#include <uhd/rfnoc/sink_node_ctrl.hpp>
| size_t | connect_upstream (node_ctrl_base::sptr upstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t()) |
| virtual void | set_tx_streamer (bool active, const size_t port) |
| virtual std::string | unique_id () const |
| | Returns a unique string that identifies this block. More...
| virtual void | clear () |
| node_map_t | list_downstream_nodes () |
| node_map_t | list_upstream_nodes () |
| void | set_downstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_downstream_port (const size_t this_port) |
| void | set_upstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_upstream_port (const size_t this_port) |
| template<typename T > |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_downstream_node () |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_upstream_node () |
| template<typename T , typename value_type > |
| UHD_INLINE value_type | find_downstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
| UHD_INLINE value_type | find_upstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
◆ node_map_pair_t
◆ node_map_t
◆ sptr
◆ _request_input_port()
| virtual size_t uhd::rfnoc::sink_node_ctrl::_request_input_port |
const size_t |
suggested_port, |
const uhd::device_addr_t & |
args |
| const |
protectedvirtual |
Ask for a port number to connect an upstream block to.
Typically, this will be overridden for custom behaviour. The default is to return the suggested port, disregarding args, unless port == ANY_PORT, in which case the first unused input port is returned.
When deriving this function for custom behaviour, consider:
- The result is used to call register_upstream_node(), which has its own checks in place.
- This function may throw if the arguments can't be resolved. The exception will propagate to the user space.
- Alternatively, the function may return ANY_PORT to signify failure.
args and suggested_port should be treated as strong suggestions, but there's no reason to just return any valid port.
Note: For reasons of thread safety, it is recommended to never, ever call this function directly. It will be used by connect_upstream() which will handle the connection process in a thread-safe manner.
- Parameters
| suggested_port | Try and connect here. |
| args | When deciding on a port number, these arguments may be used. |
- Returns
- A valid input port, or ANY_PORT on failure.
Reimplemented in uhd::rfnoc::sink_block_ctrl_base.
◆ connect_upstream()
Connect another node upstream of this node.
Note: If additional settings are required to make this connection work, e.g. configure flow control, these need to be done separately.
If the requested connection is not possible, this function will throw.
upstream_node Pointer to the node class to connect port Suggested port number on this block to connect the upstream block to. args Any arguments that can be useful for determining the port number.
- Returns
- The actual port number used.
◆ set_tx_streamer()
| virtual void uhd::rfnoc::sink_node_ctrl::set_tx_streamer |
bool |
active, |
const size_t |
port |
virtual |
Call this function to notify a node about its streamer activity.
When active is set to true, this means this block is now part of an active tx streamer chain. Conversely, when set to false, this means the node has been removed from an tx streamer chain.
◆ _tx_streamer_active
| std::map<size_t, bool> uhd::rfnoc::sink_node_ctrl::_tx_streamer_active |
protected |
For every input port, store tx streamer activity.
If _tx_streamer_active[0] == true, this means that an active tx streamer is operating on port 0. If it is false, or if the entry does not exist, there is no streamer. Values are toggled by set_tx_streamer().
