The B310 PCIe transport on Linux requires the nib310rio kernel module. Without this module, UHD cannot discover or use the B310 device over the PCIe or Thunderbolt interface.
gcc, make)dkms (recommended for package-based installs)Example (Ubuntu/Debian):
sudo apt update sudo apt install -y dkms gcc make linux-headers-$(uname -r)
For standard Linux desktop systems (for example Ubuntu or Fedora), install the nib310rio driver packages and ensure the module is loaded.
Download the latest Linux kernel driver packages from Ettus UHD latest release binaries.
The package names and roles are:
nib310rio-dkms: Required runtime kernel driver package. This package builds and installs the nib310rio kernel module via DKMS.nib310rio-dev: Development header package. This installs /usr/include/nib310rio/nib310rio.h, which is required to compile B310 support in UHD.Example install flow (Debian/Ubuntu):
sudo dpkg -i nib310rio-dkms_<version>_all.deb sudo dpkg -i nib310rio-dev_<version>_all.deb
For Fedora/RHEL-like systems, install the equivalent RPM packages:
sudo dnf install ./nib310rio-dkms-<version>-1.noarch.rpm sudo dnf install ./nib310rio-dev-<version>-1.noarch.rpm
After installation, validate that the module is present:
lsmod | grep nib310rio
If needed, load it manually:
sudo modprobe nib310rio
Then verify that UHD can discover the device:
uhd_find_devices --args type=b3xx
The checks below summarize common package-installation failures and validation steps observed in the B310 Linux driver package installation flow.
If dkms install reports missing pahole:
sudo apt install -y pahole sudo apt install -y dkms
If dpkg -i leaves nib310rio-dkms unconfigured due to unmet dependencies:
sudo apt --fix-broken install -y sudo dpkg --configure -a
After package installation, validate DKMS state and module location:
dkms status | grep nib310rio modinfo -n nib310rio
Expected:
dkms status reports nib310rio installed for the running kernel.modinfo -n nib310rio resolves to a path under /lib/modules/....The following abbreviated output snippets are examples of successful package installation.
Debian/Ubuntu (nib310rio-dkms):
Fedora/RHEL (nib310rio-dkms):
On Secure Boot systems, module build/install may succeed but modprobe can fail with key rejection until a trusted key is enrolled and the module is rebuilt and re-signed. If this occurs, follow your distribution's MOK enrollment flow, then rebuild/reinstall the DKMS module.
Typical error:
On Debian/Ubuntu systems, the flow is typically:
sudo apt install -y shim-signed mokutil
Enroll MOK.Continue.Yes.shim-signed installation.Reboot.sudo dkms remove nib310rio/<version> --all || true sudo dkms add -m nib310rio -v <version> sudo dkms build -m nib310rio -v <version> -k "$(uname -r)" sudo dkms install -m nib310rio -v <version> -k "$(uname -r)" --force sudo depmod -a sudo modprobe nib310rio
mokutil --sb-state modinfo nib310rio | grep -i signer lsmod | grep nib310rio
Confirm that expected packaging artifacts are present:
test -f /etc/udev/rules.d/99-nib310rio.rules && echo "udev rule present" test -f /etc/modules-load.d/nib310rio.conf && echo "autoload config present" test -f /usr/include/nib310rio/nib310rio.h && echo "dev header present"
This section targets Jetson Linux 39.2.1 / JetPack 7.2.1 (Ubuntu 24.04, kernel 6.8). The commands use its native source layout, where the kernel tree is kernel/kernel-noble/.
On Jetson AGX Orin, the B310 software path requires Linux DMA-BUF heap support. In particular, /dev/dma_heap/system must be available. If this device node is missing, DMA-based operation will fail and only limited BAR0 access may work.
Use the following sequence when enabling B310 support on Jetson:
/dev/dma_heap/system.nib310rio kernel driver packages as in the Linux desktop case (see Linux Desktop Installation).Confirm the target release on the Jetson host:
uname -r cat /etc/nv_tegra_release
NVIDIA kernel customization reference: Jetson Linux Kernel Customization
The procedure below builds the kernel natively on the Jetson and installs it on that same device. A cross-compiled kernel must instead be installed through the Jetson Linux Linux_for_Tegra flashing workflow; do not run the /boot copy or modules_install commands below on the cross-build host.
Build environment setup:
sudo apt update sudo apt install -y git build-essential bc flex bison libssl-dev zstd
Download and extract the Jetson Linux release package and public sources for the target release from the Jetson Linux archive. The release must match the version reported by cat /etc/nv_tegra_release. In the commands below, <install-path> is a directory on the Jetson, for example ~/jetson_linux, and <public-sources-path> is the path to the downloaded archive, for example ~/Downloads/public_sources.tbz2.
For Jetson Linux 39.2.1, download Driver Package (BSP) Sources (public_sources.tbz2).
Extract the public sources, then extract the matching source archives from its Linux_for_Tegra/source/ directory:
tar xf <public-sources-path> -C <install-path> cd <install-path>/Linux_for_Tegra/source tar xf kernel_src.tbz2 tar xf kernel_oot_modules_src.tbz2 tar xf nvidia_kernel_display_driver_source.tbz2
This release package does not include source_sync.sh; use the public-source archives instead. Seed the new kernel configuration from the running kernel:
zcat /proc/config.gz > kernel/kernel-noble/.config cd kernel/kernel-noble export ARCH=arm64 export LOCALVERSION=-tegra make olddefconfig
Enable these options as built-ins (=y):
CONFIG_DMA_SHARED_BUFFER=y CONFIG_DMABUF_HEAPS=y CONFIG_DMABUF_HEAPS_SYSTEM=y CONFIG_SYNC_FILE=y
Apply the configuration and resolve its dependencies:
scripts/config --enable DMA_SHARED_BUFFER scripts/config --enable DMABUF_HEAPS scripts/config --enable DMABUF_HEAPS_SYSTEM scripts/config --enable SYNC_FILE make olddefconfig
Build the kernel and its in-tree modules. The resulting release string is 6.8.12-tegra, so installing the matching modules is required even when the running stock kernel is 6.8.12-1021-tegra:
make -j$(nproc) Image make -j$(nproc) modules sudo -E make modules_install
Build and install the NVIDIA out-of-tree modules against the same kernel tree:
cd <install-path>/Linux_for_Tegra/source export ARCH=arm64 export LOCALVERSION=-tegra export KERNEL_HEADERS=$PWD/kernel/kernel-noble export kernel_name=noble make -j$(nproc) modules sudo -E make modules_install
Stage the new image under a separate name, leaving the original boot image unchanged:
sudo cp <install-path>/Linux_for_Tegra/source/kernel/kernel-noble/arch/arm64/boot/Image \
/boot/Image.dmabuf
No devicetree changes are required for DMA-BUF heaps, so the installed DTBs can be reused.
Add a dmabuf entry to /boot/extlinux/extlinux.conf. Its APPEND value is system-specific; copy it from the existing primary entry:
Leave DEFAULT set to primary. Reboot the Jetson, then select dmabuf from the boot menu to test the new kernel. After verification, it can instead be made the default by setting DEFAULT dmabuf. If the test kernel does not boot or essential peripherals fail, select primary to return to the original image.
After booting the dmabuf entry, confirm the new kernel is active:
uname -r
Expected: 6.8.12-tegra.
Check kernel config:
zgrep DMABUF /proc/config.gz
Verify DMA heap node exists:
ls -l /dev/dma_heap/
Expected: system entry under /dev/dma_heap/.
Check kernel log:
dmesg | grep dma_heap
Expected log includes registration of the system heap.
Once DMA-BUF support is enabled and verified, use the same nib310rio, UHD, and FPGA image flow as the Linux desktop case.
Build and install UHD using the same process as Linux desktop builds (see Building and Installing UHD from source).
After UHD and the driver are installed, validate operation:
uhd_find_devices --args type=b3xx uhd_usrp_probe --args type=b3xx
On Windows, install the b310k MSI driver package b310ki_win64.msi from Ettus UHD latest release binaries.
After installation, confirm the B310 appears in Device Manager and is enabled. If required, disable/enable the device from Device Manager to recover from enumeration failures after cabling or power changes.
