source_block_ctrl_base.hpp
18 #ifndef INCLUDED_LIBUHD_RX_BLOCK_CTRL_BASE_HPP
19 #define INCLUDED_LIBUHD_RX_BLOCK_CTRL_BASE_HPP
23
24 namespace uhd {
25  namespace rfnoc {
26
35 class source_block_ctrl_base : virtual public block_ctrl_base, virtual public source_node_ctrl
36 {
37 public:
38  typedef boost::shared_ptr<source_block_ctrl_base> sptr;
39
40  /***********************************************************************
41  * Streaming operations
42  **********************************************************************/
64  virtual void issue_stream_cmd(const uhd::stream_cmd_t &stream_cmd, const size_t chan=0);
65
66  /***********************************************************************
67  * Stream signatures
68  **********************************************************************/
79  stream_sig_t get_output_signature(size_t block_port=0) const;
80
83  std::vector<size_t> get_output_ports() const;
84
85  /***********************************************************************
86  * FPGA Configuration
87  **********************************************************************/
97  virtual void set_destination(
98  boost::uint32_t next_address,
99  size_t output_block_port = 0
100  );
101
116  virtual void configure_flow_control_out(
117  size_t buf_size_pkts,
118  size_t block_port=0,
119  const uhd::sid_t &sid=uhd::sid_t()
120  );
121
122
123 protected:
124  /***********************************************************************
125  * Hooks
126  **********************************************************************/
130  virtual size_t _request_output_port(
131  const size_t suggested_port,
132  const uhd::device_addr_t &args
133  ) const;
134
135 }; /* class source_block_ctrl_base */
136
137 }} /* namespace uhd::rfnoc */
138
139 #endif /* INCLUDED_LIBUHD_RX_BLOCK_CTRL_BASE_HPP */
140 // vim: sw=4 et:
Definition: stream_cmd.hpp:46
virtual void configure_flow_control_out(size_t buf_size_pkts, size_t block_port=0, const uhd::sid_t &sid=uhd::sid_t())
Definition: source_node_ctrl.hpp:34
Definition: block_ctrl_base.hpp:106
virtual void set_destination(boost::uint32_t next_address, size_t output_block_port=0)
Definition: build_info.hpp:25
#define UHD_RFNOC_API
Definition: config.hpp:103
Definition: source_block_ctrl_base.hpp:35
Represents a stream ID (SID).
Definition: sid.hpp:78
virtual size_t _request_output_port(const size_t suggested_port, const uhd::device_addr_t &args) const
std::vector< size_t > get_output_ports() const
boost::shared_ptr< source_block_ctrl_base > sptr
Definition: source_block_ctrl_base.hpp:38
Definition: stream_sig.hpp:33
