14 namespace uhd {
namespace rfnoc {
35 const size_t dst_port_,
38 : src_port(src_port_), dst_port(dst_port_), edge(edge_), is_forward_edge(fwd_edge)
55 bool is_forward_edge =
true;
60 return is_equal(rhs,
true);
74 return (std::tie(src_blockid, src_port, dst_blockid, dst_port)
77 && (match_properties ? (std::tie(edge, is_forward_edge)
85 return src_blockid +
":" + std::to_string(src_port)
86 + (edge == STATIC ?
"-->") + dst_blockid +
87 + std::to_string(dst_port);
Definition: config.h:87
Definition: build_info.hpp:12
Definition: graph_edge.hpp:24
std::string to_string() const
Return a string representation of the connection.
Definition: graph_edge.hpp:83
bool is_equal(const graph_edge_t &rhs, const bool match_properties=false) const
Definition: graph_edge.hpp:72
std::string dst_blockid
The ID of the destination block for this edge.
Definition: graph_edge.hpp:47
Definition: graph_edge.hpp:55
std::string src_blockid
The ID of the source block for this edge.
Definition: graph_edge.hpp:43
edge_t edge
The type of edge.
Definition: graph_edge.hpp:51
graph_edge_t(const size_t src_port_, const size_t dst_port_, const edge_t edge_, const bool fwd_edge)
Definition: graph_edge.hpp:34
edge_t
Definition: graph_edge.hpp:25
@ DYNAMIC
A user (dynamic) connection between two blocks in the FPGA.
Definition: graph_edge.hpp:27
@ STATIC
A static connection between two blocks in the FPGA.
Definition: graph_edge.hpp:26
@ RX_STREAM
A connection from an FPGA block to a software RX streamer.
Definition: graph_edge.hpp:28
size_t dst_port
The port number of the destination block for this edge.
Definition: graph_edge.hpp:49
bool operator==(const graph_edge_t &rhs) const
Equality operator: Compare two edges if they match, including edge properties.
Definition: graph_edge.hpp:58
size_t src_port
The port number of the source block for this edge.
Definition: graph_edge.hpp:45
