USRP Hardware Driver and USRP Manual  Version: 003.009.002-0-gf18abe54
template<typename T >
 dict (void)
std::size_t size (void) const
void update (const dict< std::string, std::string > &new_dict, bool fail_on_conflict=true)
  • Ex: addr=192.168.10.2
◆ device_addr_t()
argsthe arguments string
◆ cast()
const T &  def
) const
Exceptions
◆ to_pp_string()
◆ to_string()
