uhd::niusrprio::niriok_proxy Class Referenceabstract
#include <uhd/transport/nirio/niriok_proxy.h>
Inheritance diagram for uhd::niusrprio::niriok_proxy:
uhd::niusrprio::niriok_proxy_impl_v1 uhd::niusrprio::niriok_proxy_impl_v2
Classes
struct  nirio_ioctl_packet_t
typedef boost::shared_ptr< niriok_proxysptr
 niriok_proxy ()
virtual ~niriok_proxy ()
virtual nirio_status open (const std::string &interface_path)=0
virtual void close (void)=0
virtual nirio_status reset ()=0
uint32_t get_interface_num ()
virtual nirio_status get_cached_session (uint32_t &session)=0
virtual nirio_status get_version (nirio_version_t type, uint32_t &major, uint32_t &upgrade, uint32_t &maintenance, char &phase, uint32_t &build)=0
virtual nirio_status get_attribute (const nirio_device_attribute32_t attribute, uint32_t &attrValue)=0
virtual nirio_status set_attribute (const nirio_device_attribute32_t attribute, const uint32_t value)=0
virtual nirio_status peek (uint32_t offset, uint32_t &value)=0
virtual nirio_status peek (uint32_t offset, uint64_t &value)=0
virtual nirio_status poke (uint32_t offset, const uint32_t &value)=0
virtual nirio_status poke (uint32_t offset, const uint64_t &value)=0
virtual nirio_status map_fifo_memory (uint32_t fifo_instance, size_t size, nirio_driver_iface::rio_mmap_t &map)=0
virtual nirio_status unmap_fifo_memory (nirio_driver_iface::rio_mmap_t &map)=0
virtual nirio_status stop_all_fifos ()=0
nirio_quirksget_rio_quirks ()
virtual nirio_status add_fifo_resource (const nirio_fifo_info_t &fifo_info)=0
virtual nirio_status set_device_config ()=0
virtual nirio_status start_fifo (uint32_t channel)=0
virtual nirio_status stop_fifo (uint32_t channel)=0
virtual nirio_status configure_fifo (uint32_t channel, uint32_t requested_depth, uint8_t requires_actuals, uint32_t &actual_depth, uint32_t &actual_size)=0
virtual nirio_status wait_on_fifo (uint32_t channel, uint32_t elements_requested, uint32_t scalar_type, uint32_t bit_width, uint32_t timeout, uint8_t output, void *&data_pointer, uint32_t &elements_acquired, uint32_t &elements_remaining)=0
virtual nirio_status grant_fifo (uint32_t channel, uint32_t elements_to_grant)=0
virtual nirio_status read_fifo (uint32_t channel, uint32_t elements_to_read, void *buffer, uint32_t buffer_datatype_width, uint32_t scalar_type, uint32_t bit_width, uint32_t timeout, uint32_t &number_read, uint32_t &number_remaining)=0
virtual nirio_status write_fifo (uint32_t channel, uint32_t elements_to_write, void *buffer, uint32_t buffer_datatype_width, uint32_t scalar_type, uint32_t bit_width, uint32_t timeout, uint32_t &number_remaining)=0
static sptr make_and_open (const std::string &interface_path)
virtual void _close ()=0
Protected Attributes
nirio_driver_iface::rio_dev_handle_t _device_handle
uint32_t _interface_num
nirio_quirks _rio_quirks
Static Protected Attributes
static boost::shared_mutex _synchronization
◆ niriok_proxy()
uhd::niusrprio::niriok_proxy::niriok_proxy ( )
◆ ~niriok_proxy()
virtual uhd::niusrprio::niriok_proxy::~niriok_proxy ( )
virtual
◆ _close()
virtual void uhd::niusrprio::niriok_proxy::_close ( )
protectedpure virtual
◆ add_fifo_resource()
virtual nirio_status uhd::niusrprio::niriok_proxy::add_fifo_resource ( const nirio_fifo_info_t fifo_info)
◆ close()
virtual void uhd::niusrprio::niriok_proxy::close ( void  )
◆ configure_fifo()
virtual nirio_status uhd::niusrprio::niriok_proxy::configure_fifo ( uint32_t  channel,
uint32_t &  actual_depth,
uint32_t &  actual_size
◆ get_attribute()
virtual nirio_status uhd::niusrprio::niriok_proxy::get_attribute ( const nirio_device_attribute32_t  attribute,
uint32_t &  attrValue
◆ get_cached_session()
virtual nirio_status uhd::niusrprio::niriok_proxy::get_cached_session ( uint32_t &  session)
◆ get_interface_num()
uint32_t uhd::niusrprio::niriok_proxy::get_interface_num ( )
◆ get_rio_quirks()
nirio_quirks& uhd::niusrprio::niriok_proxy::get_rio_quirks ( )
◆ get_version()
virtual nirio_status uhd::niusrprio::niriok_proxy::get_version ( nirio_version_t  type,
uint32_t &  major,
uint32_t &  upgrade,
uint32_t &  maintenance,
char &  phase,
uint32_t &  build
◆ grant_fifo()
virtual nirio_status uhd::niusrprio::niriok_proxy::grant_fifo ( uint32_t  channel,
◆ make_and_open()
static sptr uhd::niusrprio::niriok_proxy::make_and_open ( const std::string &  interface_path)
◆ map_fifo_memory()
virtual nirio_status uhd::niusrprio::niriok_proxy::map_fifo_memory ( uint32_t  fifo_instance,
size_t  size,
nirio_driver_iface::rio_mmap_t map
◆ open()
virtual nirio_status uhd::niusrprio::niriok_proxy::open ( const std::string &  interface_path)
◆ peek() [1/2]
virtual nirio_status uhd::niusrprio::niriok_proxy::peek ( uint32_t  offset,
uint32_t &  value
◆ peek() [2/2]
uint64_t &  value
◆ poke() [1/2]
virtual nirio_status uhd::niusrprio::niriok_proxy::poke ( uint32_t  offset,
const uint32_t &  value
◆ poke() [2/2]
const uint64_t &  value
◆ read_fifo()
virtual nirio_status uhd::niusrprio::niriok_proxy::read_fifo ( uint32_t  channel,
void *  buffer,
uint32_t  bit_width,
uint32_t  timeout,
uint32_t &  number_read,
uint32_t &  number_remaining
◆ reset()
virtual nirio_status uhd::niusrprio::niriok_proxy::reset ( )
◆ set_attribute()
virtual nirio_status uhd::niusrprio::niriok_proxy::set_attribute ( const nirio_device_attribute32_t  attribute,
◆ set_device_config()
virtual nirio_status uhd::niusrprio::niriok_proxy::set_device_config ( )
◆ start_fifo()
virtual nirio_status uhd::niusrprio::niriok_proxy::start_fifo ( uint32_t  channel)
◆ stop_all_fifos()
virtual nirio_status uhd::niusrprio::niriok_proxy::stop_all_fifos ( )
◆ stop_fifo()
virtual nirio_status uhd::niusrprio::niriok_proxy::stop_fifo ( uint32_t  channel)
◆ unmap_fifo_memory()
virtual nirio_status uhd::niusrprio::niriok_proxy::unmap_fifo_memory ( nirio_driver_iface::rio_mmap_t map)
◆ wait_on_fifo()
virtual nirio_status uhd::niusrprio::niriok_proxy::wait_on_fifo ( uint32_t  channel,
uint32_t  bit_width,
uint32_t  timeout,
uint8_t  output,
void *&  data_pointer,
uint32_t &  elements_acquired,
uint32_t &  elements_remaining
◆ write_fifo()
virtual nirio_status uhd::niusrprio::niriok_proxy::write_fifo ( uint32_t  channel,
void *  buffer,
uint32_t  bit_width,
uint32_t  timeout,
◆ _device_handle
nirio_driver_iface::rio_dev_handle_t uhd::niusrprio::niriok_proxy::_device_handle
◆ _interface_num
uint32_t uhd::niusrprio::niriok_proxy::_interface_num
◆ _rio_quirks
nirio_quirks uhd::niusrprio::niriok_proxy::_rio_quirks
◆ _synchronization
boost::shared_mutex uhd::niusrprio::niriok_proxy::_synchronization
staticprotected
