USRP Hardware Driver and USRP Manual  Version: 003.009.002-0-gf18abe54
uhd::device Class Referenceabstract
#include <uhd/device.hpp>
Inheritance diagram for uhd::device:
enum  device_filter_t { ANY, USRP, CLOCK }
 Device type, used as a filter in make. More...
typedef boost::shared_ptr< devicesptr
typedef boost::function< device_addrs_t(const device_addr_t &)> find_t
typedef boost::function< sptr(const device_addr_t &)> make_t
virtual ~device (void)=0
 Make a new receive streamer from the streamer arguments. More...
 Make a new transmit streamer from the streamer arguments. More...
uhd::property_tree::sptr get_tree (void) const
 Get access to the underlying property structure. More...
device_filter_t get_device_type () const
 Get device type. More...
static void register_device (const find_t &find, const make_t &make, const device_filter_t filter)
static device_addrs_t find (const device_addr_t &hint, device_filter_t filter=ANY)
 Find devices attached to the host. More...
static sptr make (const device_addr_t &hint, device_filter_t filter=ANY, size_t which=0)
 Create a new device from the device address hint. More...
Protected Attributes
uhd::property_tree::sptr _tree
device_filter_t _type
The device interface represents the hardware. The API allows for discovery, configuration, and streaming.
◆ find_t
typedef boost::function<device_addrs_t(const device_addr_t &)> uhd::device::find_t
◆ make_t
typedef boost::function<sptr(const device_addr_t &)> uhd::device::make_t
typedef boost::shared_ptr<device> uhd::device::sptr
◆ device_filter_t
Enumerator
ANY
USRP
CLOCK
◆ ~device()
virtual uhd::device::~device ( void  )
◆ find()
static device_addrs_t uhd::device::find ( const device_addr_t hint,
device_filter_t  filter = ANY
The hint device address should be used to narrow down the search to particular transport types and/or transport arguments.
hinta partially (or fully) filled in device address
filteran optional filter to exclude USRP or clock devices
a vector of device addresses for all devices on the system
◆ get_device_type()
device_filter_t uhd::device::get_device_type ( ) const
Get device type.
◆ get_rx_stream()
virtual rx_streamer::sptr uhd::device::get_rx_stream ( const stream_args_t args)
Note: There can always only be one streamer. When calling get_rx_stream() a second time, the first streamer must be destroyed beforehand.
◆ get_tree()
uhd::property_tree::sptr uhd::device::get_tree ( void  ) const
◆ get_tx_stream()
virtual tx_streamer::sptr uhd::device::get_tx_stream ( const stream_args_t args)
Note: There can always only be one streamer. When calling get_tx_stream() a second time, the first streamer must be destroyed beforehand.
◆ make()
static sptr uhd::device::make ( const device_addr_t hint,
device_filter_t  filter = ANY,
size_t  which = 0
The method will go through the registered device types and pick one of the discovered devices.
By default, the first result will be used to create a new device. Use the which parameter as an index into the list of results.
whichwhich address to use when multiple are found
a shared pointer to a new device instance
◆ register_device()
static void uhd::device::register_device ( const find_t find,
const make_t make,
Register a device into the discovery and factory system.
finda function that discovers devices
makea factory function that makes a device
filterinclude only USRP devices, clock devices, or both
◆ _tree
uhd::property_tree::sptr uhd::device::_tree
◆ _type
device_filter_t uhd::device::_type
