USRP Hardware Driver and USRP Manual  Version: 003.008.003-0-g87dfdc3c
uhd::property_tree Class Referenceabstract
Inheritance diagram for uhd::property_tree:
typedef boost::shared_ptr< property_treesptr
virtual ~property_tree (void)=0
virtual sptr subtree (const fs_path &path) const =0
 Get a subtree with a new root starting at path. More...
virtual void remove (const fs_path &path)=0
 Remove a property or directory (recursive) More...
virtual bool exists (const fs_path &path) const =0
 True if the path exists in the tree. More...
virtual std::vector< std::string > list (const fs_path &path) const =0
 Get an iterable to all things in the given path. More...
template<typename T >
property< T > & create (const fs_path &path)
 Create a new property entry in the tree. More...
property< T > & access (const fs_path &path)
 Get access to a property in the tree. More...
static sptr make (void)
 Create a new + empty property tree. More...
The property tree provides a file system structure for accessing properties.
typedef boost::shared_ptr<property_tree> uhd::property_tree::sptr
◆ ~property_tree()
virtual uhd::property_tree::~property_tree ( void  )
◆ access()
property< T > & uhd::property_tree::access ( const fs_path path)
◆ create()
property< T > & uhd::property_tree::create ( const fs_path path)
◆ exists()
virtual bool uhd::property_tree::exists ( const fs_path path) const
◆ list()
virtual std::vector<std::string> uhd::property_tree::list ( const fs_path path) const
◆ make()
static sptr uhd::property_tree::make ( void  )
◆ remove()
virtual void uhd::property_tree::remove ( const fs_path path)
◆ subtree()
virtual sptr uhd::property_tree::subtree ( const fs_path path) const
