uhd::math Namespace Reference
Namespaces
 fp_compare
Enumerations
enum class  interp_mode { NEAREST_NEIGHBOR , LINEAR }
Functions
UHD_INLINE bool frequencies_are_equal (double lhs, double rhs)
double dB_to_lin (const double dB_val)
double lin_to_dB (const double val)
template<typename T >
constexpr int sign (T x)
 Returns the sign of x. More...
double wrap_frequency (const double requested_freq, const double rate)
 Return a wrapped frequency that is the equivalent frequency in the first Nyquist zone. More...
Contains useful mathematical functions, classes, and constants, which should be used in UHD when portable / std options are not available.
◆ interp_mode
Enumerator
NEAREST_NEIGHBOR
LINEAR
Function Documentation
◆ dB_to_lin()
double uhd::math::dB_to_lin ( const double  dB_val)
◆ frequencies_are_equal()
UHD_INLINE bool uhd::math::frequencies_are_equal ( double  lhs,
double  rhs
◆ lin_to_dB()
double uhd::math::lin_to_dB ( const double  val)
◆ sign()
constexpr int uhd::math::sign ( T  x)
inlineconstexpr
Note: This is equivalent to the Boost.Math version, but without the dependency.
Returns +1 for positive arguments, -1 for negative arguments, and 0 if x is zero.
◆ wrap_frequency()
double uhd::math::wrap_frequency ( const double  requested_freq,
const double  rate
Examples:
  • Just above the sampling rate: wrap_frequency(250e6, 200e6) == 50e6
  • Just outside the Nyquist zone: wrap_frequency(120e6, 200e6) == -80e6
  • Also works for negative frequencies: wrap_frequency(-250e6, 200e6) == -50e6
