dboard_iface.hpp
2 // Copyright 2010-2013,2015-2016 Ettus Research LLC
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <uhd/exception.hpp>
12 #include <uhd/types/serial.hpp>
13 #include <uhd/types/time_spec.hpp>
14 #include <uhd/usrp/gpio_defs.hpp>
15 #include <chrono>
16 #include <cstddef>
17 #include <cstdint>
18 #include <functional>
19 #include <memory>
20 #include <string>
21 #include <vector>
22
23 namespace uhd { namespace usrp {
24 class fe_connection_t;
25
28 {
36
46 };
47
55 {
56 public:
57  typedef std::shared_ptr<dboard_iface> sptr;
59
61  enum unit_t : uint32_t {
62  UNIT_RX = int('r'),
63  UNIT_TX = int('t'),
64  UNIT_BOTH = int('b'),
65  };
66
68  enum aux_dac_t : uint32_t {
69  AUX_DAC_A = int('a'),
70  AUX_DAC_B = int('b'),
71  AUX_DAC_C = int('c'),
72  AUX_DAC_D = int('d')
73  };
74
76  enum aux_adc_t : uint32_t { AUX_ADC_A = int('a'), AUX_ADC_B = int('b') };
77
79
80  ~dboard_iface(void) override{};
81
89
97  virtual void write_aux_dac(unit_t unit, aux_dac_t which_dac, double value) = 0;
98
106  virtual double read_aux_adc(unit_t unit, aux_adc_t which_adc) = 0;
107
115  virtual void set_pin_ctrl(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
116
123  virtual uint32_t get_pin_ctrl(unit_t unit) = 0;
124
133  virtual void set_atr_reg(
134  unit_t unit, atr_reg_t reg, uint32_t value, uint32_t mask = 0xffff) = 0;
135
143  virtual uint32_t get_atr_reg(unit_t unit, atr_reg_t reg) = 0;
144
152  virtual void set_gpio_ddr(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
153
160  virtual uint32_t get_gpio_ddr(unit_t unit) = 0;
161
169  virtual void set_gpio_out(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
170
177  virtual uint32_t get_gpio_out(unit_t unit) = 0;
178
185  virtual uint32_t read_gpio(unit_t unit) = 0;
186
195  virtual void write_spi(
196  unit_t unit, const spi_config_t& config, uint32_t data, size_t num_bits) = 0;
197
207  virtual uint32_t read_write_spi(
208  unit_t unit, const spi_config_t& config, uint32_t data, size_t num_bits) = 0;
209
216  virtual void set_clock_rate(unit_t unit, double rate) = 0;
217
224  virtual double get_clock_rate(unit_t unit) = 0;
225
232  virtual std::vector<double> get_clock_rates(unit_t unit) = 0;
233
240  virtual void set_clock_enabled(unit_t unit, bool enb) = 0;
241
249  virtual double get_codec_rate(unit_t unit) = 0;
250
257  virtual bool lock_clock_rate([[maybe_unused]] const unit_t unit)
258  {
259  return false; // default implementation does not support locking
260  }
261
269  virtual void set_fe_connection(unit_t unit,
270  const std::string& fe_name,
271  const uhd::usrp::fe_connection_t& fe_conn) = 0;
272
275  virtual bool has_set_fe_connection(const unit_t)
276  {
277  return false;
278  }
279
285
290  virtual void set_command_time(const uhd::time_spec_t& t) = 0;
291
296  virtual void sleep(const std::chrono::nanoseconds& time);
297
302  virtual void define_custom_register_space(const uint32_t,
303  const uint32_t,
304  std::function<void(uint32_t, uint32_t)>,
305  std::function<uint32_t(uint32_t)>)
306  { /* noop*/
307  }
308 };
309
310 }} // namespace uhd::usrp
Definition: serial.hpp:37
Definition: time_spec.hpp:31
Definition: dboard_iface.hpp:55
virtual uint32_t get_atr_reg(unit_t unit, atr_reg_t reg)=0
Definition: dboard_iface.hpp:257
virtual uint32_t get_gpio_ddr(unit_t unit)=0
virtual void set_gpio_ddr(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0
virtual void set_clock_rate(unit_t unit, double rate)=0
Definition: dboard_iface.hpp:58
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:57
virtual special_props_t get_special_props(void)=0
Definition: dboard_iface.hpp:80
virtual void set_atr_reg(unit_t unit, atr_reg_t reg, uint32_t value, uint32_t mask=0xffff)=0
virtual void set_command_time(const uhd::time_spec_t &t)=0
virtual uhd::time_spec_t get_command_time(void)=0
virtual void write_aux_dac(unit_t unit, aux_dac_t which_dac, double value)=0
virtual uint32_t get_gpio_out(unit_t unit)=0
uhd::usrp::gpio_atr::gpio_atr_reg_t atr_reg_t
Definition: dboard_iface.hpp:78
virtual std::vector< double > get_clock_rates(unit_t unit)=0
virtual void set_pin_ctrl(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0
virtual void set_gpio_out(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0
aux_adc_t
Definition: dboard_iface.hpp:76
virtual void set_fe_connection(unit_t unit, const std::string &fe_name, const uhd::usrp::fe_connection_t &fe_conn)=0
aux_dac_t
Definition: dboard_iface.hpp:68
unit_t
virtual double get_codec_rate(unit_t unit)=0
Definition: dboard_iface.hpp:275
virtual uint32_t get_pin_ctrl(unit_t unit)=0
virtual uint32_t read_write_spi(unit_t unit, const spi_config_t &config, uint32_t data, size_t num_bits)=0
virtual void sleep(const std::chrono::nanoseconds &time)
virtual void define_custom_register_space(const uint32_t, const uint32_t, std::function< void(uint32_t, uint32_t)>, std::function< uint32_t(uint32_t)>)
Definition: dboard_iface.hpp:302
virtual void write_spi(unit_t unit, const spi_config_t &config, uint32_t data, size_t num_bits)=0
virtual uint32_t read_gpio(unit_t unit)=0
virtual double get_clock_rate(unit_t unit)=0
virtual double read_aux_adc(unit_t unit, aux_adc_t which_adc)=0
virtual void set_clock_enabled(unit_t unit, bool enb)=0
Definition: fe_connection.hpp:17
Definition: config.h:87
Definition: soft_register.hpp:86
gpio_atr_reg_t
Definition: gpio_defs.hpp:12
Definition: build_info.hpp:12
Definition: serial.hpp:84
Definition: dboard_iface.hpp:28
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:45
bool soft_clock_divider
Definition: dboard_iface.hpp:35
