sensors.hpp
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <map>
12 #include <string>
13
14 namespace uhd {
15
29 {
30  typedef std::map<std::string, std::string> sensor_map_t;
31
39  sensor_value_t(const std::string& name,
40  bool value,
41  const std::string& utrue,
42  const std::string& ufalse);
43
51  sensor_value_t(const std::string& name,
52  signed value,
53  const std::string& unit,
54  const std::string& formatter = "%d");
55
63  sensor_value_t(const std::string& name,
64  double value,
65  const std::string& unit,
66  const std::string& formatter = "%f");
67
75  const std::string& name, const std::string& value, const std::string& unit);
76
85  sensor_value_t(const std::map<std::string, std::string>& sensor_dict);
86
92
94  bool to_bool(void) const;
95
97  signed to_int(void) const;
98
100  double to_real(void) const;
101
103  sensor_map_t to_map(void) const;
104
106  std::string name;
107
113  std::string value;
114
120  std::string unit;
121
123  enum data_type_t { BOOLEAN = 'b', INTEGER = 'i', REALNUM = 'r', STRING = 's' };
124
127
129  std::string to_pp_string(void) const;
130
133 };
134
135 } // namespace uhd
Definition: config.h:87
source
Identify the source of calibration data, i.e., where was it stored.
Definition: database.hpp:23
Definition: build_info.hpp:12
Definition: sensors.hpp:29
convert the sensor value to a boolean
data_type_t
Enumeration of possible data types in a sensor.
Definition: sensors.hpp:123
convert the sensor value to an integer
convert the sensor value to real number
sensor_value_t(const std::string &name, signed value, const std::string &unit, const std::string &formatter="%d")
std::map< std::string, std::string > sensor_map_t
Definition: sensors.hpp:30
sensor_value_t & operator=(const sensor_value_t &value)
Assignment operator for sensor value.
sensor_value_t(const std::string &name, const std::string &value, const std::string &unit)
sensor_value_t(const std::string &name, bool value, const std::string &utrue, const std::string &ufalse)
std::string value
Definition: sensors.hpp:113
sensor_value_t(const sensor_value_t &source)
convert the sensor value to sensor_map_t
sensor_value_t(const std::string &name, double value, const std::string &unit, const std::string &formatter="%f")
std::string name
The name of the sensor value.
Definition: sensors.hpp:106
sensor_value_t(const std::map< std::string, std::string > &sensor_dict)
data_type_t type
The data type of the value.
Definition: sensors.hpp:126
Convert this sensor value into a printable string.
std::string unit
Definition: sensors.hpp:120
