19 #define UHD_RFNOC_BLOCK_REGISTER_FOR_DEVICE_DIRECT( \
20 CLASS_NAME, NOC_ID, DEVICE_ID, BLOCK_NAME, MB_ACCESS, TB_CLOCK, CTRL_CLOCK) \
21 uhd::rfnoc::noc_block_base::sptr CLASS_NAME##_make( \
22 uhd::rfnoc::noc_block_base::make_args_ptr make_args) \
24 return std::make_shared<CLASS_NAME##_impl>(std::move(make_args)); \
26 UHD_STATIC_BLOCK(register_rfnoc_##CLASS_NAME) \
28 uhd::rfnoc::registry::register_block_direct(NOC_ID, \
34 &CLASS_NAME##_make); \
37 #define UHD_RFNOC_BLOCK_REGISTER_DIRECT( \
38 CLASS_NAME, NOC_ID, BLOCK_NAME, TB_CLOCK, CTRL_CLOCK) \
39 UHD_RFNOC_BLOCK_REGISTER_FOR_DEVICE_DIRECT( \
40 CLASS_NAME, NOC_ID, ANY_DEVICE, BLOCK_NAME, false, TB_CLOCK, CTRL_CLOCK)
42 #define UHD_RFNOC_BLOCK_REGISTER_DIRECT_MB_ACCESS( \
43 CLASS_NAME, NOC_ID, BLOCK_NAME, TB_CLOCK, CTRL_CLOCK) \
44 UHD_RFNOC_BLOCK_REGISTER_FOR_DEVICE_DIRECT( \
45 CLASS_NAME, NOC_ID, ANY_DEVICE, BLOCK_NAME, true, TB_CLOCK, CTRL_CLOCK)
47 namespace uhd {
namespace rfnoc {
90 const std::string& block_name,
92 const std::string& timebase_clock,
93 const std::string& ctrlport_clock,
100 const std::string& block_name,
102 const std::string& timebase_clock,
103 const std::string& ctrlport_clock,
118 const std::string& block_key,
factory_t factory_fn);
std::unique_ptr< make_args_int_t, make_args_deleter > make_args_ptr
Opaque pointer to the constructor arguments with custom deleter.
Definition: noc_block_base.hpp:73
Definition: noc_block_base.hpp:44
Definition: registry.hpp:54
std::function< noc_block_base::sptr(noc_block_base::make_args_ptr)> factory_t
Definition: registry.hpp:56
static void register_block_direct(std::vector< noc_id_t > noc_ids, device_type_t device_id, const std::string &block_name, bool mb_access, const std::string &timebase_clock, const std::string &ctrlport_clock, factory_t factory_fn)
static void register_block_descriptor(const std::string &block_key, factory_t factory_fn)
static void register_block_direct(noc_id_t noc_id, device_type_t device_id, const std::string &block_name, bool mb_access, const std::string &timebase_clock, const std::string &ctrlport_clock, factory_t factory_fn)
Definition: config.h:87
uint16_t device_type_t
Device Type.
Definition: defaults.hpp:56
uint32_t noc_id_t
Definition: defaults.hpp:52
Definition: build_info.hpp:12
