#include <uhd/stream.hpp>
typedef std::shared_ptr< rx_streamer > sptr
virtual ~rx_streamer (void)
virtual void issue_stream_cmd (const stream_cmd_t &stream_cmd)=0
virtual void post_input_action (const std::shared_ptr< uhd::rfnoc::action_info > &action, const size_t port)=0
virtual device_addr_t get_stream_info (const size_t chan=0) const =0
◆ buffs_type
typedef std::shared_ptr<rx_streamer> uhd::rx_streamer::sptr
◆ ~rx_streamer()
virtual uhd::rx_streamer::~rx_streamer ( void  )
virtual
◆ get_max_num_samps()
◆ get_num_channels()
◆ get_stream_info()
virtual device_addr_t uhd::rx_streamer::get_stream_info ( const size_t  chan = 0) const
Return information about the current streamer object
The contents of the returned dictionary depend on the current hardware setup, the arguments with which this streamer was created, etc.
chanThe channel number for which to get stream info
dictionary of streamer information
◆ issue_stream_cmd()
virtual void uhd::rx_streamer::issue_stream_cmd ( const stream_cmd_t &  stream_cmd)
◆ post_input_action()
virtual void uhd::rx_streamer::post_input_action ( const std::shared_ptr< uhd::rfnoc::action_info > &  action,
const size_t  port
Post an action to the input edge of the Streamer.
actionshared pointer to the corresponding action_info request
portthe port to which to post the action
◆ recv()
virtual size_t uhd::rx_streamer::recv ( const buffs_type &  buffs,
rx_metadata_t &  metadata,
const double  timeout = 0.1,
Receive buffers containing samples described by the metadata
This is the main streaming API call for receiving samples from any USRP. It will block and receive any incoming data from the device into the user-provided buffers (buffs) until one of the following conditions is met:
  • The number of samples (or items) received equals nsamps_per_buff, i.e., the buffers have been completely filled. In this case, the return value of recv() equals nsamps_per_buff.
  • An end-of-burst packet was received. When this is the case, recv() will immediately return, and assert the end_of_burst flag in the RX metadata.
  • A timeout occurs, cf. Timeouts
  • If one_packet is set, then it will return as soon as one single packet was received. It will attempt to return all the samples from the packet that was processed.
  • A sequence error is detected (i.e., packets were dropped on the way to the host computer). In particular for Ethernet-based devices, this may occur if UDP packets get dropped. In this case, an error code is set in the metadata object.
  • An invalid packet is received. metadata.error_code is set to ERROR_CODE_BAD_PACKET.
  • For multi-channel streamers, if the streamer was not able to get time-aligned samples from every channel, it will eventually give up and set metadata.error_code to ERROR_CODE_ALIGNMENT.
  • An overrun is detected. This is the case when the software is calling recv() too slowly, and the device or transport buffers are backing up. In this case, samples may be dropped and an overrun condition is reported via the RX metadata. Depending on the device and streaming mode, the hardware may continue to produce samples (e.g., in continuous streaming) or may pause/stop until reconfigured. However, recv() may not immediately return whan an overrun is detected; for more details, cf. Error Handling
Note that in many of these scenarios, the actual number of samples received is smaller than the number of samples requested. The precise number of samples that were received before the function returned is relayed as the return value of recv().
Fragmentation
If the buffer has insufficient space to hold all samples that were received in a single packet over-the-wire, then the buffer will be completely filled and the implementation will hold a pointer into the remaining portion of the packet. Subsequent calls will load from the remainder of the packet, and will flag the metadata to show that this is a fragment. The next call to receive, after the remainder becomes exhausted, will perform an over-the-wire receive as usual. See the rx metadata fragment flags and offset fields for details.
Thread Safety
Note on threading: recv() is not thread-safe, to avoid locking overhead. The application calling recv() is responsible for making sure that not more than one thread can call recv() on the same streamer at the same time. If there are multiple streamers, receiving from different sources, then those may be called from different threads simultaneously.
Error Handling
metadata is a value that is set inside this function (effectively, a return value), and should be checked for potential error codes (see rx_metadata_t::error_code_t).
The most common error code when something goes wrong is an overrun (also referred to as overflow: error_code_t::ERROR_CODE_OVERFLOW). This error code means that the device produced data faster than the application could read, and various buffers filled up leaving no more space for the device to write data to. Note that an overrun on the device will not immediately show up when calling recv(). Depending on the device implementation, there may be many more valid samples available before the device had to stop writing samples to the FIFO. Only when all valid samples are returned to the call site will the error code be set to "overrun". When this happens, all valid samples have been returned to application where recv() was called. If the device is streaming continuously, it will reset itself when the FIFO is cleared, and recv() can be called again to retrieve new, valid data.
Timeouts
The recv() call has a timeout parameter. This parameter is used to limit the time the call will block. If no data is available within the timeout period, the call will return with an error code of error_code_t::ERROR_CODE_TIMEOUT. This is not necessarily an error condition, but can occur naturally, for example if the upstream source produces data in a bursty fashion.
An important fact about the timeout parameter is that it is not a total timeout value, but is applied to every single call within recv() that uses a timeout. This means that the total time recv() can block can be significantly larger than the timeout parameter passed to recv().
When the timeout is set to zero, recv() will attempt to return as fast as possible, to minimize latency. This is useful when the application polls for data in a busy loop. However, note that in this case, it is possible that the call will return with an error code of timeout, even though a different error condition occurred, but has not been fully processed. It is therefore not sufficient to call recv() with a timeout of zero to check for any outstanding error conditions.
Calling recv() with nsamps_per_buff = 0
It is not forbidden to call recv() with nsamps_per_buff = 0, and this can be useful to retrieve metadata only. In this case, the call will still apply the timeout value internally (which means the recv() call will wait at least for the timeout value for any incoming data, even though it won't be processed). However, the call will never return an error code of ERROR_CODE_TIMEOUT, as no data is expected to be processed.
The following code snippet demonstrates how to call recv() with a zero number of samples to retrieve metadata only:
// Note: timeout > 0, and num_samps_expected > 0. In this example, we
// expect buffs to be filled.
int num_samps_rcvd = rx_streamer->recv(
buffs, num_samps_expected, metadata, timeout);
if (num_samps_rcvd < num_samps_expected &&
(metadata.error_code == error_code_t::ERROR_CODE_NONE ||
metadata.error_code == error_code_t::ERROR_CODE_TIMEOUT)) {
// If we reach this point, we assume that an error occurred, but we
// don't know what it was.
// Note the zero-value for nsamps_per_buff:
rx_streamer->recv(buffs, 0, metadata, timeout);
// Now metadata.error_code will contain the actual error code,
// if it was received within timeout.
[out]metadatadata to fill describing the buffer
