81 T
cast(
const std::string& key,
const T& def)
const
83 if (not this->has_key(key))
86 return uhd::cast::from_str<T>((*
this)[key]);
88 throw std::runtime_error(
"cannot cast " + key +
this)[key]);
Definition: device_addr.hpp:39
device_addr_t(const std::string &args="")
T cast(const std::string &key, const T &def) const
Definition: device_addr.hpp:81
std::string to_string(void) const
device_addr_t(const std::map< std::string, std::string > &info)
std::string to_pp_string(void) const
device_addr_t(const char *args)
Definition: config.h:87
@ info
Definition: log.hpp:122
Definition: build_info.hpp:12
UHD_API device_addrs_t separate_device_addr(const device_addr_t &dev_addr)
Separate an indexed device address into a vector of device addresses.
UHD_API device_addr_t combine_device_addrs(const device_addrs_t &dev_addrs)
Combine a vector of device addresses into an indexed device address.
std::vector< device_addr_t > device_addrs_t
A typedef for a vector of device addresses.
Definition: device_addr.hpp:94
Definition: exception.hpp:132
