2/3]
uhd::rfnoc::chdr::strs_payload::strs_payload ( const strs_payload &  rhs)
default
◆ strs_payload() [3/3]
uhd::rfnoc::chdr::strs_payload::strs_payload ( strs_payload &&  rhs)
default
◆ deserialize() [1/2]
void uhd::rfnoc::chdr::strs_payload::deserialize ( const uint64_t *  buff,
size_t  buff_size
buffBuffer to deserialize the payload from
buff_sizeNumber of elements in the buffer
◆ deserialize() [2/2]
size_t  buff_size,
const std::function< uint64_t(uint64_t)> &  conv_byte_order
conv_byte_orderByte order converter function (buffer to host endianness)
◆ get_length()
size_t uhd::rfnoc::chdr::strs_payload::get_length ( ) const
◆ operator!=()
bool uhd::rfnoc::chdr::strs_payload::operator!= ( const strs_payload &  rhs) const
◆ operator=()
strs_payload& uhd::rfnoc::chdr::strs_payload::operator= ( const strs_payload &  rhs)
default
◆ operator==()
bool uhd::rfnoc::chdr::strs_payload::operator== ( const strs_payload &  rhs) const
◆ populate_header()
void uhd::rfnoc::chdr::strs_payload::populate_header ( chdr_header &  header) const
◆ serialize() [1/2]
size_t uhd::rfnoc::chdr::strs_payload::serialize ( uint64_t *  buff,
) const
◆ serialize() [2/2]
) const
◆ to_string()
std::string uhd::rfnoc::chdr::strs_payload::to_string ( ) const
◆ buff_info
uint16_t uhd::rfnoc::chdr::strs_payload::buff_info = 0
◆ capacity_bytes
uint64_t uhd::rfnoc::chdr::strs_payload::capacity_bytes = 0
◆ capacity_pkts
uint32_t uhd::rfnoc::chdr::strs_payload::capacity_pkts = 0
◆ chdr_packet_type
uint8_t uhd::rfnoc::chdr::strs_payload::chdr_packet_type
◆ current_seq_num
uint16_t uhd::rfnoc::chdr::strs_payload::current_seq_num
◆ dest_epid
uint16_t uhd::rfnoc::chdr::strs_payload::dest_epid
◆ expected_seq_num
uint16_t uhd::rfnoc::chdr::strs_payload::expected_seq_num
◆ flow_control_due
bool uhd::rfnoc::chdr::strs_payload::flow_control_due
◆ info
uint64_t uhd::rfnoc::chdr::strs_payload::info = 0
◆ last_control_seq_num
uint16_t uhd::rfnoc::chdr::strs_payload::last_control_seq_num
◆ reserved_1 [1/2]
uint16_t uhd::rfnoc::chdr::strs_payload::reserved_1
◆ reserved_1 [2/2]
uint32_t uhd::rfnoc::chdr::strs_payload::reserved_1
◆ reserved_2
bool uhd::rfnoc::chdr::strs_payload::reserved_2
◆ reserved_3
bool uhd::rfnoc::chdr::strs_payload::reserved_3
struct { ... } uhd::rfnoc::chdr::strs_payload::routing_error
◆ seq_error_occoured
bool uhd::rfnoc::chdr::strs_payload::seq_error_occoured
struct { ... } uhd::rfnoc::chdr::strs_payload::sequence_error
◆ src_epid
uint16_t uhd::rfnoc::chdr::strs_payload::src_epid = 0
◆ status [1/2]
strs_status_t uhd::rfnoc::chdr::strs_payload::status = STRS_OKAY
◆  [2/2]
struct { ... } uhd::rfnoc::chdr::strs_payload::status
union { ... } uhd::rfnoc::chdr::strs_payload::status_info
◆ stop_on_seq_error_enabled
bool uhd::rfnoc::chdr::strs_payload::stop_on_seq_error_enabled
◆ this_epid
uint16_t uhd::rfnoc::chdr::strs_payload::this_epid
◆ xfer_count_bytes
uint64_t uhd::rfnoc::chdr::strs_payload::xfer_count_bytes = 0
◆ xfer_count_pkts
uint64_t uhd::rfnoc::chdr::strs_payload::xfer_count_pkts = 0
