niriok_proxy.h File Reference
#include <stdint.h>
#include <boost/smart_ptr.hpp>
#include <boost/noncopyable.hpp>
#include <boost/thread/shared_mutex.hpp>
#include <boost/thread/locks.hpp>
#include <uhd/transport/nirio/nirio_driver_iface.h>
#include <uhd/transport/nirio/nirio_quirks.h>
Classes
struct  uhd::niusrprio::nirio_fifo_info_t
class  uhd::niusrprio::niriok_proxy
struct  uhd::niusrprio::niriok_proxy::nirio_ioctl_packet_t
class  uhd::niusrprio::niriok_scoped_addr_space
Namespaces
 uhd
 uhd::niusrprio
Macros
#define NI_VENDOR_NUM   0x1093
#define VERSION_BUILD_SHIFT   0
#define VERSION_PHASE_SHIFT   14
#define VERSION_MAINT_SHIFT   16
#define VERSION_UPGRD_SHIFT   20
#define VERSION_MAJOR_SHIFT   24
#define VERSION_BUILD_MASK   0x00003FFF
#define VERSION_PHASE_MASK   0x0000C000
#define VERSION_MAINT_MASK   0x000F0000
#define VERSION_UPGRD_MASK   0x00F00000
#define VERSION_MAJOR_MASK   0xFF000000
#define GET_FIFO_MEMORY_TYPE(fifo_inst)   (static_cast<uint16_t>(0x0100 | static_cast<uint16_t>(fifo_inst)))
#define READER_LOCK   boost::shared_lock<boost::shared_mutex> reader_lock(_synchronization);
#define WRITER_LOCK
Typedefs
typedef uint64_t uhd::niusrprio::nirio_u64_t
typedef uint32_t uhd::niusrprio::nirio_u32_t
typedef uint16_t uhd::niusrprio::nirio_u16_t
typedef uint8_t uhd::niusrprio::nirio_u8_t
typedef int32_t uhd::niusrprio::nirio_i32_t
Enumerations
enum  uhd::niusrprio::nirio_version_t { uhd::niusrprio::CURRENT, uhd::niusrprio::OLDEST_COMPATIBLE }
enum  uhd::niusrprio::nirio_addr_space_t { uhd::niusrprio::INVALID = 0, uhd::niusrprio::BUS_INTERFACE = 1, uhd::niusrprio::FPGA = 2, uhd::niusrprio::BAR_WINDOW = 3 }
enum  uhd::niusrprio::nirio_device_attribute32_t {
  uhd::niusrprio::RIO_PRODUCT_NUMBER = 2UL, uhd::niusrprio::RIO_CURRENT_VERSION = 14UL, uhd::niusrprio::RIO_OLDEST_COMPATIBLE_VERSION = 15UL, uhd::niusrprio::RIO_ADDRESS_SPACE = 25UL,
  uhd::niusrprio::RIO_IS_FPGA_PROGRAMMED = 48UL, uhd::niusrprio::RIO_FPGA_DEFAULT_SIGNATURE_OFFSET = 53UL
enum  uhd::niusrprio::nirio_scalar_type_t {
  uhd::niusrprio::RIO_SCALAR_TYPE_IB = 1UL, uhd::niusrprio::RIO_SCALAR_TYPE_IW = 2UL, uhd::niusrprio::RIO_SCALAR_TYPE_IL = 3UL, uhd::niusrprio::RIO_SCALAR_TYPE_IQ = 4UL,
  uhd::niusrprio::RIO_SCALAR_TYPE_UB = 5UL, uhd::niusrprio::RIO_SCALAR_TYPE_UW = 6UL, uhd::niusrprio::RIO_SCALAR_TYPE_UL = 7UL, uhd::niusrprio::RIO_SCALAR_TYPE_UQ = 8UL
enum  uhd::niusrprio::fifo_direction_t { uhd::niusrprio::INPUT_FIFO, uhd::niusrprio::OUTPUT_FIFO }
◆ GET_FIFO_MEMORY_TYPE
#define GET_FIFO_MEMORY_TYPE (   fifo_inst)    (static_cast<uint16_t>(0x0100 | static_cast<uint16_t>(fifo_inst)))
◆ NI_VENDOR_NUM
◆ READER_LOCK
◆ VERSION_BUILD_MASK
◆ VERSION_BUILD_SHIFT
◆ VERSION_MAINT_MASK
◆ VERSION_MAINT_SHIFT
◆ VERSION_MAJOR_MASK
◆ VERSION_MAJOR_SHIFT
◆ VERSION_PHASE_MASK
◆ VERSION_PHASE_SHIFT
◆ VERSION_UPGRD_MASK
◆ VERSION_UPGRD_SHIFT
◆ WRITER_LOCK
#define WRITER_LOCK
Value:
boost::upgrade_lock<boost::shared_mutex> write_upgrade_lock(_synchronization);\
boost::upgrade_to_unique_lock<boost::shared_mutex> write_unique_lock(write_upgrade_lock);
