uhd::rfnoc::source_node_ctrl Class Referenceabstract
#include <uhd/rfnoc/source_node_ctrl.hpp>
Inheritance diagram for uhd::rfnoc::source_node_ctrl:
uhd::rfnoc::node_ctrl_base uhd::rfnoc::source_block_ctrl_base uhd::rfnoc::block_ctrl uhd::rfnoc::ddc_block_ctrl uhd::rfnoc::dma_fifo_block_ctrl uhd::rfnoc::duc_block_ctrl uhd::rfnoc::fir_block_ctrl uhd::rfnoc::null_block_ctrl uhd::rfnoc::radio_ctrl uhd::rfnoc::replay_block_ctrl uhd::rfnoc::siggen_block_ctrl uhd::rfnoc::window_block_ctrl
typedef boost::shared_ptr< source_node_ctrlsptr
typedef std::map< size_t, boost::weak_ptr< source_node_ctrl > > node_map_t
typedef std::pair< size_t, boost::weak_ptr< source_node_ctrl > > node_map_pair_t
- Public Types inherited from uhd::rfnoc::node_ctrl_base
typedef boost::shared_ptr< node_ctrl_basesptr
typedef boost::weak_ptr< node_ctrl_basewptr
typedef std::map< size_t, wptrnode_map_t
typedef std::pair< size_t, wptrnode_map_pair_t
virtual void issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t chan=0)=0
size_t connect_downstream (node_ctrl_base::sptr downstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t())
virtual void set_rx_streamer (bool active, const size_t port)
- Public Member Functions inherited from uhd::rfnoc::node_ctrl_base
virtual std::string unique_id () const
 Returns a unique string that identifies this block. More...
virtual void clear ()
node_map_t list_downstream_nodes ()
node_map_t list_upstream_nodes ()
void disconnect ()
void disconnect_output_port (const size_t output_port)
void disconnect_input_port (const size_t input_port)
void set_downstream_port (const size_t this_port, const size_t remote_port)
size_t get_downstream_port (const size_t this_port)
void set_upstream_port (const size_t this_port, const size_t remote_port)
size_t get_upstream_port (const size_t this_port)
template<typename T >
UHD_INLINE std::vector< boost::shared_ptr< T > > find_downstream_node (bool active_only=false)
UHD_INLINE std::vector< boost::shared_ptr< T > > find_upstream_node (bool active_only=false)
template<typename T , typename value_type >
UHD_INLINE value_type find_downstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >())
UHD_INLINE value_type find_upstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >())
virtual size_t _request_output_port (const size_t suggested_port, const uhd::device_addr_t &args) const
- Protected Member Functions inherited from uhd::rfnoc::node_ctrl_base
 node_ctrl_base (void)
virtual ~node_ctrl_base ()
virtual void _register_upstream_node (node_ctrl_base::sptr upstream_node, size_t port)
- Protected Attributes inherited from uhd::rfnoc::node_ctrl_base
uhd::device_addr_t _args
 Stores default arguments. More...
node_map_t _upstream_nodes
 List of upstream nodes. More...
node_map_t _downstream_nodes
 List of downstream nodes. More...
size_t _num_input_ports
size_t _num_output_ports
std::map< size_t, bool > _rx_streamer_active
std::map< size_t, bool > _tx_streamer_active
◆ node_map_pair_t
typedef std::pair<size_t, boost::weak_ptr<source_node_ctrl> > uhd::rfnoc::source_node_ctrl::node_map_pair_t
◆ node_map_t
typedef std::map<size_t, boost::weak_ptr<source_node_ctrl> > uhd::rfnoc::source_node_ctrl::node_map_t
◆ _request_output_port()
virtual size_t uhd::rfnoc::source_node_ctrl::_request_output_port ( const size_t  suggested_port,
const uhd::device_addr_t args
) const
protectedvirtual
Ask for a port number to connect a downstream block to.
See sink_node_ctrl::_request_input_port(). This is the same for output.
suggested_portTry and connect here.
argsWhen deciding on a port number, these arguments may be used.
A valid input port, or ANY_PORT on failure.
Reimplemented in uhd::rfnoc::source_block_ctrl_base.
◆ connect_downstream()
size_t uhd::rfnoc::source_node_ctrl::connect_downstream ( node_ctrl_base::sptr  downstream_node,
size_t  port = ANY_PORT,
const uhd::device_addr_t args = uhd::device_addr_t()
Connect another node downstream of this node.
Note: If additional settings are required to make this connection work, e.g. configure flow control, these need to be done separately.
If the requested connection is not possible, this function will throw.
downstream_node Pointer to the node class to connect port Suggested port number on this block to connect the downstream block to. args Any arguments that can be useful for determining the port number.
The actual port number used.
◆ issue_stream_cmd()
virtual void uhd::rfnoc::source_node_ctrl::issue_stream_cmd ( const uhd::stream_cmd_t stream_cmd,
const size_t  chan = 0
Issue a stream command for this block.
stream_cmdThe stream command.
chanChannel Index
Implemented in uhd::rfnoc::source_block_ctrl_base.
◆ set_rx_streamer()
virtual void uhd::rfnoc::source_node_ctrl::set_rx_streamer ( bool  active,
const size_t  port
virtual
Call this function to notify a node about its streamer activity.
When active is set to true, this means this block is now part of an active rx streamer chain. Conversely, when set to false, this means the node has been removed from an rx streamer chain.
