uhd::rfnoc::duc_block_control Member List
This is the complete list of members for uhd::rfnoc::duc_block_control, including all inherited members.
action_mode_t enum nameuhd::rfnoc::node_t
get_freq(const size_t chan) const =0uhd::rfnoc::duc_block_controlpure virtual
get_frequency_range(const size_t chan) const =0uhd::rfnoc::duc_block_controlpure virtual
get_input_rate(const size_t chan) const =0uhd::rfnoc::duc_block_controlpure virtual
get_input_rates(const size_t chan) const =0uhd::rfnoc::duc_block_controlpure virtual
get_output_rate(const size_t chan) const =0uhd::rfnoc::duc_block_controlpure virtual
node_t()uhd::rfnoc::node_t
post_action(const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)uhd::rfnoc::node_tprotected
post_action_handler_t typedefuhd::rfnoc::node_t
REG_ADDRS_V0uhd::rfnoc::duc_block_controlstatic
REG_ADDRS_V1uhd::rfnoc::duc_block_controlstatic
REG_COMPAT_NUMuhd::rfnoc::duc_block_controlstatic
set_freq(const double freq, const size_t chan, const std::optional< uhd::time_spec_t > time={})=0uhd::rfnoc::duc_block_controlpure virtual
set_freq(const double freq, const size_t chan, const uhd::time_spec_t time)uhd::rfnoc::duc_block_controlinline
set_freq(const double freq, const size_t chan, const boost::optional< uhd::time_spec_t > time)uhd::rfnoc::duc_block_controlinlinevirtual
set_input_rate(const double rate, const size_t chan)=0uhd::rfnoc::duc_block_controlpure virtual
set_output_rate(const double rate, const size_t chan)=0uhd::rfnoc::duc_block_controlpure virtual
