#include <uhd/config.hpp>#include <uhd/exception.hpp>#include <type_traits>#include <complex>#include <cstdint>#include <iomanip>#include <ios>#include <limits>#include <locale>#include <sstream>#include <string>Go to the source code of this file.
Namespaces | |
| uhd | |
| uhd::cast | |
| uhd::cast::detail | |
Template implementations for uhd::cast::to_str() for common types. | |
Typedefs | |
| template<typename T > | |
| using | uhd::cast::detail::has_to_string_method = decltype(has_to_string_method_impl< T >(0)) |
Functions | |
| T | uhd::cast::hexstr_cast (const std::string &in) |
| Convert a hexadecimal string into a value. More... | |
| T | uhd::cast::fromstr_cast (const std::string &in) |
| Convert hexadecimal, decimal, octal or other strings that support the >> operator into a value depending on the prefix. More... | |
| template<typename data_t > | |
| data_t | uhd::cast::from_str (const std::string &val) |
| Generic cast-from-string function. More... | |
| template<> | |
| UHD_API bool | uhd::cast::from_str (const std::string &val) |
Specialization of uhd::cast::from_str() for Boolean values. More... | |
| UHD_API std::string | uhd::cast::to_ordinal_string (int val) |
| Create an ordinal string from a number. More... | |
| auto | uhd::cast::detail::has_to_string_method_impl (int) -> decltype(std::declval< T >().to_string(), std::true_type{}) |
| auto | uhd::cast::detail::has_to_string_method_impl (...) -> std::false_type |
| auto | uhd::cast::to_str (const T &val) -> std::enable_if_t< std::is_arithmetic_v< T > &&!std::is_floating_point_v< T > &&!std::is_same_v< T, int8_t > &&!std::is_same_v< T, uint8_t > &&!std::is_enum_v< T > &&!detail::has_to_string_method< T >::value, decltype(std::to_string(val))> |
| SFINAE-based template for integer types that std::to_string can handle. More... | |
| std::string | uhd::cast::to_str (const std::complex< T > &val) |
| SFINAE-based template for std::complex<T> types. More... | |
| std::string | uhd::cast::to_str (const std::string &val) |
| Overload for std::string and C-style strings. More... | |
| std::string | uhd::cast::to_str (const char *val) |
