fosphor_block_control.hpp
2 // Copyright 2020 Ettus Research, a National Instruments Brand
5 //
6
7 #pragma once
8
9 #include <uhd/config.hpp>
11
12 namespace uhd { namespace rfnoc {
13
16  RATIO_1_1,
17  RATIO_1_8,
18  RATIO_1_64,
20 };
21
100 {
101 public:
103
104  // Block registers
105  static const uint32_t REG_ENABLE_ADDR;
106  static const uint32_t REG_CLEAR_ADDR;
107  static const uint32_t REG_RANDOM_ADDR;
108  static const uint32_t REG_DECIM_ADDR;
109  static const uint32_t REG_OFFSET_ADDR;
110  static const uint32_t REG_SCALE_ADDR;
111  static const uint32_t REG_TRISE_ADDR;
112  static const uint32_t REG_TDECAY_ADDR;
113  static const uint32_t REG_ALPHA_ADDR;
114  static const uint32_t REG_EPSILON_ADDR;
115  static const uint32_t REG_WF_CTRL_ADDR;
116  static const uint32_t REG_WF_DECIM_ADDR;
117
124  virtual void set_enable_histogram(const bool enable_histogram) = 0;
125
132  virtual bool get_enable_histogram() const = 0;
133
140  virtual void set_enable_waterfall(const bool enable_waterfall) = 0;
141
148  virtual bool get_enable_waterfall() const = 0;
149
155  virtual void clear_history() = 0;
156
164  virtual void set_enable_dither(const bool enable_dither) = 0;
165
172  virtual bool get_enable_dither() const = 0;
173
181  virtual void set_enable_noise(const bool enable_noise) = 0;
182
189  virtual bool get_enable_noise() const = 0;
190
201  virtual void set_histogram_decimation(const uint16_t decimation) = 0;
202
209  virtual uint16_t get_histogram_decimation() const = 0;
210
218  virtual void set_histogram_offset(const uint16_t offset) = 0;
219
226  virtual uint16_t get_histogram_offset() const = 0;
227
235  virtual void set_histogram_scale(const uint16_t scale) = 0;
236
243  virtual uint16_t get_histogram_scale() const = 0;
244
256  virtual void set_histogram_rise_rate(const uint16_t rise_rate) = 0;
257
264  virtual uint16_t get_histogram_rise_rate() const = 0;
265
277  virtual void set_histogram_decay_rate(const uint16_t decay_rate) = 0;
278
285  virtual uint16_t get_histogram_decay_rate() const = 0;
286
296  virtual void set_spectrum_alpha(const uint16_t alpha) = 0;
297
305  virtual uint16_t get_spectrum_alpha() const = 0;
306
315  virtual void set_spectrum_max_hold_decay(const uint16_t epsilon) = 0;
316
324  virtual uint16_t get_spectrum_max_hold_decay() const = 0;
325
332  virtual void set_waterfall_predivision(
333  const fosphor_waterfall_predivision_ratio waterfall_predivision) = 0;
334
341  virtual fosphor_waterfall_predivision_ratio get_waterfall_predivision() const = 0;
342
354  virtual void set_waterfall_mode(const fosphor_waterfall_mode waterfall_mode) = 0;
355
362  virtual fosphor_waterfall_mode get_waterfall_mode() const = 0;
363
373  virtual void set_waterfall_decimation(const uint16_t waterfall_decimation) = 0;
374
381  virtual uint16_t get_waterfall_decimation() const = 0;
382 };
383
384 }} // namespace uhd::rfnoc
Definition: fosphor_block_control.hpp:100
Definition: noc_block_base.hpp:42
Definition: config.h:87
Definition: fosphor_block_control.hpp:15
Definition: fosphor_block_control.hpp:14
Definition: build_info.hpp:12
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
