UHD  003.004.003-0-g461eb1c7
Public Types | Public Member Functions | Static Public Member Functions | List of all members
uhd::device Class Referenceabstract
#include <device.hpp>
Inheritance diagram for uhd::device:
typedef boost::shared_ptr< devicesptr
typedef boost::function< device_addrs_t(const device_addr_t &)> find_t
typedef boost::function< sptr(const device_addr_t &)> make_t
 Make a new receive streamer from the streamer arguments. More...
 Make a new transmit streamer from the streamer arguments. More...
virtual boost::shared_ptr< property_treeget_tree (void) const =0
 Get access to the underlying property structure. More...
static void register_device (const find_t &find, const make_t &make)
static device_addrs_t find (const device_addr_t &hint)
 Find usrp devices attached to the host. More...
static sptr make (const device_addr_t &hint, size_t which=0)
 Create a new usrp device from the device address hint. More...
The usrp device interface represents the usrp hardware. The api allows for discovery, configuration, and streaming.
◆ find_t
typedef boost::function<device_addrs_t(const device_addr_t &)> uhd::device::find_t
◆ make_t
typedef boost::function<sptr(const device_addr_t &)> uhd::device::make_t
typedef boost::shared_ptr<device> uhd::device::sptr
◆ find()
static device_addrs_t uhd::device::find ( const device_addr_t hint)
The hint device address should be used to narrow down the search to particular transport types and/or transport arguments.
hinta partially (or fully) filled in device address
a vector of device addresses for all usrps on the system
◆ get_rx_stream()
virtual rx_streamer::sptr uhd::device::get_rx_stream ( const stream_args_t args)
◆ get_tree()
virtual boost::shared_ptr<property_tree> uhd::device::get_tree ( void  ) const
◆ get_tx_stream()
virtual tx_streamer::sptr uhd::device::get_tx_stream ( const stream_args_t args)
◆ make()
static sptr uhd::device::make ( const device_addr_t hint,
size_t  which = 0
The make routine will call find and pick one of the results. By default, the first result will be used to create a new device. Use the which parameter as an index into the list of results.
whichwhich address to use when multiple are found
a shared pointer to a new device instance
◆ recv_async_msg()
virtual bool uhd::device::recv_async_msg ( async_metadata_t async_metadata,
double  timeout = 0.1
Receive and asynchronous message from the device.
◆ register_device()
static void uhd::device::register_device ( const find_t find,
const make_t make
Register a device into the discovery and factory system.
finda function that discovers devices
makea factory function that makes a device
