noc_block_base.hpp File Reference
Classes
class  uhd::rfnoc::noc_block_base
struct  uhd::rfnoc::noc_block_base::make_args_t
 Dummy make_args_t class. More...
struct  uhd::rfnoc::noc_block_base::make_args_deleter
 Custom deleter for make_args_int_t that doesn't require complete type. More...
Namespaces
 uhd
 uhd::rfnoc
Macros
#define RFNOC_BLOCK_CONSTRUCTOR(CLASS_NAME)    CLASS_NAME##_impl(make_args_ptr make_args) : CLASS_NAME(std::move(make_args))
 Shorthand for block constructor. More...
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
◆ RFNOC_BLOCK_CONSTRUCTOR
#define RFNOC_BLOCK_CONSTRUCTOR (   CLASS_NAME)     CLASS_NAME##_impl(make_args_ptr make_args) : CLASS_NAME(std::move(make_args))
◆ RFNOC_DECLARE_BLOCK
#define RFNOC_DECLARE_BLOCK (   CLASS_NAME)
Value:
using sptr = std::shared_ptr<CLASS_NAME>; \
CLASS_NAME(make_args_ptr make_args) : noc_block_base(std::move(make_args)) {}
