uhd::usrp::multi_usrp Class Referenceabstract
Inheritance diagram for uhd::usrp::multi_usrp:
Classes
struct  register_info_t
typedef boost::shared_ptr< multi_usrpsptr
virtual ~multi_usrp (void)=0
virtual device::sptr get_device (void)=0
virtual bool is_device3 (void)=0
virtual boost::shared_ptr< uhd::device3get_device3 (void)=0
 Convenience method to get a RX streamer. See also uhd::device::get_rx_stream(). More...
 Convenience method to get a TX streamer. See also uhd::device::get_tx_stream(). More...
virtual dict< std::string, std::string > get_usrp_rx_info (size_t chan=0)=0
virtual dict< std::string, std::string > get_usrp_tx_info (size_t chan=0)=0
virtual void set_master_clock_rate (double rate, size_t mboard=ALL_MBOARDS)=0
virtual double get_master_clock_rate (size_t mboard=0)=0
virtual meta_range_t get_master_clock_rate_range (const size_t mboard=0)=0
virtual std::string get_pp_string (void)=0
virtual std::string get_mboard_name (size_t mboard=0)=0
virtual time_spec_t get_time_now (size_t mboard=0)=0
virtual time_spec_t get_time_last_pps (size_t mboard=0)=0
virtual void set_time_now (const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual void set_time_next_pps (const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual void set_time_unknown_pps (const time_spec_t &time_spec)=0
virtual bool get_time_synchronized (void)=0
virtual void set_command_time (const uhd::time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0
virtual void clear_command_time (size_t mboard=ALL_MBOARDS)=0
virtual void issue_stream_cmd (const stream_cmd_t &stream_cmd, size_t chan=ALL_CHANS)=0
virtual void set_clock_config (const clock_config_t &clock_config, size_t mboard=ALL_MBOARDS)=0
virtual void set_time_source (const std::string &source, const size_t mboard=ALL_MBOARDS)=0
virtual std::string get_time_source (const size_t mboard)=0
virtual std::vector< std::string > get_time_sources (const size_t mboard)=0
virtual void set_clock_source (const std::string &source, const size_t mboard=ALL_MBOARDS)=0
virtual std::string get_clock_source (const size_t mboard)=0
virtual std::vector< std::string > get_clock_sources (const size_t mboard)=0
virtual void set_sync_source (const std::string &clock_source, const std::string &time_source, const size_t mboard=ALL_MBOARDS)=0
virtual void set_sync_source (const device_addr_t &sync_source, const size_t mboard=ALL_MBOARDS)=0
virtual device_addr_t get_sync_source (const size_t mboard)=0
virtual std::vector< device_addr_tget_sync_sources (const size_t mboard)=0
virtual void set_clock_source_out (const bool enb, const size_t mboard=ALL_MBOARDS)=0
virtual void set_time_source_out (const bool enb, const size_t mboard=ALL_MBOARDS)=0
virtual size_t get_num_mboards (void)=0
virtual sensor_value_t get_mboard_sensor (const std::string &name, size_t mboard=0)=0
virtual std::vector< std::string > get_mboard_sensor_names (size_t mboard=0)=0
virtual void set_user_register (const uint8_t addr, const uint32_t data, size_t mboard=ALL_MBOARDS)=0
virtual uhd::wb_iface::sptr get_user_settings_iface (const size_t chan=0)=0
virtual void set_rx_subdev_spec (const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0
virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec (size_t mboard=0)=0
virtual size_t get_rx_num_channels (void)=0
virtual std::string get_rx_subdev_name (size_t chan=0)=0
virtual void set_rx_rate (double rate, size_t chan=ALL_CHANS)=0
virtual double get_rx_rate (size_t chan=0)=0
virtual meta_range_t get_rx_rates (size_t chan=0)=0
virtual tune_result_t set_rx_freq (const tune_request_t &tune_request, size_t chan=0)=0
virtual double get_rx_freq (size_t chan=0)=0
virtual freq_range_t get_rx_freq_range (size_t chan=0)=0
virtual freq_range_t get_fe_rx_freq_range (size_t chan=0)=0
virtual std::vector< std::string > get_rx_lo_names (size_t chan=0)=0
virtual void set_rx_lo_source (const std::string &src, const std::string &name=ALL_LOS, size_t chan=0)=0
virtual const std::string get_rx_lo_source (const std::string &name=ALL_LOS, size_t chan=0)=0
virtual std::vector< std::string > get_rx_lo_sources (const std::string &name=ALL_LOS, size_t chan=0)=0
virtual void set_rx_lo_export_enabled (bool enabled, const std::string &name=ALL_LOS, size_t chan=0)=0
virtual bool get_rx_lo_export_enabled (const std::string &name=ALL_LOS, size_t chan=0)=0
virtual double set_rx_lo_freq (double freq, const std::string &name, size_t chan=0)=0
virtual double get_rx_lo_freq (const std::string &name, size_t chan=0)=0
virtual freq_range_t get_rx_lo_freq_range (const std::string &name, size_t chan=0)=0
virtual std::vector< std::string > get_tx_lo_names (size_t chan=0)=0
virtual void set_tx_lo_source (const std::string &src, const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual const std::string get_tx_lo_source (const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual std::vector< std::string > get_tx_lo_sources (const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual void set_tx_lo_export_enabled (const bool enabled, const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual bool get_tx_lo_export_enabled (const std::string &name=ALL_LOS, const size_t chan=0)=0
virtual double set_tx_lo_freq (const double freq, const std::string &name, const size_t chan=0)=0
virtual double get_tx_lo_freq (const std::string &name, const size_t chan=0)=0
virtual freq_range_t get_tx_lo_freq_range (const std::string &name, const size_t chan=0)=0
virtual void set_rx_gain (double gain, const std::string &name, size_t chan=0)=0
virtual std::vector< std::string > get_rx_gain_profile_names (const size_t chan=0)=0
virtual void set_rx_gain_profile (const std::string &profile, const size_t chan=0)=0
virtual std::string get_rx_gain_profile (const size_t chan=0)=0
void set_rx_gain (double gain, size_t chan=0)
 A convenience wrapper for setting overall RX gain. More...
virtual void set_normalized_rx_gain (double gain, size_t chan=0)=0
virtual void set_rx_agc (bool enable, size_t chan=0)=0
virtual double get_rx_gain (const std::string &name, size_t chan=0)=0
double get_rx_gain (size_t chan=0)
 A convenience wrapper for getting overall RX gain. More...
virtual double get_normalized_rx_gain (size_t chan=0)=0
virtual gain_range_t get_rx_gain_range (const std::string &name, size_t chan=0)=0
gain_range_t get_rx_gain_range (size_t chan=0)
 A convenience wrapper for getting overall RX gain range. More...
virtual std::vector< std::string > get_rx_gain_names (size_t chan=0)=0
virtual void set_rx_antenna (const std::string &ant, size_t chan=0)=0
virtual std::string get_rx_antenna (size_t chan=0)=0
virtual std::vector< std::string > get_rx_antennas (size_t chan=0)=0
virtual void set_rx_bandwidth (double bandwidth, size_t chan=0)=0
virtual double get_rx_bandwidth (size_t chan=0)=0
virtual meta_range_t get_rx_bandwidth_range (size_t chan=0)=0
virtual dboard_iface::sptr get_rx_dboard_iface (size_t chan=0)=0
virtual sensor_value_t get_rx_sensor (const std::string &name, size_t chan=0)=0
virtual std::vector< std::string > get_rx_sensor_names (size_t chan=0)=0
virtual void set_rx_dc_offset (const bool enb, size_t chan=ALL_CHANS)=0
virtual void set_rx_dc_offset (const std::complex< double > &offset, size_t chan=ALL_CHANS)=0
virtual meta_range_t get_rx_dc_offset_range (size_t chan=0)=0
virtual void set_rx_iq_balance (const bool enb, size_t chan)=0
virtual void set_rx_iq_balance (const std::complex< double > &correction, size_t chan=ALL_CHANS)=0
virtual void set_tx_subdev_spec (const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0
virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec (size_t mboard=0)=0
virtual size_t get_tx_num_channels (void)=0
virtual std::string get_tx_subdev_name (size_t chan=0)=0
virtual void set_tx_rate (double rate, size_t chan=ALL_CHANS)=0
virtual double get_tx_rate (size_t chan=0)=0
virtual meta_range_t get_tx_rates (size_t chan=0)=0
virtual tune_result_t set_tx_freq (const tune_request_t &tune_request, size_t chan=0)=0
virtual double get_tx_freq (size_t chan=0)=0
virtual freq_range_t get_tx_freq_range (size_t chan=0)=0
virtual freq_range_t get_fe_tx_freq_range (size_t chan=0)=0
virtual void set_tx_gain (double gain, const std::string &name, size_t chan=0)=0
virtual std::vector< std::string > get_tx_gain_profile_names (const size_t chan=0)=0
virtual void set_tx_gain_profile (const std::string &profile, const size_t chan=0)=0
virtual std::string get_tx_gain_profile (const size_t chan=0)=0
void set_tx_gain (double gain, size_t chan=0)
 A convenience wrapper for setting overall TX gain. More...
virtual void set_normalized_tx_gain (double gain, size_t chan=0)=0
virtual double get_tx_gain (const std::string &name, size_t chan=0)=0
double get_tx_gain (size_t chan=0)
 A convenience wrapper for getting overall TX gain. More...
virtual double get_normalized_tx_gain (size_t chan=0)=0
virtual gain_range_t get_tx_gain_range (const std::string &name, size_t chan=0)=0
gain_range_t get_tx_gain_range (size_t chan=0)
 A convenience wrapper for getting overall TX gain range. More...
virtual std::vector< std::string > get_tx_gain_names (size_t chan=0)=0
virtual void set_tx_antenna (const std::string &ant, size_t chan=0)=0
virtual std::string get_tx_antenna (size_t chan=0)=0
virtual std::vector< std::string > get_tx_antennas (size_t chan=0)=0
virtual void set_tx_bandwidth (double bandwidth, size_t chan=0)=0
virtual double get_tx_bandwidth (size_t chan=0)=0
virtual meta_range_t get_tx_bandwidth_range (size_t chan=0)=0
virtual dboard_iface::sptr get_tx_dboard_iface (size_t chan=0)=0
virtual sensor_value_t get_tx_sensor (const std::string &name, size_t chan=0)=0
virtual std::vector< std::string > get_tx_sensor_names (size_t chan=0)=0
virtual void set_tx_dc_offset (const std::complex< double > &offset, size_t chan=ALL_CHANS)=0
virtual meta_range_t get_tx_dc_offset_range (size_t chan=0)=0
virtual void set_tx_iq_balance (const std::complex< double > &correction, size_t chan=ALL_CHANS)=0
virtual std::vector< std::string > get_gpio_banks (const size_t mboard)=0
virtual void set_gpio_attr (const std::string &bank, const std::string &attr, const uint32_t value, const uint32_t mask=0xffffffff, const size_t mboard=0)=0
virtual void set_gpio_attr (const std::string &bank, const std::string &attr, const std::string &value, const uint32_t mask=0xffffffff, const size_t mboard=0)=0
virtual uint32_t get_gpio_attr (const std::string &bank, const std::string &attr, const size_t mboard=0)=0
virtual std::vector< std::string > get_gpio_string_attr (const std::string &bank, const std::string &attr, const size_t mboard=0)=0
virtual std::vector< std::string > enumerate_registers (const size_t mboard=0)=0
virtual register_info_t get_register_info (const std::string &path, const size_t mboard=0)=0
virtual void write_register (const std::string &path, const uint32_t field, const uint64_t value, const size_t mboard=0)=0
virtual uint64_t read_register (const std::string &path, const uint32_t field, const size_t mboard=0)=0
virtual std::vector< std::string > get_filter_names (const std::string &search_mask="")=0
virtual filter_info_base::sptr get_filter (const std::string &path)=0
virtual void set_filter (const std::string &path, filter_info_base::sptr filter)=0
static sptr make (const device_addr_t &dev_addr)
static const size_t ALL_MBOARDS
 A wildcard motherboard index. More...
static const size_t ALL_CHANS
 A wildcard channel index. More...
static const std::string ALL_GAINS
 A wildcard gain element name. More...
static const std::string ALL_LOS
 A wildcard LO stage name. More...
The Multi-USRP device class:
This class facilitates ease-of-use for most use-case scenarios. The wrapper provides convenience functions to tune the devices, set the dboard gains, antennas, filters, and other properties. This class can be used to interface with a single USRP with one or more channels, or multiple USRPs in a homogeneous setup. All members take an optional parameter for board number or channel number. In the single device, single channel case, these parameters can be unspecified.
When using a single device with multiple channels:
  • Channel mapping is determined by the frontend specifications
  • All channels share a common RX sample rate
  • All channels share a common TX sample rate
When using multiple devices in a configuration:
  • Channel mapping is determined by the device address arguments
  • All boards share a common RX sample rate
  • All boards share a common TX sample rate
  • All boards share a common RX frontend specification size
  • All boards share a common TX frontend specification size
  • All boards must have synchronized times (see the set_time_*() calls)
Example to setup channel mapping for multiple devices:
//create a multi_usrp with two boards in the configuration
device_addr_t dev_addr;
dev_addr["addr0"] = "192.168.10.2"
dev_addr["addr1"] = "192.168.10.3";
multi_usrp::sptr dev = multi_usrp::make(dev_addr);
//set the board on 10.2 to use the A RX frontend (RX channel 0)
dev->set_rx_subdev_spec("A:A", 0);
//set the board on 10.3 to use the B RX frontend (RX channel 1)
dev->set_rx_subdev_spec("A:B", 1);
//set both boards to use the AB TX frontend (TX channels 0 and 1)
dev->set_tx_subdev_spec("A:AB", multi_usrp::ALL_MBOARDS);
//now that all the channels are mapped, continue with configuration...
typedef boost::shared_ptr<multi_usrp> uhd::usrp::multi_usrp::sptr
◆ ~multi_usrp()
virtual uhd::usrp::multi_usrp::~multi_usrp ( void  )
◆ clear_command_time()
virtual void uhd::usrp::multi_usrp::clear_command_time ( size_t  mboard = ALL_MBOARDS)
Clear the command time so future commands are sent ASAP.
mboardwhich motherboard to set the config
◆ enumerate_registers()
virtual std::vector<std::string> uhd::usrp::multi_usrp::enumerate_registers ( const size_t  mboard = 0)
Enumerate the full paths of all low-level USRP registers accessible to read/write
mboardthe motherboard index 0 to M-1
a vector of register paths
◆ get_clock_source()
virtual std::string uhd::usrp::multi_usrp::get_clock_source ( const size_t  mboard)
Get the currently set clock source.
mboardwhich motherboard to get the config
the string representing the clock source
◆ get_clock_sources()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_clock_sources ( const size_t  mboard)
Get a list of possible clock sources.
mboardwhich motherboard to get the list
a vector of strings for possible settings
◆ get_device()
virtual device::sptr uhd::usrp::multi_usrp::get_device ( void  )
Get the underlying device object. This is needed to get access to the streaming API and properties.
the device object within this USRP
◆ get_device3()
virtual boost::shared_ptr<uhd::device3> uhd::usrp::multi_usrp::get_device3 ( void  )
Get the underlying device3 object. Only works for generation-3 (or later) devices.
The uhd::device3 object for this USRP.
Exceptions
uhd::type_errorif this device is not actually a generation-3 device.
◆ get_fe_rx_freq_range()
virtual freq_range_t uhd::usrp::multi_usrp::get_fe_rx_freq_range ( size_t  chan = 0)
Get the center frequency range of the RF frontend.
chanthe channel index 0 to N-1
a frequency range object
◆ get_fe_tx_freq_range()
virtual freq_range_t uhd::usrp::multi_usrp::get_fe_tx_freq_range ( size_t  chan = 0)
Get the center frequency range of the TX frontend.
◆ get_filter()
virtual filter_info_base::sptr uhd::usrp::multi_usrp::get_filter ( const std::string &  path)
Return the filter object for the given name.
paththe name of the filter as returned from get_filter_names().
a filter_info_base::sptr.
◆ get_filter_names()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_filter_names ( const std::string &  search_mask = "")
Enumerate the available filters in the signal path.
search_mask
Select only certain filter names by specifying this search mask.
E.g. if search mask is set to "rx_frontends/A" only filter names including that string will be returned.
a vector of strings representing the selected filter names.
◆ get_gpio_attr()
virtual uint32_t uhd::usrp::multi_usrp::get_gpio_attr ( const std::string &  bank,
const std::string &  attr,
Get a GPIO attribute on a particular GPIO bank. Possible attribute names:
  • CTRL - 1 for ATR mode 0 for GPIO mode
  • DDR - 1 for output 0 for input
  • OUT - GPIO output level (not ATR mode)
  • ATR_0X - ATR idle state
  • ATR_RX - ATR receive only state
  • ATR_TX - ATR transmit only state
  • ATR_XX - ATR full duplex state
  • READBACK - readback input GPIOs
    bankthe name of a GPIO bank
    attrthe name of a GPIO attribute
    the value set for this attribute
◆ get_gpio_banks()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_gpio_banks ( const size_t  mboard)
Enumerate gpio banks on the specified device.
a list of string for each bank name
◆ get_gpio_string_attr()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_gpio_string_attr ( const std::string &  bank,
  • SRC - "PS" for handling by processing system
    • "RADIO_N/M" for handling by radio block with N is in [0..Number of Radio]; M is in [0..Number of port per Radio]
  • CTRL - "ATR" for ATR mode
    • "GPIO" for GPIO mode
  • DDR - "OUT" for output
    • "IN" for input
  • OUT - a string of numbers representing GPIO output level (not ATR mode)
    • "HIGH"or "LOW" as GPIO output level that apply for each bit mask that is 1
  • ATR_0X - a string of numbers representing a value of the ATR idle state register
    • "HIGH" or "LOW" as a value set on each bit on of the ATR idle state register
  • ATR_RX - a string of numbers representing a value of a ATR receive only state register
    • "HIGH" or "LOW" as a value set on each bit on of the ATR receive only state register
  • ATR_TX - a string of numbers representing a value of the ATR transmit only state register
    • "HIGH" or "LOW" as a value set on each bit on of the ATR transmit only state register
  • ATR_XX - a string of numbers representing a value of the ATR full duplex state register
    • "HIGH" or "LOW" as a value set on each bit on of the ATR full duplex state register
    the value set for this attribute in vector of strings
◆ get_master_clock_rate()
virtual double uhd::usrp::multi_usrp::get_master_clock_rate ( size_t  mboard = 0)
Get the master clock rate.
the master clock rate in Hz.
◆ get_master_clock_rate_range()
virtual meta_range_t uhd::usrp::multi_usrp::get_master_clock_rate_range ( const size_t  mboard = 0)
Return the range within which the master clock rate can be set for this session
Note that many USRPs do not actually support setting the master clock rate during a running session. In this case, the range will consist of a single value, which is the current master clock rate. Values from this range are valid/sensible inputs to set_master_clock_rate(), although keep in mind that the latter coerces.
Examples:
  • The B200 series' master clock rate can be changed at runtime and will report the true range of supported values
  • The X300 series has two discrete options for the clock rate, but will always return the clock rate which the USRP was initialized to because it cannot be changed at runtime
  • The N200 series does not have a configurable clock rate, and will always return the same single value as a range
◆ get_mboard_name()
virtual std::string uhd::usrp::multi_usrp::get_mboard_name ( size_t  mboard = 0)
Get canonical name for this USRP motherboard.
mboardwhich motherboard to query
a string representing the name
◆ get_mboard_sensor()
virtual sensor_value_t uhd::usrp::multi_usrp::get_mboard_sensor ( const std::string &  name,
size_t  mboard = 0
Get a motherboard sensor value.
namethe name of the sensor
a sensor value object
◆ get_mboard_sensor_names()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_mboard_sensor_names ( size_t  mboard = 0)
Get a list of possible motherboard sensor names.
a vector of sensor names
◆ get_normalized_rx_gain()
virtual double uhd::usrp::multi_usrp::get_normalized_rx_gain ( size_t  chan = 0)
Return the normalized RX gain value.
See set_normalized_rx_gain() for a discussion of normalized gains.
The normalized gain (in [0, 1])
Exceptions
Auhd::runtime_error if the gain value is outside [0, 1].
◆ get_normalized_tx_gain()
virtual double uhd::usrp::multi_usrp::get_normalized_tx_gain ( size_t  chan = 0)
Return the normalized TX gain value.
Exceptions
◆ get_num_mboards()
virtual size_t uhd::usrp::multi_usrp::get_num_mboards ( void  )
Get the number of USRP motherboards in this configuration.
◆ get_pp_string()
virtual std::string uhd::usrp::multi_usrp::get_pp_string ( void  )
a printable string
◆ get_register_info()
virtual register_info_t uhd::usrp::multi_usrp::get_register_info ( const std::string &  path,
Get more information about a low-level device register
paththe full path to the register
the info struct which contains the bitwidth and read-write access information
◆ get_rx_antenna()
virtual std::string uhd::usrp::multi_usrp::get_rx_antenna ( size_t  chan = 0)
Get the selected RX antenna on the frontend.
the antenna name
◆ get_rx_antennas()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_rx_antennas ( size_t  chan = 0)
Get a list of possible RX antennas on the frontend.
a vector of antenna names
◆ get_rx_bandwidth()
virtual double uhd::usrp::multi_usrp::get_rx_bandwidth ( size_t  chan = 0)
Get the RX bandwidth on the frontend.
the bandwidth in Hz
◆ get_rx_bandwidth_range()
virtual meta_range_t uhd::usrp::multi_usrp::get_rx_bandwidth_range ( size_t  chan = 0)
Get the range of the possible RX bandwidth settings.
a range of bandwidths in Hz
◆ get_rx_dboard_iface()
virtual dboard_iface::sptr uhd::usrp::multi_usrp::get_rx_dboard_iface ( size_t  chan = 0)
Get the dboard interface object for the RX frontend. The dboard interface gives access to GPIOs, SPI, I2C, low-speed ADC and DAC. Use at your own risk!
the dboard interface sptr
◆ get_rx_dc_offset_range()
virtual meta_range_t uhd::usrp::multi_usrp::get_rx_dc_offset_range ( size_t  chan = 0)
Get the valid range for RX DC offset values.
◆ get_rx_freq()
virtual double uhd::usrp::multi_usrp::get_rx_freq ( size_t  chan = 0)
Get the RX center frequency.
the frequency in Hz
◆ get_rx_freq_range()
virtual freq_range_t uhd::usrp::multi_usrp::get_rx_freq_range ( size_t  chan = 0)
Get the RX center frequency range. This range includes the overall tunable range of the RX chain, including frontend chain and digital down conversion chain. This tunable limit does not include the baseband bandwidth; users should assume that the actual range is +/- samp_rate/2.
◆ get_rx_gain() [1/2]
virtual double uhd::usrp::multi_usrp::get_rx_gain ( const std::string &  name,
size_t  chan = 0
Get the RX gain value for the specified gain element. For an empty name, sum across all gain elements.
the gain in dB
◆ get_rx_gain() [2/2]
double uhd::usrp::multi_usrp::get_rx_gain ( size_t  chan = 0)
◆ get_rx_gain_names()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_rx_gain_names ( size_t  chan = 0)
Get the names of the gain elements in the RX chain. Gain elements are ordered from antenna to FPGA.
a vector of gain element names
◆ get_rx_gain_profile()
virtual std::string uhd::usrp::multi_usrp::get_rx_gain_profile ( const size_t  chan = 0)
Get the RX gain profile.
a string of current RX gain profile of corresponding channel.
◆ get_rx_gain_profile_names()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_rx_gain_profile_names ( const size_t  chan = 0)
Get a list of possible RX gain profile options
Example: On the TwinRX, this will return "low-noise", "low-distortion" or "default". These names can be used in gain-profile related API called. An empty return value doesn't mean there are no profile options, it means that this radio does not have any gain profiles implemented, and typically means there is only one default profile of set gain
a vector of strings for possible gain profile options, or an empty list of this doesn't apply.
◆ get_rx_gain_range() [1/2]
virtual gain_range_t uhd::usrp::multi_usrp::get_rx_gain_range ( const std::string &  name,
size_t  chan = 0
Get the RX gain range for the specified gain element. For an empty name, calculate the overall gain range.
a gain range object
◆ get_rx_gain_range() [2/2]
gain_range_t uhd::usrp::multi_usrp::get_rx_gain_range ( size_t  chan = 0)
◆ get_rx_lo_export_enabled()
virtual bool uhd::usrp::multi_usrp::get_rx_lo_export_enabled ( const std::string &  name = ALL_LOS,
size_t  chan = 0
Returns true if the currently selected LO is being exported.
namethe name of the LO stage to query
◆ get_rx_lo_freq()
virtual double uhd::usrp::multi_usrp::get_rx_lo_freq ( const std::string &  name,
size_t  chan = 0
Get the current RX LO frequency (Advanced).
If the channel does not have independently configurable LOs the current rf frequency will be returned. See also set_rx_lo_freq() for more information.
the configured LO frequency
◆ get_rx_lo_freq_range()
virtual freq_range_t uhd::usrp::multi_usrp::get_rx_lo_freq_range ( const std::string &  name,
size_t  chan = 0
Get the LO frequency range of the RX LO.
If the channel does not have independently configurable LOs the rf frequency range will be returned.
◆ get_rx_lo_names()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_rx_lo_names ( size_t  chan = 0)
Get a list of possible LO stage names
Example: On the TwinRX, this will return "LO1", "LO2". These names can are used in other LO-related API calls, so this function can be used for automatically enumerating LO stages. An empty return value doesn't mean there are no LOs, it means that this radio does not have an LO API implemented, and typically means the LOs have no direct way of being controlled other than setting the frequency.
a vector of strings for possible LO names, or an empty list of this doesn't apply (i.e. there are no controllable LO stages)
◆ get_rx_lo_source()
virtual const std::string uhd::usrp::multi_usrp::get_rx_lo_source ( const std::string &  name = ALL_LOS,
size_t  chan = 0
Get the currently selected LO source.
Channels without controllable LO sources will always return "internal".
the configured LO source
◆ get_rx_lo_sources()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_rx_lo_sources ( const std::string &  name = ALL_LOS,
size_t  chan = 0
Get a list of possible LO sources.
Channels which do not have controllable LO sources will return "internal". Typical values are "internal" and "external", although the TwinRX has more options, such as "companion". These options are device- specific.
◆ get_rx_num_channels()
virtual size_t uhd::usrp::multi_usrp::get_rx_num_channels ( void  )
Get the number of RX channels in this configuration. This is the number of USRPs times the number of RX channels per board, where the number of RX channels per board is homogeneous among all USRPs.
◆ get_rx_rate()
virtual double uhd::usrp::multi_usrp::get_rx_rate ( size_t  chan = 0)
Gets the RX sample rate.
the rate in Sps
◆ get_rx_rates()
virtual meta_range_t uhd::usrp::multi_usrp::get_rx_rates ( size_t  chan = 0)
Get a range of possible RX rates.
the meta range of rates
◆ get_rx_sensor()
virtual sensor_value_t uhd::usrp::multi_usrp::get_rx_sensor ( const std::string &  name,
size_t  chan = 0
Get an RX frontend sensor value.
◆ get_rx_sensor_names()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_rx_sensor_names ( size_t  chan = 0)
Get a list of possible RX frontend sensor names.
◆ get_rx_stream()
virtual rx_streamer::sptr uhd::usrp::multi_usrp::get_rx_stream ( const stream_args_t args)
◆ get_rx_subdev_name()
virtual std::string uhd::usrp::multi_usrp::get_rx_subdev_name ( size_t  chan = 0)
Get the name of the RX frontend.
the frontend name
◆ get_rx_subdev_spec()
virtual uhd::usrp::subdev_spec_t uhd::usrp::multi_usrp::get_rx_subdev_spec ( size_t  mboard = 0)
Get the RX frontend specification.
the frontend specification in use
◆ get_sync_source()
virtual device_addr_t uhd::usrp::multi_usrp::get_sync_source ( const size_t  mboard)
Get the currently set sync source.
the dictionary representing the sync source settings
◆ get_sync_sources()
virtual std::vector<device_addr_t> uhd::usrp::multi_usrp::get_sync_sources ( const size_t  mboard)
Get a list of available sync sources
◆ get_time_last_pps()
virtual time_spec_t uhd::usrp::multi_usrp::get_time_last_pps ( size_t  mboard = 0)
Get the time when the last pps pulse occurred.
a timespec representing the last pps
◆ get_time_now()
virtual time_spec_t uhd::usrp::multi_usrp::get_time_now ( size_t  mboard = 0)
Get the current time in the usrp time registers.
a timespec representing current usrp time
◆ get_time_source()
virtual std::string uhd::usrp::multi_usrp::get_time_source ( const size_t  mboard)
Get the currently set time source.
the string representing the time source
◆ get_time_sources()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_time_sources ( const size_t  mboard)
Get a list of possible time sources.
◆ get_time_synchronized()
virtual bool uhd::usrp::multi_usrp::get_time_synchronized ( void  )
Are the times across all motherboards in this configuration synchronized? Checks that all time registers are approximately close but not exact, given that the RTT may varying for a control packet transaction.
true when all motherboards time registers are in sync
◆ get_tx_antenna()
virtual std::string uhd::usrp::multi_usrp::get_tx_antenna ( size_t  chan = 0)
Get the selected TX antenna on the frontend.
the antenna name
◆ get_tx_antennas()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_tx_antennas ( size_t  chan = 0)
Get a list of possible TX antennas on the frontend.
◆ get_tx_bandwidth()
virtual double uhd::usrp::multi_usrp::get_tx_bandwidth ( size_t  chan = 0)
Get the TX bandwidth on the frontend.
the bandwidth in Hz
◆ get_tx_bandwidth_range()
virtual meta_range_t uhd::usrp::multi_usrp::get_tx_bandwidth_range ( size_t  chan = 0)
Get the range of the possible TX bandwidth settings.
◆ get_tx_dboard_iface()
virtual dboard_iface::sptr uhd::usrp::multi_usrp::get_tx_dboard_iface ( size_t  chan = 0)
Get the dboard interface object for the TX frontend. The dboard interface gives access to GPIOs, SPI, I2C, low-speed ADC and DAC. Use at your own risk!
◆ get_tx_dc_offset_range()
virtual meta_range_t uhd::usrp::multi_usrp::get_tx_dc_offset_range ( size_t  chan = 0)
Get the valid range for TX DC offset values.
◆ get_tx_freq()
virtual double uhd::usrp::multi_usrp::get_tx_freq ( size_t  chan = 0)
Get the TX center frequency.
the frequency in Hz
◆ get_tx_freq_range()
virtual freq_range_t uhd::usrp::multi_usrp::get_tx_freq_range ( size_t  chan = 0)
Get the TX center frequency range. This range includes the overall tunable range of the TX chain, including frontend chain and digital up conversion chain. This tunable limit does not include the baseband bandwidth; users should assume that the actual range is +/- samp_rate/2.
◆ get_tx_gain() [1/2]
virtual double uhd::usrp::multi_usrp::get_tx_gain ( const std::string &  name,
size_t  chan = 0
Get the TX gain value for the specified gain element. For an empty name, sum across all gain elements.
the gain in dB
◆ get_tx_gain() [2/2]
double uhd::usrp::multi_usrp::get_tx_gain ( size_t  chan = 0)
◆ get_tx_gain_names()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_tx_gain_names ( size_t  chan = 0)
Get the names of the gain elements in the TX chain. Gain elements are ordered from antenna to FPGA.
◆ get_tx_gain_profile()
virtual std::string uhd::usrp::multi_usrp::get_tx_gain_profile ( const size_t  chan = 0)
Get the TX gain profile.
a string of current TX gain profile of corresponding channel.
◆ get_tx_gain_profile_names()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_tx_gain_profile_names ( const size_t  chan = 0)
Get a list of possible TX gain profile options
Example: On the N310, this will return "manual" or "default". These names can be used in gain related API called. An empty return value doesn't mean there are no profile options, it means that this radio does not have any gain profiles implemented, and typically means there is only one default profile of set gain
◆ get_tx_gain_range() [1/2]
virtual gain_range_t uhd::usrp::multi_usrp::get_tx_gain_range ( const std::string &  name,
size_t  chan = 0
Get the TX gain range for the specified gain element. For an empty name, calculate the overall gain range.
a gain range object
◆ get_tx_gain_range() [2/2]
gain_range_t uhd::usrp::multi_usrp::get_tx_gain_range ( size_t  chan = 0)
◆ get_tx_lo_export_enabled()
virtual bool uhd::usrp::multi_usrp::get_tx_lo_export_enabled ( const std::string &  name = ALL_LOS,
◆ get_tx_lo_freq()
virtual double uhd::usrp::multi_usrp::get_tx_lo_freq ( const std::string &  name,
Get the current TX LO frequency (Advanced).
If the channel does not have independently configurable LOs the current rf frequency will be returned. See also set_tx_lo_freq() for more information.
◆ get_tx_lo_freq_range()
virtual freq_range_t uhd::usrp::multi_usrp::get_tx_lo_freq_range ( const std::string &  name,
Get the LO frequency range of the TX LO.
◆ get_tx_lo_names()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_tx_lo_names ( size_t  chan = 0)
Get a list of possible TX LO stage names
See also get_rx_lo_names().
◆ get_tx_lo_source()
virtual const std::string uhd::usrp::multi_usrp::get_tx_lo_source ( const std::string &  name = ALL_LOS,
Get the currently selected TX LO source.
◆ get_tx_lo_sources()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_tx_lo_sources ( const std::string &  name = ALL_LOS,
Channels which do not have controllable LO sources will return "internal". Typical values are "internal" and "external". These options are device-specific.
◆ get_tx_num_channels()
virtual size_t uhd::usrp::multi_usrp::get_tx_num_channels ( void  )
Get the number of TX channels in this configuration. This is the number of USRPs times the number of TX channels per board, where the number of TX channels per board is homogeneous among all USRPs.
◆ get_tx_rate()
virtual double uhd::usrp::multi_usrp::get_tx_rate ( size_t  chan = 0)
Gets the TX sample rate.
the rate in Sps
◆ get_tx_rates()
virtual meta_range_t uhd::usrp::multi_usrp::get_tx_rates ( size_t  chan = 0)
Get a range of possible TX rates.
◆ get_tx_sensor()
virtual sensor_value_t uhd::usrp::multi_usrp::get_tx_sensor ( const std::string &  name,
size_t  chan = 0
Get an TX frontend sensor value.
◆ get_tx_sensor_names()
virtual std::vector<std::string> uhd::usrp::multi_usrp::get_tx_sensor_names ( size_t  chan = 0)
Get a list of possible TX frontend sensor names.
◆ get_tx_stream()
virtual tx_streamer::sptr uhd::usrp::multi_usrp::get_tx_stream ( const stream_args_t args)
◆ get_tx_subdev_name()
virtual std::string uhd::usrp::multi_usrp::get_tx_subdev_name ( size_t  chan = 0)
Get the name of the TX frontend.
the frontend name
◆ get_tx_subdev_spec()
virtual uhd::usrp::subdev_spec_t uhd::usrp::multi_usrp::get_tx_subdev_spec ( size_t  mboard = 0)
Get the TX frontend specification.
◆ get_user_settings_iface()
virtual uhd::wb_iface::sptr uhd::usrp::multi_usrp::get_user_settings_iface ( const size_t  chan = 0)
Return a user settings interface object
This is only supported by some USRPs (B2xx series, N230). It will return an object that will allow to peek and poke user settings, which typically are implemented by custom FPGA images. If the device does not support such an interface, it will return a null pointer. This allows to probe this functionality, but can lead to dereferencing errors if no checks are performed.
A typical way to use this is as follows:
auto usrp = multi_usrp::make(device_args);
const size_t chan = 0;
auto user_settings = usrp->get_user_settings_iface(chan);
if (!user_settings) {
std::cout << "No user settings!" << std::endl;
} else {
user_settings->poke32(0, 23); // Write value 23 to register 0
Either a uhd::wb_iface object to poke the user settings, or a nullptr if the device doesn't support this interface.
◆ get_usrp_rx_info()
virtual dict<std::string, std::string> uhd::usrp::multi_usrp::get_usrp_rx_info ( size_t  chan = 0)
Returns identifying information about this USRP's configuration. Returns motherboard ID, name, and serial. Returns daughterboard RX ID, subdev name and spec, serial, and antenna.
chanchannel index 0 to N-1
RX info
◆ get_usrp_tx_info()
virtual dict<std::string, std::string> uhd::usrp::multi_usrp::get_usrp_tx_info ( size_t  chan = 0)
Returns identifying information about this USRP's configuration. Returns motherboard ID, name, and serial. Returns daughterboard TX ID, subdev name and spec, serial, and antenna.
TX info
◆ is_device3()
virtual bool uhd::usrp::multi_usrp::is_device3 ( void  )
Returns true if this is a generation-3 device.
◆ issue_stream_cmd()
virtual void uhd::usrp::multi_usrp::issue_stream_cmd ( const stream_cmd_t stream_cmd,
size_t  chan = ALL_CHANS
◆ make()
static sptr uhd::usrp::multi_usrp::make ( const device_addr_t dev_addr)
dev_addrthe device address
a new single usrp object
Exceptions
uhd::key_errorno device found
uhd::index_errorfewer devices found than expected
◆ read_register()
virtual uint64_t uhd::usrp::multi_usrp::read_register ( const std::string &  path,
Read a low-level register field from a register in the USRP hardware
fieldthe identifier of bitfield to be read
the value of the register field
◆ set_clock_config()
virtual void uhd::usrp::multi_usrp::set_clock_config ( const clock_config_t clock_config,
Set the clock configuration for the usrp device. DEPRECATED in favor of set time and clock source calls. This tells the usrp how to get a 10MHz reference and PPS clock. See the documentation for clock_config_t for more info.
clock_configthe clock configuration to set
◆ set_clock_source()
virtual void uhd::usrp::multi_usrp::set_clock_source ( const std::string &  source,
const size_t  mboard = ALL_MBOARDS
Set the clock source for the USRP device
This sets the source of the frequency reference, typically a 10 MHz signal. In order to frequency-align multiple USRPs, it is necessary to connect all of them to a common reference and provide them with the same clock source. Typical values for source are 'internal', 'external'. Refer to the specific device manual for a full list of options.
If the value for for source is not available for this device, it will throw an exception. Calling get_clock_sources() will return a valid list of options for this method.
Side effects: Some devices only support certain combinations of time and clock source. It is possible that the underlying device implementation will change the time source when the clock source changes and vice versa. Reading back the current values of clock and time source using get_clock_source() and get_time_source() is the only certain way of knowing which clock and time source are currently selected.
This function does not force a re-initialization of the underlying hardware when the value does not change. Consider the following snippet:
auto usrp = uhd::usrp::multi_usrp::make(device_args);
// This may or may not cause the hardware to reconfigure, depending on
// the default state of the device
usrp->set_clock_source("internal");
// Now, the clock source is definitely set to "internal"!
// The next call probably won't do anything but will return immediately,
// because the clock source was already set to "internal"
// The clock source is still guaranteed to be "internal" at this point
See also:
sourcea string representing the time source
Exceptions
uhd::value_errorif source is an invalid option
◆ set_clock_source_out()
virtual void uhd::usrp::multi_usrp::set_clock_source_out ( const bool  enb,
Send the clock source to an output connector. This call is only applicable on devices with reference outputs. By default, the reference output will be enabled for ease of use. This call may be used to enable or disable the output.
enbtrue to output the clock source.
◆ set_command_time()
virtual void uhd::usrp::multi_usrp::set_command_time ( const uhd::time_spec_t time_spec,
Set the time at which the control commands will take effect.
A timed command will back-pressure all subsequent timed commands, assuming that the subsequent commands occur within the time-window. If the time spec is late, the command will be activated upon arrival.
time_specthe time at which the next command will activate
◆ set_filter()
virtual void uhd::usrp::multi_usrp::set_filter ( const std::string &  path,
Write back a filter obtained by get_filter() to the signal path. This filter can be a modified version of the originally returned one. The information about Rx or Tx is contained in the path parameter.
filterthe filter_info_base::sptr of the filter object to be written
◆ set_gpio_attr() [1/2]
virtual void uhd::usrp::multi_usrp::set_gpio_attr ( const std::string &  bank,
const uint32_t  mask = 0xffffffff,
Set a GPIO attribute on a particular GPIO bank. Possible attribute names:
    valuethe new value for this GPIO bank
    maskthe bit mask to effect which pins are changed
◆ set_gpio_attr() [2/2]
const std::string &  value,
    • "IN" for input
◆ set_master_clock_rate()
virtual void uhd::usrp::multi_usrp::set_master_clock_rate ( double  rate,
Set the master clock rate.
What exactly this changes is device-dependent, but it will always affect the rate at which the ADC/DAC is running.
Like tuning receive or transmit frequencies, this call will do a best effort to change the master clock rate. The device will coerce to the closest clock rate available, and on many devices won't actually change anything at all. Call get_master_clock_rate() to see which rate was actually applied.
Note that changing this value during streaming is not recommended and can have random side effects.
If the device has an 'auto clock rate' setting (e.g. B200, see also Automatic Clock Rate Setting), calling this function will disable the automatic clock rate selection, and the clock rate will be fixed to rate.
ratethe new master clock rate in Hz
◆ set_normalized_rx_gain()
virtual void uhd::usrp::multi_usrp::set_normalized_rx_gain ( double  gain,
size_t  chan = 0
Set the normalized RX gain value.
The normalized gain is a value in [0, 1], where 0 is the smallest gain value available, and 1 is the largest, independent of the device. In between, gains are linearly interpolated.
Check the individual device manual for notes on the gain range.
Note that it is not possible to specify a gain name for this function, it will always set the overall gain.
gainthe normalized gain value
Exceptions
◆ set_normalized_tx_gain()
virtual void uhd::usrp::multi_usrp::set_normalized_tx_gain ( double  gain,
size_t  chan = 0
Set the normalized TX gain value.
See set_normalized_rx_gain() for a discussion on normalized gains.
Exceptions
◆ set_rx_agc()
virtual void uhd::usrp::multi_usrp::set_rx_agc ( bool  enable,
size_t  chan = 0
Enable or disable the RX AGC module. Once this module is enabled manual gain settings will be ignored. The AGC will start in a default configuration which should be good for most use cases. Device specific configuration parameters can be found in the property tree.
enableEnable or Disable the AGC
◆ set_rx_antenna()
virtual void uhd::usrp::multi_usrp::set_rx_antenna ( const std::string &  ant,
size_t  chan = 0
Select the RX antenna on the frontend.
antthe antenna name
◆ set_rx_bandwidth()
virtual void uhd::usrp::multi_usrp::set_rx_bandwidth ( double  bandwidth,
size_t  chan = 0
Set the RX bandwidth on the frontend.
bandwidththe bandwidth in Hz
◆ set_rx_dc_offset() [1/2]
virtual void uhd::usrp::multi_usrp::set_rx_dc_offset ( const bool  enb,
Enable/disable the automatic RX DC offset correction. The automatic correction subtracts out the long-run average.
When disabled, the averaging option operation is halted. Once halted, the average value will be held constant until the user re-enables the automatic correction or overrides the value by manually setting the offset.
enbtrue to enable automatic DC offset correction
◆ set_rx_dc_offset() [2/2]
virtual void uhd::usrp::multi_usrp::set_rx_dc_offset ( const std::complex< double > &  offset,
Set a constant RX DC offset value. The value is complex to control both I and Q. Only set this when automatic correction is disabled.
offsetthe dc offset (1.0 is full-scale)
◆ set_rx_freq()
virtual tune_result_t uhd::usrp::multi_usrp::set_rx_freq ( const tune_request_t tune_request,
size_t  chan = 0
Set the RX center frequency.
tune_requesttune request instructions
a tune result object
◆ set_rx_gain() [1/2]
virtual void uhd::usrp::multi_usrp::set_rx_gain ( double  gain,
size_t  chan = 0
Set the RX gain value for the specified gain element. For an empty name, distribute across all gain elements.
gainthe gain in dB
◆ set_rx_gain() [2/2]
size_t  chan = 0
◆ set_rx_gain_profile()
virtual void uhd::usrp::multi_usrp::set_rx_gain_profile ( const std::string &  profile,
Set the RX gain profile.
profilethe profile string option
◆ set_rx_iq_balance() [1/2]
virtual void uhd::usrp::multi_usrp::set_rx_iq_balance ( const bool  enb,
size_t  chan
Enable/disable the automatic IQ imbalance correction.
enbtrue to enable automatic IQ balance correction
◆ set_rx_iq_balance() [2/2]
virtual void uhd::usrp::multi_usrp::set_rx_iq_balance ( const std::complex< double > &  correction,
Set the RX frontend IQ imbalance correction. Use this to adjust the magnitude and phase of I and Q.
correctionthe complex correction (1.0 is full-scale)
◆ set_rx_lo_export_enabled()
virtual void uhd::usrp::multi_usrp::set_rx_lo_export_enabled ( bool  enabled,
size_t  chan = 0
Set whether the LO used by the device is exported
For USRPs that support exportable LOs, this function configures if the LO used by chan is exported or not.
enabledif true then export the LO
namethe name of the LO stage to update
chanthe channel index 0 to N-1 for the source channel
Exceptions
uhd::runtime_errorif LO exporting is not enabled
◆ set_rx_lo_freq()
virtual double uhd::usrp::multi_usrp::set_rx_lo_freq ( double  freq,
size_t  chan = 0
Set the RX LO frequency (Advanced).
The actual behaviour is device-specific. However, as a rule of thumb, this will coerce the underlying driver into some state. Typical situations include:
  • LOs are internal, and this function is called to pin an LO to a certain value. This can force the driver to pick different IFs for different stages, and there may be situations where this behaviour can be used to reduce spurs in specific bands.
  • LOs are external. In this case, this function is used to notify UHD what the actual value of an externally provided LO is. The only time when calling this function is necessary is when the LO source is set to external, but the external LO can't be tuned to the exact value required by UHD to achieve a certain center frequency. In this case, calling set_rx_lo_freq() will let UHD know that the LO is not the expected value, and it's possible that UHD will find other ways to compensate for the LO offset.
freqthe frequency to set the LO to
a coerced LO frequency
◆ set_rx_lo_source()
virtual void uhd::usrp::multi_usrp::set_rx_lo_source ( const std::string &  src,
size_t  chan = 0
Set the LO source for the USRP device.
For USRPs that support selectable LO sources, this function allows switching between them. Typical options for source: internal, external.
srca string representing the LO source
namethe name of the LO stage to update. If the wildcard value ALL_LOS is used, the setting will be applied to all LOs on this channel.
◆ set_rx_rate()
virtual void uhd::usrp::multi_usrp::set_rx_rate ( double  rate,
Set the RX sample rate.
ratethe rate in Sps
◆ set_rx_subdev_spec()
virtual void uhd::usrp::multi_usrp::set_rx_subdev_spec ( const uhd::usrp::subdev_spec_t spec,
Set the RX frontend specification: The subdev spec maps a physical part of a daughter-board to a channel number. Set the subdev spec before calling into any methods with a channel number. The subdev spec must be the same size across all motherboards.
specthe new frontend specification
◆ set_sync_source() [1/2]
virtual void uhd::usrp::multi_usrp::set_sync_source ( const std::string &  clock_source,
const std::string &  time_source,
Set the reference/synchronization sources for the USRP device
This is a shorthand for calling set_sync_source(device_addr_t("clock_source=$CLOCK_SOURCE,time_source=$TIME_SOURCE"))
clock_sourceA string representing the clock source
time_sourceA string representing the time source
Exceptions
uhd::value_errorif the sources don't actually exist
◆ set_sync_source() [2/2]
virtual void uhd::usrp::multi_usrp::set_sync_source ( const device_addr_t sync_source,
Typically, this will set both clock and time source in a single call. For some USRPs, this may be significantly faster than calling set_time_source() and set_clock_source() individually.
Example:
usrp->set_sync_source(
device_addr_t("clock_source=external,time_source=external"));
This function does not force a re-initialization of the underlying hardware when the value does not change. See also set_time_source() and set_clock_source() for more details.
sync_sourceA dictionary representing the various source settings.
Exceptions
uhd::value_errorif the sources don't actually exist or if the combination of clock and time source is invalid.
◆ set_time_next_pps()
virtual void uhd::usrp::multi_usrp::set_time_next_pps ( const time_spec_t time_spec,
Set the time registers on the usrp at the next pps tick. The values will not be latched in until the pulse occurs. It is recommended that the user sleep(1) after calling to ensure that the time registers will be in a known state prior to use.
Note: Because this call sets the time on the "next" pps, the seconds in the time spec should be current seconds + 1.
time_specthe time to latch into the usrp device
◆ set_time_now()
virtual void uhd::usrp::multi_usrp::set_time_now ( const time_spec_t time_spec,
Sets the time registers on the usrp immediately.
If only one MIMO master is present in your configuration, set_time_now is safe to use because the slave's time automatically follows the master's time. Otherwise, this call cannot set the time synchronously across multiple devices. Please use the set_time_next_pps or set_time_unknown_pps calls with a PPS signal.
◆ set_time_source()
virtual void uhd::usrp::multi_usrp::set_time_source ( const std::string &  source,
Set the time source for the USRP device
This sets the method of time synchronization, typically a pulse per second signal. In order to time-align multiple USRPs, it is necessary to connect all of them to a common reference and provide them with the same time source. Typical values for source are 'internal', 'external'. Refer to the specific device manual for a full list of options.
If the value for for source is not available for this device, it will throw an exception. Calling get_time_sources() will return a valid list of options for this method.
Side effects: Some devices only support certain combinations of time and clock source. It is possible that the underlying device implementation will change the clock source when the time source changes and vice versa. Reading back the current values of clock and time source using get_clock_source() and get_time_source() is the only certain way of knowing which clock and time source are currently selected.
usrp->set_time_source("internal");
// Now, the time source is definitely set to "internal"!
// because the time source was already set to "internal"
// The time source is still guaranteed to be "internal" at this point
See also:
Exceptions
◆ set_time_source_out()
virtual void uhd::usrp::multi_usrp::set_time_source_out ( const bool  enb,
Send the time source to an output connector. This call is only applicable on devices with PPS outputs. By default, the PPS output will be enabled for ease of use. This call may be used to enable or disable the output.
enbtrue to output the time source.
◆ set_time_unknown_pps()
virtual void uhd::usrp::multi_usrp::set_time_unknown_pps ( const time_spec_t time_spec)
Synchronize the times across all motherboards in this configuration. Use this method to sync the times when the edge of the PPS is unknown.
Ex: Host machine is not attached to serial port of GPSDO and can therefore not query the GPSDO for the PPS edge.
This is a 2-step process, and will take at most 2 seconds to complete. Upon completion, the times will be synchronized to the time provided.
  • Step1: wait for the last pps time to transition to catch the edge
  • Step2: set the time at the next pps (synchronous for all boards)
time_specthe time to latch at the next pps after catching the edge
◆ set_tx_antenna()
virtual void uhd::usrp::multi_usrp::set_tx_antenna ( const std::string &  ant,
size_t  chan = 0
Select the TX antenna on the frontend.
antthe antenna name
◆ set_tx_bandwidth()
virtual void uhd::usrp::multi_usrp::set_tx_bandwidth ( double  bandwidth,
size_t  chan = 0
Set the TX bandwidth on the frontend.
◆ set_tx_dc_offset()
virtual void uhd::usrp::multi_usrp::set_tx_dc_offset ( const std::complex< double > &  offset,
Set a constant TX DC offset value. The value is complex to control both I and Q.
◆ set_tx_freq()
virtual tune_result_t uhd::usrp::multi_usrp::set_tx_freq ( const tune_request_t tune_request,
size_t  chan = 0
Set the TX center frequency.
◆ set_tx_gain() [1/2]
virtual void uhd::usrp::multi_usrp::set_tx_gain ( double  gain,
size_t  chan = 0
Set the TX gain value for the specified gain element. For an empty name, distribute across all gain elements.
gainthe gain in dB
◆ set_tx_gain() [2/2]
size_t  chan = 0
◆ set_tx_gain_profile()
virtual void uhd::usrp::multi_usrp::set_tx_gain_profile ( const std::string &  profile,
Set the TX gain profile.
◆ set_tx_iq_balance()
virtual void uhd::usrp::multi_usrp::set_tx_iq_balance ( const std::complex< double > &  correction,
Set the TX frontend IQ imbalance correction. Use this to adjust the magnitude and phase of I and Q.
◆ set_tx_lo_export_enabled()
virtual void uhd::usrp::multi_usrp::set_tx_lo_export_enabled ( const bool  enabled,
Set whether the TX LO used by the device is exported
Exceptions
◆ set_tx_lo_freq()
virtual double uhd::usrp::multi_usrp::set_tx_lo_freq ( const double  freq,
Set the TX LO frequency (Advanced).
  • LOs are external. In this case, this function is used to notify UHD what the actual value of an externally provided LO is. The only time when calling this function is necessary is when the LO source is set to external, but the external LO can't be tuned to the exact value required by UHD to achieve a certain center frequency. In this case, calling set_tx_lo_freq() will let UHD know that the LO is not the expected value, and it's possible that UHD will find other ways to compensate for the LO offset.
◆ set_tx_lo_source()
virtual void uhd::usrp::multi_usrp::set_tx_lo_source ( const std::string &  src,
Set the TX LO source for the USRP device.
◆ set_tx_rate()
virtual void uhd::usrp::multi_usrp::set_tx_rate ( double  rate,
Set the TX sample rate.
ratethe rate in Sps
◆ set_tx_subdev_spec()
virtual void uhd::usrp::multi_usrp::set_tx_subdev_spec ( const uhd::usrp::subdev_spec_t spec,
Set the TX frontend specification: The subdev spec maps a physical part of a daughter-board to a channel number. Set the subdev spec before calling into any methods with a channel number. The subdev spec must be the same size across all motherboards.
◆ set_user_register()
virtual void uhd::usrp::multi_usrp::set_user_register ( const uint8_t  addr,
Perform write on the user configuration register bus. These only exist if the user has implemented custom setting registers in the device FPGA.
addr8-bit register address
data32-bit register value
mboardwhich motherboard to set the user register
◆ write_register()
virtual void uhd::usrp::multi_usrp::write_register ( const std::string &  path,
Write a low-level register field for a register in the USRP hardware
fieldthe identifier of bitfield to be written (all other bits remain unchanged)
valuethe value to write to the register field
◆ ALL_CHANS
const size_t uhd::usrp::multi_usrp::ALL_CHANS
◆ ALL_GAINS
const std::string uhd::usrp::multi_usrp::ALL_GAINS
◆ ALL_LOS
const std::string uhd::usrp::multi_usrp::ALL_LOS
◆ ALL_MBOARDS
const size_t uhd::usrp::multi_usrp::ALL_MBOARDS
