USRP B3xx Series
Comparative features list
  • Hardware Capabilities:
    • PCIe Gen 2x4 or Thunderbolt™ 3 or later
    • External PPS input
    • External reference input (10 MHz, 122.88 MHz, or 125 MHz)
    • 4x External high-frequency reference output (122.88 MHz or 125 MHz) and PPS output over mini HDMI for improved phase-coherent operation
    • Internal GPSDO for timing and time/frequency reference
    • Supported master clock rates: 122.88 MHz and 125 MHz
    • Fixed TX/RX bandwidth: 100 MHz
    • Onboard power and temperature monitoring
    • Front-panel mini HDMI GPIO connector
    • 1 GiB DDR3 RAM
    • Kintex-7 Industrial-Grade FPGA (XC7K325T)
    • JTAG Connector (only accessible on OEM and PCIe variants)
  • FPGA Capabilities:
  • Mechanical Capabilities:
    • The B310 is available in multiple form factors:
      • 790817-01 Full Height PCIe 2.0 x 4 for desktop and standard workstations
      • 790415-01 OEM PCIe 2.0 x 4 for embedded and customer system integration
      • 790414-01 Enclosed Thunderbolt™ housed in a passively cooled enclosure with accommodations for attachment to an optional rackmount kit (accessory)
  • RF Capabilities:
    • 2x full-duplex RF channels with a bandwidth of 100MHz, tunable from 350 MHz - 7.225 GHz center frequency using the ADRV9032R transceiver
Overview and Features
The B310 has three variants: PCIe, OEM PCIe, and Enclosed Thunderbolt™.
Ettus USRP B310 PCIe
Ettus USRP B310 OEM PCIe
Ettus USRP B310 Enclosed Thunderbolt™
The Ettus USRP B310 is a B-Series USRP. All three variants utilize the same ADRV9032R transceiver as well as the same clocking circuitry. The PCIe variant is a superset of the OEM variant, including a PCIe front panel bracket and attached heatsink. Apart from the different mechanical enclosure, the Thunderbolt™ variant differs only by the added Thunderbolt™ circuitry to connect the module over Thunderbolt™ rather than PCIe card edge. The other pieces of the board are equivalent. The software support within UHD is the same for all three variants.
Front and Back Panels
The front and back panels are equivalent between the three variants as far as ports are concerned. The only difference being that the Thunderbolt™ panels have a horizontal orientation, and the other variants have a vertical orientation. The below pictures are from the Thunderbolt™ variant.
Ettus USRP B310 Thunderbolt™ Front Panel
The B310 front panel provides access to the RF ports and status LEDs for each channel. It also provides access to the GPS antenna port and the Mini HDMI GPIO port. There is also a power LED status indicator.
Ettus USRP B310 Thunderbolt™ Back Panel
The B310 back panel provides access to the Reference and PPS In ports for clocking as well as the SYNC port that outputs the high-frequency reference and PPS out signals through use of the multi-device sync cable. The panel also provides access to the external power USB-C port and Thunderbolt™ USB-C port. These ports are only used in the Thunderbolt™ configuration but are present in the other configurations.
Getting started
This section walks through the first steps to get your USRP B310 up and running. The B310 connects to your host computer via PCIe card edge or Thunderbolt™ depending on the variant.
Installing the Kernel Driver
The B310 requires the nib310rio kernel module on Linux, or the b310k driver on Windows. Without this kernel driver, UHD will not be able to detect or interact with the device.
To install either of these drivers, please follow the instructions here: B3xx Kernel Module Installation and Usage
See Driver not loaded for driver troubleshooting steps.
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The USRP is guaranteed to be functional at the time it is received by the customer. Improper use or handling can cause the device to become non-functional. Take the following precautions to prevent damage:
  • Never allow the board to come into contact with any voltage spikes.
Hardware Setup
PCI Express
  • Prior to installing the module, make sure the PC is powered off.
  • Install the B310 into an available PCIe slot (x4 or larger).
    • For best performance, ensure the slot supports PCIe gen 2x4.
  • Power on the PC.
Thunderbolt™
  • The Thunderbolt™ variant is hot-pluggable.
  • Connect power to the device via the included cable.
  • Connect the B310's Thunderbolt™ port to a Thunderbolt™ port on the PC via Thunderbolt™ cable.
Note: Use a certified Thunderbolt™ cable — not all cables with USB-C connectors support Thunderbolt™. Similarly, ensure the host port is Thunderbolt™-capable; not all USB-C ports support Thunderbolt™.
Discovering the Device
Once the driver is installed and the device is connected, run:
uhd_find_devices --args type=b3xx
to verify UHD can see the device. To probe all hardware components, run:
uhd_usrp_probe --args type=b3xx
Updating the FPGA
Upon first use, update the FPGA image to the version of UHD you are utilizing to ensure compatibility between the driver and FPGA.
  1. Download current UHD images using the uhd_images_downloader script (see also Firmware and FPGA Images).
  2. Use uhd_image_loader to update the FPGA:
    uhd_image_loader --args="type=b3xx,resource=<resource>"
  3. Power-cycle the device after loading.
FPGA Image Flavors
The B310 has two FPGA images that are shipped with UHD. The default FPGA, replay, has a RFNoC Replay block that can be used as with other RFNoC devices. The other FPGA, fifo, instead utilizes the DRAM as a buffer for improved streaming performance for the Thunderbolt™ variant.
To load a specific FPGA flavor, add the fpga device argument to the uhd_image_loader utility:
uhd_image_loader --args="type=b3xx,resource=<resource>,fpga=fifo"
If no FPGA flavor is specified, the default flavor will be programmed.
FPGA Resource Utilization
Utilization statistics are subject to change between UHD releases. This information is current as of UHD 4.11 and was taken directly from Xilinx Vivado 2021.1, targeting FPGA xc7k325t-fbg676-1.
The following table includes resource utilization for the replay FPGA bitfile.
Device utilization summary:
Number of Slice LUTs*: 124522 out of 203800 61.10 %
Number of LUT as Logic: 103305 out of 203800 50.69 %
Number of LUT as Memory: 21217 out of 64000 33.15 %
Number of LUT as Distributed RAM: 10316
Number of LUT as Shift Register: 10901
Number of Slice Registers: 184170 out of 407600 45.18 %
Number of Bonded IOB: 220 out of 400 55.00 %
Number of Block RAM Tile: 369.5 out of 445 83.03 %
Number of DSPs: 192 out of 840 22.86 %
The following table includes resource utilization for the fifo FPGA bitfile.
Number of Slice LUTs*: 105027 out of 203800 51.53 %
Number of LUT as Logic: 87703 out of 203800 43.03 %
Number of LUT as Memory: 17324 out of 64000 27.07 %
Number of LUT as Distributed RAM: 8150
Number of LUT as Shift Register: 9174
Number of Slice Registers: 163184 out of 407600 40.04 %
Number of Bonded IOB: 218 out of 400 54.50 %
Number of Block RAM Tile: 392.5 out of 445 88.20 %
Downloading ADRV9032R Firmware
The ADRV9032R has several binaries that must be programmed every UHD session. To acquire these binaries, the user can run the following command:
uhd_images_downloader --types b3xx
The files should be present in the directory pointed to by UHD_IMAGES_DIR or the default UHD images location.
Using a B3xx USRP from UHD
Like any other USRP, the B310 is controlled by the UHD software. To create a device handle in C++:
auto usrp = uhd::usrp::multi_usrp::make("type=b3xx");
Device arguments
Key Description Example Value
type Device type filter type=b3xx
resource PCIe resource identifier resource=nib310rio0
master_clock_rate Master clock rate used by the device (default: 122.88e6) master_clock_rate=122.88e6
system_ref_rate External reference clock frequency in Hz (default: 10e6) system_ref_rate=10e6
clock_source Reference clock source (see Setup Clocking) clock_source=internal
time_source Time/PPS source (see Setup Clocking) time_source=internal
init_cals ADRV9032 initialization calibration selection init_cals=DEFAULT
tracking_cals ADRV9032 tracking calibration selection tracking_cals=DEFAULT
Setup Clocking
Master clock rate
The B310 supports master clock rates of 122.88MHz and 125MHz. This rate cannot be changed at runtime.
Clock and time sources
The following clock sources and time sources are available:
Clock Source Description
internal Internal clocking chip, default
external External reference input (10 MHz, 122.88 MHz, or 125 MHz)
gpsdo Internal clocking chip disciplined by onboard GPS chip
sync High-frequency sync signal from sync cable (rate = master clock rate)
sync_gpsdo GPSDO-disciplined sync signal from sync cable (rate = master clock rate)
Time Source Description
internal Internal free-running timekeeper, default
external External PPS signal
gpsdo Timepulse from GPS chip
sync External PPS signal (meant for input via multi-device sync cable)
sync_gpsdo External PPS signal (meant for input via multi-device sync cable)
Valid clock/time source combinations:
Clock Source Time Source
internal internal
external internal
external external
external sync
external sync_gpsdo
gpsdo gpsdo
sync sync
sync_gpsdo sync_gpsdo
If the external reference clock is not 10 MHz, provide the system_ref_rate device arg. If using the sync, or sync_gpsdo clock source, you do not need to provide the system_ref_rate device arg, since it will be the rate of the master_clock_rate
To use an external reference:
auto usrp = uhd::usrp::multi_usrp::make("type=b3xx,clock_source=external");
Multi-Device Synchronization
Multiple B310 devices can be synchronized using a shared external clock and PPS signal. Connect each device to either the same 10 MHz reference and PPS source or via multi-device sync cable. Then, use clock_source=external and time_source=external if using a shared 10 MHz reference or clock_source=sync and time_source=sync if using the multi-device sync cable.
When all devices are configured with matching sync sources, the multi-device session will run the synchronization procedure automatically during initialization (resource names for the devices can be found via uhd_find_devices):
"resource0=<resource0>,resource1=<resource1>,clock_source=external,time_source=external");
This procedure must be run during initialization for the ADRV9032 transceiver chips to synchronize correctly. The cabling for the multi-device system must be connected before the session is initialized. For the 10MHz external reference clock, the setup is similar to other USRPs and is documented here: External PPS and 10 MHz reference signals. For USRP B310, a new method of synchronization was introduced using the SYNC port on the back of USRP B310 and a separate multi-device sync cable. The multi-device sync cable is a mini HDMI to eight SMA cable, four of those SMAs (PFI 0-3) carry a high-frequency reference clock (either 122.88MHz or 125MHz, depending on the session master clock rate) and the other four SMAs (PFI 4-7) carry a PPS signal exported from the B310 that is connected to the SYNC port. This can be used to synchronize up four B310s. Any of the four B310s can be used for the mini HDMI connection, but this connection must be setup before the UHD session is opened. A diagram can be seen below for connecting four B310s using the multi-device sync cable. NI recommends using the accessory '791010-01 - USRP MULTI DEVICE DIRECT SYNC CABLE, 0.3M', orderable through ni.com or your local sales representative. This cable breaks out the mini-HDMI (HDMI Type C) to 8x SMA.
Multi-Device Sync Cable Setup with Four B310s
Addressing the Device
Single device configuration
On Linux, UHD locates devices by scanning /sys/bus/pci/drivers/nib310rio/. The device resource key is the sysfs device identifier (e.g., an entry under the nib310rio subdirectory).
On Windows, UHD uses the Windows Device Manager to enumerate b310k driver devices and derives the resource from the PCIe bus:device:function location.
Typical UHD device address:
type=b3xx,resource=<resource string>
Multiple device configuration
Multiple B310 devices may be used simultaneously by specifying each device's resource. Use the uhd::usrp::multi_usrp interface with a combined device resource args:
type=b3xx,resource0=<resource string for device 0>,resource1=<resource string for device 1>
For multi-device synchronization, ensure all devices share an external clock and PPS signal (see Multi-Device Synchronization).
Hardware Notes
RF Hardware (ADRV9032)
The B310 uses an Analog Devices ADRV9032 transceiver.
  • Number of channels: 2 (2x2 MIMO)
  • TX antennas: TX/RX0
  • RX antennas: TX/RX0, RX1
  • TX gain range: 0.0 to 41.5 dB, step 0.05 dB
  • RX gain range: 0.0 to 36.0 dB, step 0.5 dB
  • TX/RX bandwidth: Fixed at 100 MHz
LO Configuration
Each channel has two LOs that can be set:
LO Name Sources Description
RFLO LO0, LO1 RF local oscillator from ADRV9032 synthesizer
NCO NCO Numerically-controlled frequency shifter
Since there are only two RFLOs and four channels, that means that channels will need to share RFLOs. By default, the two Rx channels share one LO, while the two Tx channels share the other LO. This means when you change the frequency of one channel, you will likely change the frequency of another.
Set the LO source using uhd::usrp::multi_usrp::set_rx_lo_source() or uhd::usrp::multi_usrp::set_tx_lo_source() with LO name "RFLO".
RF Calibrations
The ADRV9032 transceiver has built-in calibrations which can be enabled from UHD. A more detailed description of the calibrations can be found in the ADRV903x user guide, see section "ARM PROCESSOR AND DEVICE CALIBRATIONS".
Not all calibrations available on the ADRV9032R are applicable to the USRP B310. However, those calibrations that are applicable can be enabled/disabled at initialization time using the tracking_cals and init_cals device args (see also Device arguments). These can be set by using the following descriptive keys provided by UHD (e.g. init_cals=DEFAULT,tracking_cals=TX_QEC|RX_QEC). The | symbol can be used to combine keys (equivalent to a bitwise OR).
Key (init_cal) Function
RX_DC_OFFSET Corrects for DC Offset within the receiver chain
ADC_RX Calibrates the receiver ADC
ADC_ORX Calibrates the observation receiver ADC
ADC_TXLB Calibrates the Tx loopback receiver ADC
TXDAC Calibrates the transmitter DAC
TXBBF Tunes the corner frequency of the transmitter filter
TXLB_FILTER Tx Loopback filter calibration
TXLB_PATH_DLY Computes the transmitter to internal loopback path delay, which is required for the TxQEC initial calibration and tracking
TX_ATTEN_CAL Tx atten phase/gain calibration
HRM Performs HRM (harmonic reject mixer) harmonics rejection corrections
TXQEC Performs an initial QEC calibration for the transmitter path. It utilizes the transmitter path and an internal loopback path
TXLOL Performs an initial LO leakage calibration for the transmitter path. Utilizes the transmitter path and the internal loopback path
Key (tracking_cal) Function
RX_QEC RxQEC Tracking calibration
RX_ADC Rx ADC Tracking calibration
RXSPUR RxSpur Tracking calibration
TX_QEC TxQEC Tracking calibration
TX_LB_ADC TxLB ADC Tracking calibration
Blackout Frequency Avoidance
If Tx QEC tracking calibrations are active, there are ranges of frequency that must be avoided due to being within 1 MHz of blackout frequencies. This is detailed in the "Tx QEC Tracking Calibration Frequency Planning" section of the ADRV903x user guide. However, note that because of the initial frequencies used by the B310, the sampling frequency that needs to be used is the sampling rate of the LBADC rather than the Tx DAC sampling rate. This blackout avoidance will be triggered anytime that the uhd::usrp::multi_usrp::set_tx_freq() or uhd::usrp::multi_usrp::set_rx_freq() is called with a value within 1 MHz of any blackout frequencies. This works by adjusting the RFLO to a frequency that is at least 1 MHz away from all blackout frequencies and the NCO is used to account for the shift, such that the overall frequency is where the user requested.
This blackout avoidance can be avoided by calling the uhd::usrp::multi_usrp::set_tx_lo_freq() or uhd::usrp::multi_usrp::set_rx_lo_freq() to set the frequency of a specific LO. If the RFLO is set to a frequency that is within 1 MHz of a blackout frequency, a warning will be printed, but the blackout avoidance algorithm will not be triggered.
Front Panel GPIO
The B310 has a front-panel mini HDMI GPIO connector accessible on the front panel of the device. Users can utilize these pins with the UHD GPIO API. (see GPIO API).
Each pin can be freely programmed or track the ATR register of either radio channel.
The mini HDMI connector has 19 pins, 10 of these pins can be used through the UHD GPIO API. The pin mapping can be seen below:
Pin Mapping
  • Pin 1: GND
  • Pin 2: Data[8]
  • Pin 3: GND
  • Pin 4: GND
  • Pin 5: Data[9]
  • Pin 6: GND
  • Pin 7: GND
  • Pin 8: Data[0]
  • Pin 9: Data[1]
  • Pin 10: GND
  • Pin 11: Data[2]
  • Pin 12: Data[3]
  • Pin 13: GND
  • Pin 14: Data[4]
  • Pin 15: Data[5]
  • Pin 16: Data[6]
  • Pin 17: Data[7]
  • Pin 18: +3.3V
  • Pin 19: GND
Available Sensors
The following sensors are available and can be queried through the UHD API:
Motherboard sensors:
  • pcie_max_speed - maximum PCIe link speed, in GT/s
  • pcie_negotiated_speed - actual PCIe link speed, in GT/s
  • pcie_max_width - maximum PCIe link width, in lanes
  • pcie_negotiated_width - actual PCIe link width, in lanes
  • ref_locked - clock reference locked
  • ref_stable - clock reference has remained stable
  • temp_middle - temperature of the board middle zone, in degrees Celsius
  • temp_pcie_connector_edge - temperature at the PCIe connector edge, in degrees Celsius
  • temp_front_end - temperature of the RF front end, in degrees Celsius
  • temp_fpga - temperature of the FPGA, in degrees Celsius
  • input_voltage - input supply voltage, in volts
  • input_power - input power consumption, in watts
  • input_current - input current draw, in amperes
  • lmk05318_priref_valid - LMK05318 primary reference is valid
  • gps_pps_present - GPS PPS signal is present
GPS sensors (when clock_source is set to gpsdo or sync_gpsdo):
  • gps_locked - GPS is locked to satellites
  • gps_gpgga - GPGGA string from the GPS module
  • gps_time - GPS time in seconds since the epoch
  • gps_gprmc - GPRMC string from the GPS module
  • gps_lmk04832_lock - LMK04832 is locked
  • gps_lmk05318_dpll_freq_lock - LMK05318 DPLL frequency is locked
  • gps_lmk05318_dpll_phase_lock - LMK05318 DPLL phase is locked
Per-channel RF sensors:
  • lo_locked - RF local oscillator locked
  • temp_rfic - temperature of the RFIC, in degrees Celsius
Host-USRP Streaming
The B310 can stream up to two receive and two transmit channels through its PCIe or Thunderbolt™ host interface. The maximum sustainable rate depends on the PCIe link, transport path, operating system, FPGA image, and host CPU configuration.
Unless stated otherwise, all streaming results in this section were obtained using the default replay FPGA bitfile.
Executing benchmark_rate over multiple iterations and extended continuous periods without data loss resulted in the following maximum rates and channel counts. Maximum performance was achieved with the following settings:
  • The --multi_streamer argument for multi-channel benchmarks. This assigns a separate streamer thread to each channel being streamed.
Desktop Linux
Recommended Desktop Host PC
  • At least 8 logical CPUs
  • At least 32 GB RAM
  • Ubuntu 22.04 or newer
  • Linux kernel version 6.2 or newer with matching kernel headers
  • PCIe Gen2 x4 slot or a slot with greater electrical capability
Verify the negotiated link using the pcie_negotiated_speed and pcie_negotiated_width sensors, and compare them with pcie_max_speed and pcie_max_width. The usrp_list_sensors application can be used to list these and other B310 sensors:
usrp_list_sensors --args="type=b3xx,resource=<resource>"
Validated Hardware and Software Configurations
The direct-PCIe results were validated on x86_64 desktop systems with the following representative configurations:
  • AMD system with a Ryzen Threadripper 3960X, 24 physical cores, 48 CPUs, 3.6 GHz, and 64 GB RAM.
  • ASUSTeK COMPUTER INC. X99-A system with an Intel Core i7-5930K, 6 physical cores, 12 logical CPUs, 3.50 GHz, and 32 GB RAM.
  • Lenovo system with an Intel Xeon E5-1630 v4, 4 physical cores, 8 logical CPUs, 3.70 GHz, and 32 GB RAM.
  • HP system with a 13th Gen Intel Core i9-13900K, 8 physical performance cores, 16 logical CPUs, and 32 GB RAM.
The direct-PCIe results on the tested x86_64 desktop systems were:
Configuration Rate
1 Rx or 1 Tx 125 MS/s
2 Rx or 2 Tx 125 MS/s
1 Rx + 1 Tx 125 MS/s
2 Rx + 2 Tx 125 MS/s
Use benchmark_rate to test the complete host-to-USRP path. For example:
benchmark_rate --args="type=b3xx,resource=<resource>,master_clock_rate=125e6" --channels=0,1 --rx_rate=125e6 --tx_rate=125e6 --multi_streamer
For repeatable measurements, use the CPU performance governor, close unnecessary applications, and run multiple long-duration iterations. If a test does not sustain, repeat it at half rate to distinguish a host scheduling or transport limitation from an RF configuration problem.
Linux Thunderbolt™
Recommended Thunderbolt™ Host
Minimum requirements for reliable high-rate Thunderbolt™ streaming:
  • At least 16 GB RAM
  • Thunderbolt™ 3 or newer port with PCIe tunneling enabled
  • bolt package installed and configured when device authorization is required
The Thunderbolt™ variant presents the B310 PCIe interface through a tunneled PCIe connection. Use a certified Thunderbolt™ cable, a Thunderbolt™-capable host port, and the external power connection. A USB-C port that supports only USB cannot enumerate the device. On Linux, authorize the device when required:
boltctl list
boltctl authorize <uuid>
Use boltctl enroll --policy auto <uuid> to authorize it automatically on future connections. Confirm enumeration before starting UHD:
For the Thunderbolt™ variant, the fifo FPGA image uses the B310 DRAM as a buffer and is intended to improve streaming performance by some extent:
The Thunderbolt™ results below were obtained with the default replay FPGA bitfile, not the optional fifo image.
The Linux Thunderbolt™ results were validated on the following laptop configurations using the default replay FPGA bitfile:
  • Dell Latitude 7420 running Ubuntu 24.04.4 LTS.
  • ASUS Zenbook UX3405C running Ubuntu 26.04 LTS.
  • MSI Summit 13 AI+ EVO running Ubuntu 24.04 LTS.
  • Dell Latitude 5550 running Fedora 44.
Configuration Rate
2 Rx 125 MS/s
2 Tx 62.5 MS/s
1 Rx + 1 Tx 62.5 MS/s
2 Rx + 2 Tx 31.25 MS/s
Jetson AGX Orin Linux
The Jetson AGX Orin configuration consists of an ARM64 system with 12 ARM Cortex-A78AE cores and 64 GB RAM. The system runs Jetson Linux R36.4.4 (L4T 36.4.4) with the B310 connected through the PCIe slot. The PCIe results using the default replay FPGA bitfile were:
Configuration Rate
The following optimizations can improve sustained Jetson performance and can be used if needed:
  • Add pci=pcie_bus_perf to the APPEND entry in /boot/extlinux/extlinux.conf, then reboot. Confirm the argument with cat /proc/cmdline and inspect the negotiated MPS with lspci. On the tested system this selected an MPS of 256.
  • Set all CPU cores to the performance governor:
    for ((i=0;i<$(nproc);i++)); do sudo cpufreq-set -c $i -r -g performance; done
  • Stop non-essential services while benchmarking:
    sudo systemctl stop gdm
    sudo systemctl stop docker
    sudo systemctl stop docker.socket
    sudo systemctl stop containerd
  • Confirm all cores are online with cat /sys/devices/system/cpu/online and bring an offline core online, replacing X with its core number:
    echo 1 | sudo tee /sys/devices/system/cpu/cpuX/online
  • Select the highest power mode and lock the clocks:
    sudo nvpmodel -m 0
    sudo jetson_clocks
  • Set the --priority argument to high. This requires benchmark_rate to be executed with suitable privileges, for example using sudo. On some systems, assigning high priority to multiple threads in the UHD streaming application can cause unintended consequences because the threads contend for CPU and other system resources. The effect is system-dependent, so compare results with and without this option when troubleshooting.
Miscellaneous
Timed Commands
The B310 supports Timed Commands the same way as other USRPs. Timed sampling and timed command dispatch are handled in the FPGA.
GPS
The B310 includes a UBLOX GPS chip. When the B310 has access to GPS satellite signals, it can use this module to read out the current GPS time and location as well as to discipline an onboard clocking chip.
To use the GPS as clock and time source:
// Set clock and time source individually:
usrp->set_clock_source("gpsdo");
usrp->set_time_source("gpsdo");
// Or equivalently (faster, avoids redundant internal operations):
usrp->set_sync_source("clock_source=gpsdo,time_source=gpsdo");
Note that acquiring a GPS lock can take some time. Query the gps_locked motherboard sensor before depending on GPS timing accuracy. The GPS chip sends a timepulse signal to an internal clocking chip to discipline the clocking on the B310. The DPLL of this clocking chip can take some time to lock to this timepulse. Query the ref_locked motherboard sensor while the clock source is set to gpsdo or sync_gpsdo to determine if the DPLL of the clocking chip has locked to the timepulse signal sent by the GPS chip. See Available Sensors for all available GPS-related sensors.
Subdev Specifications
The B310 has a single radio slot (A) with two RF channels. The following subdev specifications are available:
Channel Subdev Spec
Channel 0 A:0
Channel 1 A:1
Troubleshooting
Driver not loaded
If the device does not appear under /sys/bus/pci/drivers/nib310rio/ (Linux):
  1. Check that the module is loaded:
    lsmod | grep nib310rio
  2. If not, load it:
    sudo modprobe nib310rio
  3. Check dmesg for errors.
  4. If Secure Boot is enabled, the module must be signed. See your distribution's documentation on MOK (Machine Owner Key) enrollment, or disable Secure Boot in the UEFI/BIOS settings.
Poor performance
A PCIe slot that physically fits the B310 does not guarantee that link training will negotiate the maximum link speed and link width the B310 supports; for example, a slot may be physically larger than it is electrically wired. If the maximum is not achieved, UHD prints a warning when running an application. You can also query the pcie_negotiated_speed and pcie_negotiated_width sensors (and compare against pcie_max_speed and pcie_max_width).
Thunderbolt™ variant does not show up
The Thunderbolt™ variant is a PCI Express device whose PCIe link is tunneled over the Thunderbolt™ cable. Before UHD can see it, the host must enumerate it as a PCIe device, which requires the port, the cable, and the host's Thunderbolt™ security settings to all cooperate. If uhd_find_devices does not find the device, work through the following.
1. Verify the device has power
The Thunderbolt™ variant is powered by the external power connector, not by the Thunderbolt™ cable. Make sure the supplied power cable is connected to the USB-C power port (not the Thunderbolt™ port) and that the power LED on the front panel is lit. A device without power will never enumerate.
2. Verify the host port is Thunderbolt™-capable
Not every USB-C port supports Thunderbolt™. A USB-C port that only supports USB cannot tunnel PCIe and will not enumerate the B310. Look for a lightning bolt symbol next to the port, or a "4" for USB4 ports, and check the platform's documentation.
3. Verify the cable
Use a certified Thunderbolt™ cable. Many USB-C cables carry only power and USB data and will not pass PCIe traffic.
4. Approve (authorize) the Thunderbolt™ device
Because a tunneled PCIe device can perform DMA into host memory, most hosts ship with a Thunderbolt™ security level that requires the user to explicitly approve a newly connected device. Until it is approved, the device is visible to the Thunderbolt™ stack but is not enumerated on the PCIe bus, so UHD cannot see it.
Linux
Approval is handled by the bolt daemon and its boltctl command-line tool (install the bolt package if it is missing). List connected devices:
boltctl list
An unapproved device is reported with status: connected and authorized: no. Authorize it for the current session:
Or enroll it permanently, so it is automatically authorized on every future connection:
Windows
On systems with the Intel Thunderbolt™ software installed, connecting the B310 raises an "Approve Thunderbolt™ Devices" dialog. Select the B310 and choose Always Connect so it is approved automatically in the future. Approvals can be reviewed and changed later from the Thunderbolt™ Control Center (or the Thunderbolt™ Software application) in the "Attached Devices" view.
Newer Windows systems using native USB4/Thunderbolt™ support with kernel DMA protection approve devices automatically and show no dialog; in that case the device should appear directly in Device Manager.
5. Check the UEFI/BIOS settings
Several platform settings can prevent PCIe tunneling:
  • Thunderbolt™ security level: must be a level that allows PCIe tunneling. "DisplayPort only" or "USB only" will not work.
  • Thunderbolt™/USB4 support: must be enabled.
  • PCIe tunneling (sometimes listed separately, or as "Thunderbolt™ PCIe support"): must be enabled.
FPGA version mismatch
If initialization fails with an FPGA compatibility number error, first download the appropriate FPGA images:
Then update the FPGA image:
Device recovery and bricking
It is possible to put the device into an unusable state by loading bad images ("bricking"). Fortunately, the B310 device can be loaded with a good image temporarily using the JTAG interface. Once booted into the safe image, the user can once again load images onto the device using uhd_image_loader.
