sink_block_ctrl_base.hpp
18 #ifndef INCLUDED_LIBUHD_TX_BLOCK_CTRL_BASE_HPP
19 #define INCLUDED_LIBUHD_TX_BLOCK_CTRL_BASE_HPP
23
24 namespace uhd {
25  namespace rfnoc {
26
36 class sink_block_ctrl_base : virtual public block_ctrl_base, virtual public sink_node_ctrl
37 {
38 public:
39  typedef boost::shared_ptr<sink_block_ctrl_base> sptr;
40
41  /***********************************************************************
42  * Stream signatures
43  **********************************************************************/
54  stream_sig_t get_input_signature(size_t block_port=0) const;
55
58  std::vector<size_t> get_input_ports() const;
59
60  /***********************************************************************
61  * FPGA Configuration
62  **********************************************************************/
75  size_t get_fifo_size(size_t block_port=0) const;
76
94  virtual void configure_flow_control_in(
95  size_t cycles,
96  size_t packets,
97  size_t block_port=0
98  );
99
105  virtual void set_error_policy(
106  const std::string &policy
107  );
108
109 protected:
110  /***********************************************************************
111  * Hooks
112  **********************************************************************/
116  virtual size_t _request_input_port(
117  const size_t suggested_port,
118  const uhd::device_addr_t &args
119  ) const;
120
121 }; /* class sink_block_ctrl_base */
122
123 }} /* namespace uhd::rfnoc */
124
125 #endif /* INCLUDED_LIBUHD_TX_BLOCK_CTRL_BASE_HPP */
126 // vim: sw=4 et:
virtual size_t _request_input_port(const size_t suggested_port, const uhd::device_addr_t &args) const
Definition: sink_block_ctrl_base.hpp:36
Definition: block_ctrl_base.hpp:106
Definition: build_info.hpp:25
#define UHD_RFNOC_API
Definition: config.hpp:103
Definition: sink_node_ctrl.hpp:34
boost::shared_ptr< sink_block_ctrl_base > sptr
Definition: sink_block_ctrl_base.hpp:39
virtual void configure_flow_control_in(size_t cycles, size_t packets, size_t block_port=0)
virtual void set_error_policy(const std::string &policy)
Definition: stream_sig.hpp:33
std::vector< size_t > get_input_ports() const
