uhd::rfnoc::graph_edge_t Struct Reference
#include <uhd/rfnoc/graph_edge.hpp>
A container that holds information about a graph edge
Note: The source and destination IDs are strings, not block IDs (uhd::rfnoc::block_id_t). This is because the graph can contain edges that are not between RFNoC blocks (e.g., to a streamer), and we need to be able to generically express node IDs.
enum  edge_t : uint32_t { STATIC , DYNAMIC , RX_STREAM , TX_STREAM }
 graph_edge_t ()=default
 graph_edge_t (const size_t src_port_, const size_t dst_port_, const edge_t edge_, const bool fwd_edge)
bool operator== (const graph_edge_t &rhs) const
 Equality operator: Compare two edges if they match, including edge properties. More...
bool is_equal (const graph_edge_t &rhs, const bool match_properties=false) const
std::string to_string () const
 Return a string representation of the connection. More...
Public Attributes
std::string src_blockid
 The ID of the source block for this edge. More...
size_t src_port = 0
 The port number of the source block for this edge. More...
std::string dst_blockid
 The ID of the destination block for this edge. More...
size_t dst_port = 0
 The port number of the destination block for this edge. More...
edge_t edge = DYNAMIC
 The type of edge. More...
bool is_forward_edge = true
◆ edge_t
Enumerator
STATIC
A static connection between two blocks in the FPGA.
DYNAMIC
A user (dynamic) connection between two blocks in the FPGA.
RX_STREAM
A connection from an FPGA block to a software RX streamer.
TX_STREAM
A connection from a software TX streamer and an FPGA block.
◆ graph_edge_t() [1/2]
uhd::rfnoc::graph_edge_t::graph_edge_t ( )
default
◆ graph_edge_t() [2/2]
uhd::rfnoc::graph_edge_t::graph_edge_t ( const size_t  src_port_,
const edge_t  edge_,
const bool  fwd_edge
◆ is_equal()
bool uhd::rfnoc::graph_edge_t::is_equal ( const graph_edge_t &  rhs,
const bool  match_properties = false
) const
Equality comparison of two edges.
If match_properties is false, this compares two edges to test if they have the same direction, source port, and destination port. If match_properties is true, then it also tests if all the edge properties match (edge type, back-edge).
true if edges match.
◆ operator==()
bool uhd::rfnoc::graph_edge_t::operator== ( const graph_edge_t &  rhs) const
◆ to_string()
std::string uhd::rfnoc::graph_edge_t::to_string ( void  ) const
◆ dst_blockid
std::string uhd::rfnoc::graph_edge_t::dst_blockid
◆ dst_port
size_t uhd::rfnoc::graph_edge_t::dst_port = 0
◆ edge
edge_t uhd::rfnoc::graph_edge_t::edge = DYNAMIC
The type of edge.
◆ is_forward_edge
bool uhd::rfnoc::graph_edge_t::is_forward_edge = true
When false, the framework will assume this is a back-edge. Back-edges are not used for sorting the graph as a DAG.
◆ src_blockid
std::string uhd::rfnoc::graph_edge_t::src_blockid
◆ src_port
size_t uhd::rfnoc::graph_edge_t::src_port = 0
