22 struct async_metadata_t;
172 typedef std::shared_ptr<rx_streamer>
sptr;
328 const size_t nsamps_per_buff,
330 const double timeout = 0.1,
331 const bool one_packet =
false) = 0;
352 const std::shared_ptr<uhd::rfnoc::action_info>& action,
const size_t port) = 0;
373 typedef std::shared_ptr<tx_streamer>
sptr;
415 const size_t nsamps_per_buff,
417 const double timeout = 0.1) = 0;
434 const std::shared_ptr<uhd::rfnoc::action_info>& action,
Definition: device_addr.hpp:39
Definition: ref_vector.hpp:22
Definition: stream.hpp:170
ref_vector< void * > buffs_type
Typedef for a pointer to a single, or a collection of recv buffers.
Definition: stream.hpp:183
Definition: stream.hpp:172
virtual void post_input_action(const std::shared_ptr< uhd::rfnoc::action_info > &action, const size_t port)=0
virtual ~rx_streamer(void)
virtual device_addr_t get_stream_info(const size_t chan=0) const =0
virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd)=0
virtual size_t get_num_channels(void) const =0
Get the number of channels associated with this streamer.
virtual size_t get_max_num_samps(void) const =0
Get the max number of samples per buffer per packet.
virtual size_t recv(const buffs_type &buffs, const size_t nsamps_per_buff, rx_metadata_t &metadata, const double timeout=0.1, const bool one_packet=false)=0
Definition: stream.hpp:371
virtual ~tx_streamer(void)
virtual bool recv_async_msg(async_metadata_t &async_metadata, double timeout=0.1)=0
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:373
ref_vector< const void * > buffs_type
Typedef for a pointer to a single, or a collection of send buffers.
Definition: stream.hpp:384
virtual void post_output_action(const std::shared_ptr< uhd::rfnoc::action_info > &action, const size_t port)=0
virtual size_t send(const buffs_type &buffs, const size_t nsamps_per_buff, const tx_metadata_t &metadata, const double timeout=0.1)=0
Definition: config.h:87
Definition: build_info.hpp:12
Definition: stream.hpp:51
std::string otw_format
Definition: stream.hpp:95
device_addr_t args
Definition: stream.hpp:132
std::string cpu_format
Definition: stream.hpp:75
stream_args_t(const std::string &cpu="", const std::string &otw="")
Convenience constructor for streamer args.
Definition: stream.hpp:53
std::vector< size_t > channels
Definition: stream.hpp:161
Definition: stream_cmd.hpp:42
