radio_ctrl.hpp
2 // Copyright 2015-2016 Ettus Research LLC
4 //
6 //
7
8 #ifndef INCLUDED_LIBUHD_RFNOC_RADIO_CTRL_HPP
9 #define INCLUDED_LIBUHD_RFNOC_RADIO_CTRL_HPP
10
17 #include <uhd/types/direction.hpp>
18 #include <uhd/types/ranges.hpp>
19
20 namespace uhd { namespace rfnoc {
21
25  public sink_block_ctrl_base,
26  public rate_node_ctrl,
27  public tick_node_ctrl,
29 {
30 public:
32
33  virtual ~radio_ctrl() {}
34
35
37  static const size_t ALL_CHANS = size_t(~0);
38
40  static const std::string ALL_GAINS;
41
43  static const std::string ALL_LOS;
44
45  /************************************************************************
46  * API calls
47  ***********************************************************************/
52  virtual double get_rate() const = 0;
53
58  virtual double set_rate(double rate) = 0;
59
64  virtual std::string get_tx_antenna(const size_t chan) /* const */ = 0;
65
70  virtual void set_tx_antenna(const std::string& ant, const size_t chan) = 0;
71
76  virtual std::string get_rx_antenna(const size_t chan) /* const */ = 0;
77
82  virtual void set_rx_antenna(const std::string& ant, const size_t chan) = 0;
83
91  virtual double get_tx_frequency(const size_t chan) /* const */ = 0;
92
103  virtual double set_tx_frequency(const double freq, size_t chan) = 0;
104
109  virtual double get_rx_frequency(const size_t chan) /* const */ = 0;
110
120  virtual double set_rx_frequency(const double freq, const size_t chan) = 0;
121
126  virtual double get_tx_gain(const size_t chan) = 0;
127
135  virtual double set_tx_gain(const double gain, const size_t chan) = 0;
136
141  virtual double get_rx_gain(const size_t chan) = 0;
142
150  virtual double set_rx_gain(const double gain, const size_t chan) = 0;
151
156  virtual double get_tx_bandwidth(const size_t chan) = 0;
157
164  virtual double set_tx_bandwidth(const double bandwidth, const size_t chan) = 0;
165
170  virtual double get_rx_bandwidth(const size_t chan) = 0;
171
178  virtual double set_rx_bandwidth(const double bandwidth, const size_t chan) = 0;
179
187  virtual void set_time_now(const time_spec_t& time_spec) = 0;
188
200  virtual void set_time_next_pps(const time_spec_t& time_spec) = 0;
201
210  virtual time_spec_t get_time_now() = 0;
211
216  virtual time_spec_t get_time_last_pps() = 0;
217
222  virtual std::vector<std::string> get_gpio_banks() const = 0;
223
239  virtual void set_gpio_attr(const std::string& bank,
240  const std::string& attr,
241  const uint32_t value,
242  const uint32_t mask) = 0;
243
259  virtual uint32_t get_gpio_attr(const std::string& bank, const std::string& attr) = 0;
260
261  /**************************************************************************
262  * LO Controls
263  *************************************************************************/
269  virtual std::vector<std::string> get_rx_lo_names(const size_t chan) = 0;
270
279  virtual std::vector<std::string> get_rx_lo_sources(
280  const std::string& name, const size_t chan) = 0;
281
290  virtual freq_range_t get_rx_lo_freq_range(
291  const std::string& name, const size_t chan) = 0;
292
302  virtual void set_rx_lo_source(
303  const std::string& src, const std::string& name, const size_t chan) = 0;
304
313  virtual const std::string get_rx_lo_source(
314  const std::string& name, const size_t chan) = 0;
315
324  virtual void set_rx_lo_export_enabled(
325  bool enabled, const std::string& name, const size_t chan) = 0;
326
332  virtual bool get_rx_lo_export_enabled(const std::string& name, const size_t chan) = 0;
333
341  virtual double set_rx_lo_freq(
342  double freq, const std::string& name, const size_t chan) = 0;
343
352  virtual double get_rx_lo_freq(const std::string& name, const size_t chan) = 0;
353
359  virtual std::vector<std::string> get_tx_lo_names(const size_t chan) = 0;
360
369  virtual std::vector<std::string> get_tx_lo_sources(
370  const std::string& name, const size_t chan) = 0;
371
380  virtual freq_range_t get_tx_lo_freq_range(
381  const std::string& name, const size_t chan) = 0;
382
392  virtual void set_tx_lo_source(
393  const std::string& src, const std::string& name, const size_t chan) = 0;
394
403  virtual const std::string get_tx_lo_source(
404  const std::string& name, const size_t chan) = 0;
405
414  virtual void set_tx_lo_export_enabled(
415  const bool enabled, const std::string& name, const size_t chan) = 0;
416
422  virtual bool get_tx_lo_export_enabled(const std::string& name, const size_t chan) = 0;
423
433  virtual double set_tx_lo_freq(
434  const double freq, const std::string& name, const size_t chan) = 0;
435
447  virtual double get_tx_lo_freq(const std::string& name, const size_t chan) = 0;
448
449  /**************************************************************************
450  * Time and clock control
451  *************************************************************************/
452
461  virtual void set_time_source(const std::string& source) = 0;
462
468  virtual std::string get_time_source() = 0;
469
475  virtual std::vector<std::string> get_time_sources() = 0;
476
484  virtual void set_clock_source(const std::string& source) = 0;
485
491  virtual std::string get_clock_source() = 0;
492
498  virtual std::vector<std::string> get_clock_sources() = 0;
499
506  virtual size_t get_chan_from_dboard_fe(
507  const std::string& fe, const uhd::direction_t dir) = 0;
508
511  virtual std::string get_dboard_fe_from_chan(
512  const size_t chan, const uhd::direction_t dir) = 0;
513
516  virtual void enable_rx_timestamps(const bool enable, const size_t chan) = 0;
517 }; /* class radio_ctrl */
518
519 }} /* namespace uhd::rfnoc */
520
521 #endif /* INCLUDED_LIBUHD_RFNOC_RADIO_CTRL_HPP */
Definition: terminator_node_ctrl.hpp:29
#define UHD_RFNOC_BLOCK_OBJECT(class_name)
This macro must be put in the public section of an RFNoC.
Definition: block_ctrl_base.hpp:59
Definition: sink_block_ctrl_base.hpp:25
Definition: time_spec.hpp:29
Definition: rate_node_ctrl.hpp:27
Block controller for all RFNoC-based radio blocks.
Definition: radio_ctrl.hpp:24
A wildcard gain element name.
Definition: radio_ctrl.hpp:40
A wildcard local oscillator element name.
Definition: radio_ctrl.hpp:43
Definition: build_info.hpp:13
Definition: tick_node_ctrl.hpp:24
#define UHD_RFNOC_API
Definition: config.hpp:104
Definition: source_block_ctrl_base.hpp:24
direction_t
Definition: direction.hpp:13
Definition: soft_register.hpp:88
Definition: ranges.hpp:65
