Classes | |
| struct | uhd_range_t |
| Range of floating-point values.  More... | |
Typedefs | |
| typedef struct uhd_meta_range_t * | uhd_meta_range_handle |
| C-level interface for dealing with a list of ranges.  More... | |
Functions | |
| UHD_API uhd_error | uhd_range_to_pp_string (const uhd_range_t *range, char *pp_string_out, size_t strbuffer_len) |
| Get a string representation of the given range.  More... | |
| UHD_API uhd_error | uhd_meta_range_make (uhd_meta_range_handle *h) |
| Create a meta range handle.  More... | |
| UHD_API uhd_error | uhd_meta_range_free (uhd_meta_range_handle *h) |
| Destroy a meta range handle.  More... | |
| UHD_API uhd_error | uhd_meta_range_start (uhd_meta_range_handle h, double *start_out) |
| Get the overall start value for the given meta range.  More... | |
| UHD_API uhd_error | uhd_meta_range_stop (uhd_meta_range_handle h, double *stop_out) |
| Get the overall stop value for the given meta range.  More... | |
| UHD_API uhd_error | uhd_meta_range_step (uhd_meta_range_handle h, double *step_out) |
| Get the overall step value for the given meta range.  More... | |
| UHD_API uhd_error | uhd_meta_range_clip (uhd_meta_range_handle h, double value, bool clip_step, double *result_out) |
| Clip the given value to a possible value in the given range.  More... | |
| UHD_API uhd_error | uhd_meta_range_size (uhd_meta_range_handle h, size_t *size_out) |
| Get the number of ranges in the given meta range.  More... | |
| UHD_API uhd_error | uhd_meta_range_push_back (uhd_meta_range_handle h, const uhd_range_t *range) |
| Add a range to the given meta range.  More... | |
| UHD_API uhd_error | uhd_meta_range_at (uhd_meta_range_handle h, size_t num, uhd_range_t *range_out) |
| Get the range at the given index.  More... | |
| UHD_API uhd_error | uhd_meta_range_to_pp_string (uhd_meta_range_handle h, char *pp_string_out, size_t strbuffer_len) |
| Get a string representation of the given meta range.  More... | |
| UHD_API uhd_error | uhd_meta_range_last_error (uhd_meta_range_handle h, char *error_out, size_t strbuffer_len) |
| Get the last error recorded by the underlying meta range.  More... | |
| typedef struct uhd_meta_range_t* uhd_meta_range_handle |
See uhd::meta_range_t for more details.
| UHD_API uhd_error uhd_meta_range_at | ( | uhd_meta_range_handle | h, |
| size_t | num, | ||
| uhd_range_t * | range_out | ||
| UHD_API uhd_error uhd_meta_range_clip | ( | uhd_meta_range_handle | h, |
| double | value, | ||
| bool | clip_step, | ||
| double * | result_out | ||
| UHD_API uhd_error uhd_meta_range_free | ( | uhd_meta_range_handle * | h | ) |
NOTE: Using a uhd_meta_range_handle after passing it into this function will result in a segmentation fault.
| UHD_API uhd_error uhd_meta_range_last_error | ( | uhd_meta_range_handle | h, |
| char * | error_out, | ||
| size_t | strbuffer_len | ||
| UHD_API uhd_error uhd_meta_range_make | ( | uhd_meta_range_handle * | h | ) |
NOTE: Using a uhd_meta_range_handle before passing it into this function will result in undefined behavior.
| UHD_API uhd_error uhd_meta_range_push_back | ( | uhd_meta_range_handle | h, |
| const uhd_range_t * | range | ||
| UHD_API uhd_error uhd_meta_range_size | ( | uhd_meta_range_handle | h, |
| size_t * | size_out | ||
| UHD_API uhd_error uhd_meta_range_start | ( | uhd_meta_range_handle | h, |
| double * | start_out | ||
| UHD_API uhd_error uhd_meta_range_step | ( | uhd_meta_range_handle | h, |
| double * | step_out | ||
| UHD_API uhd_error uhd_meta_range_stop | ( | uhd_meta_range_handle | h, |
| double * | stop_out | ||
| UHD_API uhd_error uhd_meta_range_to_pp_string | ( | uhd_meta_range_handle | h, |
| char * | pp_string_out, | ||
| UHD_API uhd_error uhd_range_to_pp_string | ( | const uhd_range_t * | range, |
